My 300Mhz Pentium Box
First post, by Yushatak
Others have expressed interest in this box of mine as I've mentioned it in other threads, so I figured I'd start a thread to discuss it. The CPU in this box is quite unique, a custom remounted laptop Tillamook 266 MMX on a desktop adapter of some kind that I found in 2010-11 or so (there was only one available at the time IIRC, or Id've bought more).
Since it's a laptop chip and wasn't designed to even have cooling AFAIK (and even if it was, it definitely can have a more effective cooler in a desktop) and it's lower voltage, so it generates less heat to start with. I overclocked it to 300Mhz since I could. It's set up at 66Mhz*4.5=297Mhz.
To my knowledge the cache is perfectly intact (someone said something about Tillamooks in desktops disabling the cache) and it's got 16KB L1 Data, 16KB L1 Inst. (are these the same or is it 32KB total?), and 1MB L2. Pretty respectable IMO!
I ran the benchmark "just because" and got 11 for single thread, and 9 for multi-thread. If anyone wants me to run a specific benchmark for comparison to similar boxen (a desktop chip at 300Mhz or 266 or what-have-you perhaps?) just let me know and I will do so.
While I have other enthusiasts looking at this, let me know if you spot anything wrong/bad/etc. that I may have overlooked. I must say I was very appreciative to see the people who maintain CPU-Z have a dedicated Windows 98 version. :3 Speaking of which, the box is running 98SE with no extra updates or anything because I've had bad luck with SP3 and 98SE2ME being unstable in the past. I plan to back up the windows folder and boot files and test combinations of them for stability once I have more software installed to use to test with (input appreciated).
Here's the specs of my baby:
CPU-Z TXT Report
Binaries
CPU-Z version 1.76.0.x32
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Timers
Perf timer 1.193 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Mobile Pentium MMX
Codename
Specification
Package TCP Mobile
CPUID 5.8.1
Extended CPUID 5.8
Core Stepping MYA0
Technology 0.25 um
Core Speed 297.0 MHz
Multiplier x Bus Speed 4.5 x 66.0 MHz
Instructions sets MMX
L1 Data cache 16 KBytes, 4-way set associative, 32-byte line size
L1 Instruction cache 16 KBytes, 4-way set associative, 32-byte line size
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01000402h
Max CPUID level 00000001h
Show last 636 lines
	Cache descriptor	Level 1, I, 16 KB, 1 thread(s)
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000581 0x00000000 0x00000000 0x008001BF
Chipset
Northbridge VIA Apollo VP3 rev. 04
Southbridge VIA VT82C586 rev. 41
Graphic Interface AGP
AGP Revision 1.0
AGP Transfer Rate 2x
AGP SBA supported, enabled
On Board Cache 1024 KBytes
Memory Type SDRAM
Memory Size 512 MBytes
Memory Frequency 66.0 MHz (1:1)
CAS# latency (CL) 3.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 6
Memory SPD
Monitoring
Mainboard Model VA-503+ (0x00000187 - 0x005A768B)
LPCIO
Hardware Monitors
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x0597
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x10
Header 0x00
PCI header
Address 0 (memory) 0xE0000000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class AGP
Caps offset 0xA0
Caps version 1.0
Caps status enabled
Transfer rate 2x (max 2x)
Queue length 1 (max 8)
PCI registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 06 11 97 05 06 00 90 82 04 00 00 06 00 10 00 00
10 08 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 80 8A 85 F0 00 00 00 00 98 00 10 20 30 40 40 40
60 0F AA C0 23 E4 E4 04 00 00 00 40 01 60 67 00 00
70 E1 8A EC 00 00 80 40 00 00 00 00 00 00 00 80 40
80 0F 41 00 00 E0 00 00 00 07 00 FC 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 02 00 10 00 03 02 00 07 02 03 00 00 0E 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 97 05
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x8598
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 06 11 98 85 07 00 20 22 00 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 00
20 00 D8 F0 DF 00 A8 F0 AF 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00
40 70 6C 50 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x0586
Revision ID 0x41
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 06 11 86 05 8F 00 00 02 41 00 01 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 05 00 00 01 00 10 A0 21 00 C4 00 00 00 00 F3
50 24 00 00 00 00 00 49 A0 00 06 F7 00 10 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 7 (0x07), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 4 (port) 0x00006400
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x0F
Int. Pin 0x00
PCI registers
00 06 11 71 05 07 00 80 02 06 8A 01 01 00 40 00 00
20 01 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 00 00
40 0B E2 09 3A 69 00 C0 00 A8 A8 A8 A8 FF 00 FF FF
50 03 03 03 03 00 00 00 00 A8 A8 A8 A8 00 00 00 00
60 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00
70 02 00 00 00 00 00 00 00 82 00 00 00 00 00 00 00
80 14 DA FE 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 06 00 71 05 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (UHCI)
Location bus 0 (0x00), device 7 (0x07), function 2 (0x02)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 4 (port) 0x00006800
Subvendor ID 0x0925
Subsystem ID 0x1234
Int. Line 0x0B
Int. Pin 0x04
PCI registers
00 06 11 38 30 07 00 00 02 02 00 03 0C 08 40 00 00
20 01 68 00 00 00 00 00 00 00 00 00 00 25 09 34 12
30 00 00 00 00 00 00 00 00 00 00 00 00 0B 04 00 00
40 00 00 00 00 C2 00 20 04 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Bridge device
Location bus 0 (0x00), device 7 (0x07), function 3 (0x03)
Common header
Vendor ID 0x1106
Model ID 0x3040
Revision ID 0x10
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 06 11 40 30 00 00 80 02 10 00 80 06 00 00 00 00
40 40 88 00 00 78 B8 00 00 01 60 00 00 00 00 00 00
50 00 FF 7F 88 00 00 00 00 00 00 00 00 00 00 00 00
Description Video device
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x121A
Model ID 0x0002
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE2000000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0xFF
Int. Pin 0x00
PCI registers
00 1A 12 02 00 02 00 80 00 02 00 00 04 00 00 00 00
10 08 00 00 E2 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 03 40 01 00 00 00 00 00 00 00 00 00 7F F0 FF 0F
50 00 00 00 00 F9 12 00 30 00 00 00 00 00 00 00 00
Description Mass storage Controller
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x105A
Model ID 0x4D69
Revision ID 0x02
PI 0x85
SubClass 0x80
BaseClass 0x01
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x00006C00
Address 1 (port) 0x00007000
Address 2 (port) 0x00007400
Address 3 (port) 0x00007800
Address 4 (port) 0x00007C00
Address 5 (memory) 0xE3000000
Subvendor ID 0x105A
Subsystem ID 0x4D68
Int. Line 0x09
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x60
Caps version 1.0
PCI registers
00 5A 10 69 4D 07 00 30 04 02 85 80 01 08 40 00 00
10 01 6C 00 00 01 70 00 00 01 74 00 00 01 78 00 00
20 01 7C 00 00 00 00 00 E3 00 00 00 00 5A 10 68 4D
30 00 00 00 00 60 00 00 00 00 00 00 00 09 01 04 12
60 01 00 21 02 00 00 00 00 00 00 00 00 00 00 00 00
Description Network Controller
Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x14B9
Model ID 0x0350
Revision ID 0x01
PI 0x00
SubClass 0x80
BaseClass 0x02
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE3004000
Address 1 (port) 0x00008000
Address 2 (port) 0x00008400
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x0A
Int. Pin 0x01
PCI registers
00 B9 14 50 03 03 00 80 82 01 00 80 02 08 00 00 00
10 00 40 00 E3 01 80 00 00 01 84 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0A 01 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x474D
Revision ID 0x65
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xD8000000
Address 1 (port) 0x0000E000
Address 2 (memory) 0xD9000000
Subvendor ID 0x1002
Subsystem ID 0x0008
Int. Line 0x04
Int. Pin 0x01
PCI capability
Caps class AGP
Caps offset 0x50
Caps version 1.0
Caps status enabled
Queue length 1 (max 256)
PCI capability
Caps offset 0x5C
Caps version 1.0
PCI registers
00 02 10 4D 47 87 00 90 02 65 00 00 03 08 40 00 00
10 00 00 00 D8 01 E0 00 00 00 00 00 D9 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 08 00
30 00 00 00 00 50 00 00 00 00 00 00 00 04 01 08 00
40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 02 5C 10 00 03 02 00 FF 02 03 00 07 01 00 01 06
DMI
DMI BIOS
vendor Award Software International Inc.
version 4.51 PG
date 07/20/98
ROM size 128 KB
DMI System Information
manufacturer System Manufacturer
product Product Name
version SYS-xxxxxx
serial Serial number xxxxxx
UUID {74737953-6D65-4D20-616E-756661637475}
SKU unknown
family unknown
DMI Baseboard
vendor First International Computer Inc.
model VA-503+
revision PCB 1.X
DMI System Enclosure
manufacturer Manufactory Name
chassis type Desktop
chassis serial Serial number xxxxxx
DMI Memory Controller
correction unknown
Max module size 256 MBytes
DMI Memory Module
designation DIMM1
size 256 MBytes (double bank)
DMI Memory Module
designation DIMM2
DMI Memory Module
designation SIMM1
DMI Memory Module
designation SIMM2
DMI Memory Module
designation SIMM3
DMI Memory Module
designation SIMM4
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector 25 Pin Dual Inline (pin 26 cut)
connector DB-25 female
DMI Port Connector
designation PS2_KB (internal)
port type Keyboard Port
connector Mini DIN
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation ISA
type ISA
width 16 bits
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Processor
manufacturer Intel
model Pentium-MMX
clock speed 300.0 MHz
FSB speed 66.0 MHz
multiplier 4.5x
Storage
USB Devices
Graphics
Number of adapters 1
Graphic APIs
API ATI I/O
Display Adapters
Display adapter 0
Name XPERT 98 RXL AGP 2X
Board Manufacturer Advanced Micro Devices Inc. (AMD)
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1002)
Model ID 0x474D (0x0008)
Performance Level 0
Monitor 0
Model ()
ID ATC0000
Serial 00000000
Manufacturing Date Week 0, Year 2005
Size 14.3 inches
Max Resolution 0 x 0 @ 0 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 1.5
Software
Windows Version Microsoft Windows 98 SE
DirectX Version 9.0c
ACPI
ACPI Tree
Register Spaces
Register space PCI
Register space PCI #2
Register space SMBus, base address = 0x06000
Reply 1 of 10, by TechieDude
Sorry for bumping, but do you still have it?
EDIT: Sorry, just now realised that Yushatak hasn't been active since May of 2018, my bad.
Reply 2 of 10, by Yushatak
Nah it's good I always exist, I do still have this box.
What'd you want to know about it?
Reply 3 of 10, by ragefury32
Yushatak wrote on 2020-04-08, 22:48:
What socket is that Tilamook? I can't tell whether it's MMC1 or Socket 615, how did you manage to get a socket adapter for it?
Reply 4 of 10, by Yushatak
Socket 7, someone already made the adapter, it was a surface mounted chip originally and if I recall the adapter is kinda permanently part of it now. There was apparently a period of time where people in China were taking unused SMC chips and converting them to desktop packages, or so I heard around the time I purchased it.
If memory serves it it looks very much like this but with a built-in adapter (note I mean this picture specifically, not the others that show the full board it was mounted to):
http://www.cpu-collection.de/?l0=i&i=2408
It's been several years since I had the CPU out of it, though.
Reply 6 of 10, by H3nrik V!
Yushatak wrote on 2020-04-08, 23:39:
Socket 7, someone already made the adapter, it was a surface mounted chip originally and if I recall the adapter is kinda perman […]
That top picture looks pretty much like a close-up of the left bottom picture?
Reply 7 of 10, by Nvm1
I have one of those too, I even posted a picture of it once here on vogons.
Didn't have the chance to test the cpu other then it booted on a S7 motherboard.
I hope when life is a bit more normal again here that I then try it on several motherboards and see what is possible!
Reply 8 of 10, by ragefury32
Ah yeah, that makes sense. The entire MMC1/2 module was one of those "what were they thinking" ideas - package a CPU (okay), the cache (hmmm) and the Northbridge chip (wha...) together in a single module. Makes for some weird setups, like swapping from a Tillamook MMX to a 440ZX based PII module/Dixon will result in a laptop with EDO RAM...which is odd. I am not surprised if someone lift the CPU off the MMC1 package and added it into a socket 7 adapter - Intel certainly did it for their embedded Pentium MMX line (look up SL27S/SL2Z4 for examples of Tillamooks on Socket 7). Nice machine for Win98 stuff - makes me wish I have a Socket 7 machine that I can mess with....HMMMMMM. Maybe the K6-3+ inside my Cobalt Qube 3 can come out.
Reply 9 of 10, by TechieDude
I wanted to know how you got the L2 cache to work with it, and what the adapter looks like.
Spoiler
I also didn't know that you don't get automatically notified of new posts on a thread where you have posted.
EDIT: I also expected it to be one of those Socket 7 Tillamooks, not that weird thing. Fascinating.
Reply 10 of 10, by Yushatak
ragefury32 wrote on 2020-04-09, 18:37:
Yeah I put this in a box that supports up to a K6-III+ but I built it around this CPU to maximize it's abilities. I have a Voodoo2 chained to.. something - it's been too long since I used the box. Runs great, though.
Anonymous Coward wrote on 2020-04-09, 00:18:
Is the multiplier on your chip unlocked?
I do not recall, though I seem to remember the multipliers being all determined by the board as far as what I messed with. If you can tell me how to verify this I will pull the box and do so at the earliest convenience.
TechieDude wrote on 2020-04-10, 23:42:
I didn't do anything special to make that work, as far as I recall, it's possible the board provided L2? I dunno. I can get pics of the package at some point but it sounds like someone else posted pics of the same chip on here at some point (and I'd rather not take the cooler off because I'm sure I used heat compound for the mild OC and have only mediocre heat compound around at the moment).
