AMD K6 3DMARK, aiming for stars.
Reply 600 of 725, by Necrodude
Here is a onedrive link to the stuff
https://1drv.ms/f/c/b8c79c7b63196774/EtEat31d … 6HMQ_w?e=hyBUol
Quake3 installation
Installation:
Just drag and drop the files in your quake3 folder.
If the game for some reason decides not to start. Try another config file. Remember, if you try this, also delete the q3config.cfg file in your baseq3 folder. The autoexec file writes it info to the q3config file.
The default autoexec config file is the fastest.
This patch is also modular. You can choose if you want compressed textures or sounds.
In the Baseq3 folder and you will find different pak . You will find the following files:
pak9 - map animations This file turns of all the moving stuff on the maps.
pak9 - sounds This file includes low quality faster sounds.
pak9 - texures This file includes compressed faster textures.
pak9 - GFX This file includes compressed explosion effects etc.
If you dont want compressed textures or sounds, or any of the stuff, just remove the pak files you want.
This Patch also includes G3Virus User exe with SMP support ,and "low Quality Audio" support. Different speed configs are also included.
Quake2 installation:
Just drag and drop the files in your quake2 folder.
pak7.pak is optional. It is a low res texture pack that gives a tiny fps boost on low end machines with 4mb graphics cards
You can turn of the games textures with this variable in the autoexec.cfg file
set gl_hack_notextures "1" \\means no textures
set gl_hack_notextures "0" \\ textures on
The sound has been set to 8khz. This is a feature that cant be choosed in the menu. Less khz means more FPS
set s_khz "8"
22khz is high quality
Unreal Tournament installation:
First make a backup of your OpenGLDrv.dll that resides in the
system folder of your unreal tournament game.
Then copy the System folder to your unreal tournament folder
Start the game, choose the options menu, then, preferences, followed by
the video section.
Click on the "change" button on the video driver option.
The game restarts, a window that is called "Unreal Tournament Video Configuration" opens,
and you can change your video driver.
Press the "show all devices" button and choose OpenGL
The game restarts. You are now ready to go!
You can change a lot of settings and gain more performance or fidelity
in a hidden menu, or the unrealtournament.ini file that you will find in the system folder.
To gain acces to the hidden menu you need to do the following.
Start the game. Press the "Tools" button, followed by system console.
A window with a black background will open. Type "preferences" and the hidden menu will open.
You can change a lot of stuff here, and even brake the game.
So be careful. If you brake the game. Delete the unrealtournament.ini file in the system folder,
the game will create a new default file.
Anyway. There is video section and a renderer section with a lot of settings that you can change.
I would recomend that you read the included UTGLR Settings.html file for more info.
Reply 601 of 725, by zuldan
Necrodude wrote on 2025-05-05, 19:39:
Here is a onedrive link to the stuff […]
Quake3 installation
Installation:
set s_khz "8"
the video section.
Awesome thank you so much for that. Going to try all 3 games 😀
Reply 602 of 725, by Necrodude
zuldan wrote on 2025-05-05, 20:11:
Quake3 installation
Installation:
set s_khz "8"
the video section.
Please post some results in this thread
AMD K6 Quake2 and Quake 3, aiming for stars.
Reply 603 of 725, by Sphere478
Re: New MVP4 build
I’ve been able to get some decent results using mvp4 lately! 😀
Anyone else have one?
I would like to try to get my nvs280, or gf2 mx400 working on it.
But as always, can’t quite seem to get those working right. Any suggestions?
Sphere's PCB projects.
Reply 604 of 725, by Mamba
Hello,
Probably this is a silly question and the answer is :”why you did that??”.
But I set up a ss7 system with a reworked Soltek motherboard (tested) and a delidded k6-2+ @ III+.
The motherboard was capable of booting into windows at 133mhz so I asked my friend to recap it.
Installed XP and run legacy update program…
Guess it was a mystake because yes the OS now is updated but any Nvidia gpu I install gives me bluescreen with nv4_disp error (with any driver). With FSB at 100Mhz of course.
Radeon is out of question because of the overclocked agp port.
Am I right?
Should I reinstall everything and keep at SP2 the OS?
If so, which necessary updates should I install (I mean updates that are needed for drivers and/or DirectX proper functionality.
Thanks
Reply 606 of 725, by Mamba
Sphere478 wrote on 2025-06-02, 22:58:
Maybe a radeon 9800 pro might be able to handle that agp port?
Ati cards are known to be unstable with agp over 66mhz.
Reply 607 of 725, by DarthSun
Mamba wrote on 2025-06-03, 04:38:
The Medion R9600 TX is an exception. PCI was at 53MHz during tuning, AGP was also very high. The 9800Pro really couldn't handle this.
The attachment 225621_lmirhh4x7kp9tddi_medion9600tx.jpg is no longer available
The attachment 225621_nphqm8xwg71mrjrg_1kkepv2sli.jpg is no longer available
The attachment 225621_qgbhh7wfy2ivkgud_p4v2sli_6.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 608 of 725, by Mamba
DarthSun wrote on 2025-06-03, 10:10:
The Medion R9600 TX is an exception. PCI was at 53MHz during tuning, AGP was also very high. The 9800Pro really couldn't handle […]
Never heard of a 9600 capable of 3.3v
Anyway, I am still kindly asking for an answer.
Reply 609 of 725, by DarthSun
Mamba wrote on 2025-06-03, 10:36:
Sure, but if you look closely, this is not XT but TX, it also works in SS7 alongside K6x.
Reply 610 of 725, by Mamba
DarthSun wrote on 2025-06-03, 10:40:
Is it a rebadged 9500 or a real 9600?
It is not clear to me.
Reply 611 of 725, by tehsiggi
Mamba wrote on 2025-06-03, 10:47:
The 9600TX is a Radeon 9500 Pro by MSI.
The attachment Screenshot from 2025-06-03 12-54-01.png is no longer available
It has an R300 core under the covers and uses an MSI custom PCB layout.
It was sold with Medion Computers, they re-badged it 9600TX because, well, bigger number better.
Cheers.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 612 of 725, by DarthSun
Hybrid manufactured by Medion. You can see from the two notches that it can run in 2x/4x/8x AGP.
https://www.techpowerup.com/gpu-specs/radeon-9600-tx.c2104
Reply 613 of 725, by DarthSun
DarthSun wrote on 2025-06-03, 11:00:
3DM01 :
The attachment 225621_yaisg7t9zbdrgydf_prescott_r9600tx_3dm01.jpg is no longer available
Reply 614 of 725, by Mamba
Oh ok.
I have already a 9500 pro L shaped memory.
My problems won’t be solved by this one.
Reply 616 of 725, by Mamba
Sphere478 wrote on 2025-06-04, 03:13:
Wasn’t the 9500 basically a 9700?
Would any of the 9700 work?
Yes.
But again the agp frequency out of spec is not ok with ATI.
See 440bx behaviour.
Anyway, I see the same symptoms using a PCI card, so probably I really messed up the OS with all unwanted updates.
Will install 98SE an try again.
Reply 617 of 725, by Sphere478
okay interesting, I had recalled incorrectly that the agp generations upped the frequency from 66 mhz to 133, that isn't the case. according to my google-fu the clock stayed at 66 mhz all the way to 8x but they did the whole DDR thing with it transmitting 2x, 4x, 8x per clock cycle. So my idea of just throwing in a 8x capable card to be compatible with the higher freq was flawed.
perhaps a 66 mhz tolerant pci video card to the rescue?
Reply 618 of 725, by Mamba
Sphere478 wrote on 2025-06-05, 05:07:
I see same behaviour with FSB at 100Mhz.
So it is not related to FSB.
I am reinstalling OS
Reply 619 of 725, by Falcosoft
Hi,
I would like to ask a favor from the proud K6-2/3 owners. 😀
Here you can find my benchmark that can run even on Win98 when at least Directx6 is installed:
x86 microarchitecture benchmark (MandelX)
Please, run the benchmark and upload the results.
I would like to get some info about how much faster K6-2/3 can be using hand optimized 3DNow! code versus optimized x87 FPU code. I suspect the results should be about more than 4x but I need hard proof.
Thanks in advance !
Website, Youtube
VST Midi Driver Midi Mapper
