First post, by PacificState
Does anyone have a BOM list to hand to recap a Quadro4 980XGL card? If there are different versions, mine has SMD capacitors. Thanks!
Thank-you so much; I'm very grateful!
One question (I couldn't figure this out from the schematics): do any or all of the capacitors need to be low ESR?
PacificState wrote on 2026-05-05, 15:04:do any or all of the capacitors need to be low ESR?
Only if you can find a 470u capacitor that isn't a Low-ESR type with an ESR of 25 mΩ. 😀
The polymer OSCON from Sanyo has been marked as "no_stuff" because, back then, it cost as much as three electrolytic capacitors.
What’s the point of all this fuss now?
PS Polymer capacitor technology is now 40 years old. However, for the first 20 years, it was protected by Sanyo’s patents, which set the prices for capacitors of this type.
That is why the schematic shows the OSCON designation.
In the mid-2000s, other manufacturers only began to produce them once the patents had expired.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
PacificState wrote on 2026-05-05, 15:04:One question (I couldn't figure this out from the schematics): do any or all of the capacitors need to be low ESR?
Yes. All part of power supply.
