First post, by lmttn
Hello again. I recently got and installed a Sound Blaster Audigy 2 ZS using the driver set on PhilsComputerLab's website. For Windows games, everything works perfectly. However, when booting the computer, I get the following error message:
Config file is incomplete.SBPortCreative SB16 Emulation Driver NOT loading.
At first, I didn't make anything of it. It wasn't until I tried installing DOS games that I realized it might be a problem, as no game I installed detected any sound hardware. Did I forget to install something, or do I need to manually make a config file? Thanks in advance.
