Reply 20 of 32, by Shiftyy
NeoG_ wrote on 2026-07-18, 23:36:
If you are interested in making your WP32 McCake sound more like an SC-55 in soundfont mode, I recommend Trevor0402's SC-55 soun […]
Shiftyy wrote on 2026-07-12, 07:05:
WaveTable #2: WP32 McCake (Connected via PCMIDI MPU-401)
If you are interested in making your WP32 McCake sound more like an SC-55 in soundfont mode, I recommend Trevor0402's SC-55 soundfont
https://www.doomworld.com/forum/topic/118828- … comment-2493425
And I made a patched version of mt32-pi for the WP32 which rolls in the SC-55s specific percussion behaviour (which the dreamblaster GS series doesn't replicate)
Getting SC-55 style drum note cut behaviour on MT32-Pi Fluidsynth
Thanks but I'm using a custom firmware and don't want to go through that process again.
I'm also happy with the X2GS. I'll probably only replace it if I ever get the opportunity to buy a SCB-55 or similar, which is unlikely.
Reply 22 of 32, by NeoG_
Shiftyy wrote on 2026-07-22, 16:23:
Oh yeah I forgot about that, well now I have the ability to recompile mt32-pi from source and I like that feature I rolled it into the kernel image for myself too. It doesn't require custom ROMs either since the display routine is updated instead of the ROM files. I've attached it in case you are interested. But in your case you would need to revert to the unmodified ROMs so the checksum doesn't throw an error.
Reply 23 of 32, by Shiftyy
NeoG_ wrote on 2026-07-23, 01:20:
Cool, I'll try it out in the next few weeks once my PC is back together. I have it disassembled currently.
Reply 24 of 32, by Shiftyy
While at the CoD4 LAN, someone pointed out to me that I had a bulging capacitor.
The attachment 20260725_032303.jpg is no longer available
He was right. I ended up replacing all five capacitors that were next to the VRMs with Panasonic EEU-FR1C152.
My next goal was to try and achieve a 4GHz overclock.
I performed a volt mod to the CPU. This volt mod is for 1.5v, however CPUZ reports it as 1.45v. I used copper tape rather than conductive paint.
The attachment 20260727_212722.jpg is no longer available
The attachment 20260727_212719.jpg is no longer available
Ignore the scratches. They are purely cosmetic.
I then installed my new Noctua NH-C14S CPU cooler. It has been fitted with two brand new Noctua NF-A14x25 G2 PWM SX2-PP 140mm fans for improved cooling and quieter operation. I used Thermal Grizzly's newly released Duronaut Pro thermal paste. I also installed the CPU's old Noctua 140mm fan to the front of the case. I wanted to cool the CPU to the best of my abilities, without using water. 1.5v is very high for this CPU.
The attachment 20260729_230315.jpg is no longer available
The attachment 20260729_230311.jpg is no longer available
Reply 25 of 32, by Shiftyy
The attachment 20260730_232252.jpg is no longer available
The attachment 20260730_005008.jpg is no longer available
The attachment 20260730_005206.jpg is no longer available
The attachment 20260729_145330.jpg is no longer available
The attachment 20260729_145326.jpg is no longer available
As you can see, the CPU cooler barely fits with maybe 1-2cm clearance.
Reply 26 of 32, by Shiftyy
I wasn't able to achieve a stable 4GHz overclock. At 1.5v, Windows refused to boot. I tried 1.6v, and was able to complete a benchmark, but the system was not stable.
The attachment 20260729_232642.jpg is no longer available
Is this the fastest benchmark for a machine with full ISA DMA support, ever? Not counting those that use LPC-ISA bridges, because I hear compatibility is rough.
1.6v is too high and the temps aren't reasonable. So I dropped it back down to 1.5v. The sweet spot ended up being 3.6GHz. It is 100% stable at 1.5v from my stress testing.
Here are the final benchmark results
The attachment 20260730_231851.jpg is no longer available
The attachment 20260731_144445.jpg is no longer available
The attachment 20260731_145744.jpg is no longer available
The attachment 20260731_150816.jpg is no longer available
With the side panel on, I get around 44c-50c idle (Depends if the air in the case is already warm) and around 62-63c under full load with Prime95.
With the side panel off, I get around 41-42c idle and around 59c-60c under full load with Prime95.
I was getting around 55c whilst playing GTA:SA with the side panel on, which is a more realistic scenario since the machine is only going to be used for gaming.
The overclocking is done. Now the underclocking begins.
Reply 27 of 32, by myne
https://theretroweb.com/chip/documentation/w8 … 76686200327.pdf
This might help you get a bit higher overclock
Specifically pp17
"Bit 7 SYSCLK Divider.
0 = SYSCLK is equal to PCICLK divided by 4.
1 = SYSCLK is equal to PCICLK divided by 3"
If it's not already in the bios, it'll be fun figuring out how to set it.
I built:
Reply 28 of 32, by AlexZ
If you want to OC, you might want to consider a case with more airflow. 60'C air will accumulate in the case with just one little exhaust fan. PSU fan is only for cooling the PSU itself.
Newer cases had much more airflow like ZALMAN Z9 Plus:
https://www.newegg.com/zalman-atx-mid-tower-s … N82E16811235027
I use it for my single core Athlon 64, but it could be used even for modern PC as long as GPU length is not an issue.
Cooler Master N300 / N400 also have lot of airflow and slot for FDD. My Phenom X4 uses Cooler Master N500 ( https://www.newegg.com/cooler-master-atx-mid- … N82E16811119280 ).
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 29 of 32, by Shiftyy
myne wrote on 2026-07-31, 05:51:
https://theretroweb.com/chip/documentation/w8 … 76686200327.pdf This might help you get a bit higher overclock Specifically pp17 […]
Specifically pp17
Is this for FSB overclocks? I am using the unlocked multiplier to overclock. I tried using setfsb, but the machine freezes.
Reply 30 of 32, by Shiftyy
AlexZ wrote on 2026-07-31, 07:02:
If you want to OC, you might want to consider a case with more airflow. 60'C air will accumulate in the case with just one littl […]
I will run an extended stress test, but I believe 62c-63c is the worst case scenario for the ambient temps I was in. And that was with Prime95 which is unrealistic, as no game will get near those those loads or temps. I'm okay with the current results. If it gets worse, I'd rather reduce the overclock than replace the case.
The case is actually really good for its time. Side panel vents and front bottom vents.
Reply 31 of 32, by Shiftyy
I got a chance to try this out and compare it to the X2GS. Unfortunately, the mt32-pi has much more bass and I couldn't make a good conclusion. Plus I have really poor hearing (Half deaf) so I'm probably the worst person on earth for comparing sounds.
Reply 32 of 32, by myne
Shiftyy wrote on 2026-07-31, 12:41:
Specifically pp17
Yeah. Ok. Not relevant to you then.
I built:
