First post, by smelanson
Is it possible to install a real verison of DOS in DOS Box?
Reply 1 of 8, by DosFreak
Yes, Create an image of a floppy with DOS on it and use the BOOT command in dosbox to load the floppy.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 8, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I remember running COMMAND.COM from FreeDOS very long time ago in order to decrease amount of DOS memory (it was before "loadfix" command was implemented).
So I guess there should not be any problem (apart from general problem with MS DOS checking version number). Anyway - just try it and you will see.
Mirek
