First post, by smelanson
Is it possible to install a real verison of DOS in DOS Box?
Reply 1 of 8, by DosFreak
Yes, Create an image of a floppy with DOS on it and use the BOOT command in dosbox to load the floppy.
Make your games work offline
Reply 3 of 8, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I remember running COMMAND.COM from FreeDOS very long time ago in order to decrease amount of DOS memory (it was before "loadfix" command was implemented).
So I guess there should not be any problem (apart from general problem with MS DOS checking version number). Anyway - just try it and you will see.
Mirek
