First post, by Yushatak
 - Member
Others have expressed interest in this box of mine as I've mentioned it in other threads, so I figured I'd start a thread to discuss it. The CPU in this box is quite unique, a custom remounted laptop Tillamook 266 MMX on a desktop adapter of some kind that I found in 2010-11 or so (there was only one available at the time IIRC, or Id've bought more).
Since it's a laptop chip and wasn't designed to even have cooling AFAIK (and even if it was, it definitely can have a more effective cooler in a desktop) and it's lower voltage, so it generates less heat to start with. I overclocked it to 300Mhz since I could. It's set up at 66Mhz*4.5=297Mhz.
To my knowledge the cache is perfectly intact (someone said something about Tillamooks in desktops disabling the cache) and it's got 16KB L1 Data, 16KB L1 Inst. (are these the same or is it 32KB total?), and 1MB L2. Pretty respectable IMO!
I ran the benchmark "just because" and got 11 for single thread, and 9 for multi-thread. If anyone wants me to run a specific benchmark for comparison to similar boxen (a desktop chip at 300Mhz or 266 or what-have-you perhaps?) just let me know and I will do so.
While I have other enthusiasts looking at this, let me know if you spot anything wrong/bad/etc. that I may have overlooked. I must say I was very appreciative to see the people who maintain CPU-Z have a dedicated Windows 98 version. :3 Speaking of which, the box is running 98SE with no extra updates or anything because I've had bad luck with SP3 and 98SE2ME being unstable in the past. I plan to back up the windows folder and boot files and test combinations of them for stability once I have more software installed to use to test with (input appreciated).
Here's the specs of my baby:
CPU-Z TXT Report-------------------------------------------------------------------------Binaries-------------------------------------------------------------------------CPU-Z version 1.76.0.x32Processors-------------------------------------------------------------------------Number of processors 1Number of threads 1APICs-------------------------------------------------------------------------Processor 0-- Core 0-- Thread 0 0Timers-------------------------------------------------------------------------Perf timer 1.193 MHzSys timer 1.000 KHzProcessors Information-------------------------------------------------------------------------Processor 1 ID = 0Number of cores 1 (max 1)Number of threads 1 (max 1)Name Intel Mobile Pentium MMXCodenameSpecificationPackage TCP MobileCPUID 5.8.1Extended CPUID 5.8Core Stepping MYA0Technology 0.25 umCore Speed 297.0 MHzMultiplier x Bus Speed 4.5 x 66.0 MHzInstructions sets MMXL1 Data cache 16 KBytes, 4-way set associative, 32-byte line sizeL1 Instruction cache 16 KBytes, 4-way set associative, 32-byte line sizeFID/VID Control noThread dumps-------------------------------------------------------------------------CPU Thread 0APIC ID 0Topology Processor ID 0, Core ID 0, Thread ID 0Type 01000402hMax CPUID level 00000001h
Cache descriptor Level 1, I, 16 KB, 1 thread(s)Cache descriptor Level 1, D, 16 KB, 1 thread(s)CPUID0x00000000 0x00000001 0x756E6547 0x6C65746E 0x49656E690x00000001 0x00000581 0x00000000 0x00000000 0x008001BFChipset-------------------------------------------------------------------------Northbridge VIA Apollo VP3 rev. 04Southbridge VIA VT82C586 rev. 41Graphic Interface AGPAGP Revision 1.0AGP Transfer Rate 2xAGP SBA supported, enabledOn Board Cache 1024 KBytesMemory Type SDRAMMemory Size 512 MBytesMemory Frequency 66.0 MHz (1:1)CAS# latency (CL) 3.0RAS# to CAS# delay (tRCD) 3RAS# Precharge (tRP) 3Cycle Time (tRAS) 6Memory SPD-------------------------------------------------------------------------Monitoring-------------------------------------------------------------------------Mainboard Model VA-503+ (0x00000187 - 0x005A768B)LPCIO-------------------------------------------------------------------------Hardware Monitors-------------------------------------------------------------------------PCI Devices-------------------------------------------------------------------------Description Host BridgeLocation bus 0 (0x00), device 0 (0x00), function 0 (0x00)Common headerVendor ID 0x1106Model ID 0x0597Revision ID 0x04PI 0x00SubClass 0x00BaseClass 0x06Cache Line 0x00Latency 0x10Header 0x00PCI headerAddress 0 (memory) 0xE0000000Subvendor ID 0x0000Subsystem ID 0x0000Int. Line 0x00Int. Pin 0x00PCI capabilityCaps class AGPCaps offset 0xA0Caps version 1.0Caps status enabledTransfer rate 2x (max 2x)Queue length 1 (max 8)PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 06 11 97 05 06 00 90 82 04 00 00 06 00 10 00 0010 08 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 80 8A 85 F0 00 00 00 00 98 00 10 20 30 40 40 4060 0F AA C0 23 E4 E4 04 00 00 00 40 01 60 67 00 0070 E1 8A EC 00 00 80 40 00 00 00 00 00 00 00 80 4080 0F 41 00 00 E0 00 00 00 07 00 FC 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 02 00 10 00 03 02 00 07 02 03 00 00 0E 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 97 05Description PCI to PCI BridgeLocation bus 0 (0x00), device 1 (0x01), function 0 (0x00)Common headerVendor ID 0x1106Model ID 0x8598Revision ID 0x00PI 0x00SubClass 0x04BaseClass 0x06Cache Line 0x00Latency 0x00Header 0x01PCI headerPrimary bus 0x00Secondary bus 0x01Int. Line 0x00Int. Pin 0x00PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 06 11 98 85 07 00 20 22 00 00 04 06 00 00 01 0010 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 0020 00 D8 F0 DF 00 A8 F0 AF 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 0040 70 6C 50 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description PCI to ISA BridgeLocation bus 0 (0x00), device 7 (0x07), function 0 (0x00)Common headerVendor ID 0x1106Model ID 0x0586Revision ID 0x41PI 0x00SubClass 0x01BaseClass 0x06Cache Line 0x00Latency 0x00Header 0x80PCI headerSubvendor ID 0x0000Subsystem ID 0x0000Int. Line 0x00Int. Pin 0x00PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 06 11 86 05 8F 00 00 02 41 00 01 06 00 00 80 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 05 00 00 01 00 10 A0 21 00 C4 00 00 00 00 F350 24 00 00 00 00 00 49 A0 00 06 F7 00 10 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description IDE ControllerLocation bus 0 (0x00), device 7 (0x07), function 1 (0x01)Common headerVendor ID 0x1106Model ID 0x0571Revision ID 0x06PI 0x8ASubClass 0x01BaseClass 0x01Cache Line 0x00Latency 0x40Header 0x00PCI headerAddress 4 (port) 0x00006400Subvendor ID 0x0000Subsystem ID 0x0000Int. Line 0x0FInt. Pin 0x00PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 06 11 71 05 07 00 80 02 06 8A 01 01 00 40 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 01 64 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 00 0040 0B E2 09 3A 69 00 C0 00 A8 A8 A8 A8 FF 00 FF FF50 03 03 03 03 00 00 00 00 A8 A8 A8 A8 00 00 00 0060 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 0070 02 00 00 00 00 00 00 00 82 00 00 00 00 00 00 0080 14 DA FE 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 06 00 71 05 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description USB Controller (UHCI)Location bus 0 (0x00), device 7 (0x07), function 2 (0x02)Common headerVendor ID 0x1106Model ID 0x3038Revision ID 0x02PI 0x00SubClass 0x03BaseClass 0x0CCache Line 0x08Latency 0x40Header 0x00PCI headerAddress 4 (port) 0x00006800Subvendor ID 0x0925Subsystem ID 0x1234Int. Line 0x0BInt. Pin 0x04PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 06 11 38 30 07 00 00 02 02 00 03 0C 08 40 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 01 68 00 00 00 00 00 00 00 00 00 00 25 09 34 1230 00 00 00 00 00 00 00 00 00 00 00 00 0B 04 00 0040 00 00 00 00 C2 00 20 04 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description Bridge deviceLocation bus 0 (0x00), device 7 (0x07), function 3 (0x03)Common headerVendor ID 0x1106Model ID 0x3040Revision ID 0x10PI 0x00SubClass 0x80BaseClass 0x06Cache Line 0x00Latency 0x00Header 0x00PCI headerSubvendor ID 0x0000Subsystem ID 0x0000Int. Line 0x00Int. Pin 0x00PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 06 11 40 30 00 00 80 02 10 00 80 06 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 40 88 00 00 78 B8 00 00 01 60 00 00 00 00 00 0050 00 FF 7F 88 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description Video deviceLocation bus 0 (0x00), device 8 (0x08), function 0 (0x00)Common headerVendor ID 0x121AModel ID 0x0002Revision ID 0x02PI 0x00SubClass 0x00BaseClass 0x04Cache Line 0x00Latency 0x00Header 0x00PCI headerAddress 0 (memory) 0xE2000000Subvendor ID 0x0000Subsystem ID 0x0000Int. Line 0xFFInt. Pin 0x00PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 1A 12 02 00 02 00 80 00 02 00 00 04 00 00 00 0010 08 00 00 E2 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 0040 03 40 01 00 00 00 00 00 00 00 00 00 7F F0 FF 0F50 00 00 00 00 F9 12 00 30 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description Mass storage ControllerLocation bus 0 (0x00), device 9 (0x09), function 0 (0x00)Common headerVendor ID 0x105AModel ID 0x4D69Revision ID 0x02PI 0x85SubClass 0x80BaseClass 0x01Cache Line 0x08Latency 0x40Header 0x00PCI headerAddress 0 (port) 0x00006C00Address 1 (port) 0x00007000Address 2 (port) 0x00007400Address 3 (port) 0x00007800Address 4 (port) 0x00007C00Address 5 (memory) 0xE3000000Subvendor ID 0x105ASubsystem ID 0x4D68Int. Line 0x09Int. Pin 0x01PCI capabilityCaps class Power ManagementCaps offset 0x60Caps version 1.0PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 5A 10 69 4D 07 00 30 04 02 85 80 01 08 40 00 0010 01 6C 00 00 01 70 00 00 01 74 00 00 01 78 00 0020 01 7C 00 00 00 00 00 E3 00 00 00 00 5A 10 68 4D30 00 00 00 00 60 00 00 00 00 00 00 00 09 01 04 1240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 01 00 21 02 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description Network ControllerLocation bus 0 (0x00), device 10 (0x0A), function 0 (0x00)Common headerVendor ID 0x14B9Model ID 0x0350Revision ID 0x01PI 0x00SubClass 0x80BaseClass 0x02Cache Line 0x08Latency 0x00Header 0x00PCI headerAddress 0 (memory) 0xE3004000Address 1 (port) 0x00008000Address 2 (port) 0x00008400Subvendor ID 0x0000Subsystem ID 0x0000Int. Line 0x0AInt. Pin 0x01PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 B9 14 50 03 03 00 80 82 01 00 80 02 08 00 00 0010 00 40 00 E3 01 80 00 00 01 84 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 0A 01 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Description VGA ControllerLocation bus 1 (0x01), device 0 (0x00), function 0 (0x00)Common headerVendor ID 0x1002Model ID 0x474DRevision ID 0x65PI 0x00SubClass 0x00BaseClass 0x03Cache Line 0x08Latency 0x40Header 0x00PCI headerAddress 0 (memory) 0xD8000000Address 1 (port) 0x0000E000Address 2 (memory) 0xD9000000Subvendor ID 0x1002Subsystem ID 0x0008Int. Line 0x04Int. Pin 0x01PCI capabilityCaps class AGPCaps offset 0x50Caps version 1.0Caps status enabledTransfer rate 2x (max 2x)Queue length 1 (max 256)PCI capabilityCaps class Power ManagementCaps offset 0x5CCaps version 1.0PCI registers00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F00 02 10 4D 47 87 00 90 02 65 00 00 03 08 40 00 0010 00 00 00 D8 01 E0 00 00 00 00 00 D9 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 02 10 08 0030 00 00 00 00 50 00 00 00 00 00 00 00 04 01 08 0040 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 02 5C 10 00 03 02 00 FF 02 03 00 07 01 00 01 0660 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00DMI-------------------------------------------------------------------------DMI BIOSvendor Award Software International Inc.version 4.51 PGdate 07/20/98ROM size 128 KBDMI System Informationmanufacturer System Manufacturerproduct Product Nameversion SYS-xxxxxxserial Serial number xxxxxxUUID {74737953-6D65-4D20-616E-756661637475}SKU unknownfamily unknownDMI Baseboardvendor First International Computer Inc.model VA-503+revision PCB 1.Xserial Serial number xxxxxxDMI System Enclosuremanufacturer Manufactory Namechassis type Desktopchassis serial Serial number xxxxxxDMI Memory Controllercorrection unknownMax module size 256 MBytesDMI Memory Moduledesignation DIMM1size 256 MBytes (double bank)DMI Memory Moduledesignation DIMM2size 256 MBytes (double bank)DMI Memory Moduledesignation SIMM1DMI Memory Moduledesignation SIMM2DMI Memory Moduledesignation SIMM3DMI Memory Moduledesignation SIMM4DMI Port Connectordesignation PRIMARY IDE (internal)connector On Board IDEDMI Port Connectordesignation SECONDARY IDE (internal)connector On Board IDEDMI Port Connectordesignation FDD (internal)port type 8251 FIFO Compatibleconnector On Board FloppyDMI Port Connectordesignation COM1 (internal)port type Serial Port 16450connector 9 Pin Dual Inline (pin 10 cut)connector DB-9 maleDMI Port Connectordesignation COM2 (internal)port type Serial Port 16450connector 9 Pin Dual Inline (pin 10 cut)connector DB-9 maleDMI Port Connectordesignation LPT1 (internal)port type Parallel Port ECP/EPPconnector 25 Pin Dual Inline (pin 26 cut)connector DB-25 femaleDMI Port Connectordesignation PS2_KB (internal)port type Keyboard Portconnector Mini DINDMI Extension Slotdesignation ISAtype ISAwidth 16 bitsDMI Extension Slotdesignation ISAtype ISAwidth 16 bitsDMI Extension Slotdesignation ISAtype ISAwidth 16 bitsDMI Extension Slotdesignation PCItype PCIwidth 32 bitspopulated yesDMI Extension Slotdesignation PCItype PCIwidth 32 bitspopulated noDMI Extension Slotdesignation PCItype PCIwidth 32 bitspopulated noDMI Processormanufacturer Intelmodel Pentium-MMXclock speed 300.0 MHzFSB speed 66.0 MHzmultiplier 4.5xStorage-------------------------------------------------------------------------USB Devices-------------------------------------------------------------------------Graphics-------------------------------------------------------------------------Number of adapters 1Graphic APIs-------------------------------------------------------------------------API ATI I/ODisplay Adapters-------------------------------------------------------------------------Display adapter 0Name XPERT 98 RXL AGP 2XBoard Manufacturer Advanced Micro Devices Inc. (AMD)PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)Vendor ID 0x1002 (0x1002)Model ID 0x474D (0x0008)Performance Level 0Monitor 0Model ()ID ATC0000Serial 00000000Manufacturing Date Week 0, Year 2005Size 14.3 inchesMax Resolution 0 x 0 @ 0 HzHorizontal Freq. Range 0-0 kHzVertical Freq. Range 0-0 HzMax Pixel Clock 0 MHzGamma Factor 1.5Software-------------------------------------------------------------------------Windows Version Microsoft Windows 98 SEDirectX Version 9.0cACPI-------------------------------------------------------------------------ACPI TreeRegister Spaces-------------------------------------------------------------------------Register space PCIRegister space PCI #2Register space SMBus, base address = 0x06000
