Reply 760 of 1229, by feipoa
- l33t++
Sphere478 wrote on 2022-12-10, 03:02:Looking at this closer, I can add more on the underside without much sacrificing also. Again, on the 5v though […]
Do you want more 5v caps?
Thicker pcb will mean less interference and suck pins in more.
It will also increase via resistance.
Give and take.
I think 1.6 makes sense unless 2.0 is same price and even at that, a toss up
Edit: managed to fit 10 5v 1210 caps above and below without much sacrificing of design.
Want all of em? Or take some out?
Aren't there traces crossing the bottom central region? If not, or can be moved, it sounds like a decent plan to put the 4x Vin on the bottom and 4x Vout on the top. Only one minor drawback to putting the caps on the bottom centre region is they will be more difficult to remove on/off for experimenting. Not a show stopper though.
10? lol. I think 4 Vin and 4 Vout are enough. It is really diminishing returns. I think best to stick with the values and quantities tested.
