Reply 320 of 416, by Deksor
Truly if we could have that working from the get go, we would have added it by now. The current situation is a quick and dirty "fix" that tends to last a bit too long ...
Also thanks for the support. I actually thought of renting something, but the issue is that they cost quite a bit here, I'm not sure they're safe, and more importantly I don't have any car and don't have a use for it. Getting one just for temporarily would be a bit too much and renting one too.
And the bigger problem is time. I can only be there on weekends so I'm really limited to what I can and can't do
Reply 321 of 416, by appiah4
I came across this board and bought it. It is visually 100% identical to PCPartner ABPS3-C861 (https://theretroweb.com/motherboards/s/pcpart … 1-35-c861-01-xx) right down to silkscreen markings. However, going by the stickers on the ISA slot it is branded ASKA SST-5830, so that is another brand/model you may want to add.
It also seems to come with a different BIOS for the ITE IO controller than the ones on the site. I can upload it tonight if you want.
Reply 322 of 416, by mR_Slug
added name.
With regard to the user submission system. We are going to have to be very careful about how we implement this. First the motherboard editor has some quirks, it may be difficult to use. And we need to have a clear system for whats been changed. I think this will be slow to develop. But we are planning it.
There do seem to be so many things on the to do list, and this is not #1 right now.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 323 of 416, by rasz_pl
https://theretroweb.com/motherboards/s/dell-s … 6-xx-mdt-rev.-2
good picture No video, but code from mystery 486 board
https://theretroweb.com/motherboards/s/itt-co … ional-series-40
pictures and manual scans Re: WD1003-WAH compatibility with 12.5mhz systems?
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 324 of 416, by noshutdown
this site is very helpful, but in recent days its extremely slow to access, can you check it out?
Reply 327 of 416, by noshutdown
Deksor wrote on 2023-01-06, 09:07:
I haven't experienced any slowdowns, have you tried other computers/outside of your home ?
yes, i tried several different computers/cellphones and internet service providers, in my home and office, and they are all very difficult to open. could it be that i am in china?
but it used to be fast about a week before...
Reply 328 of 416, by Deksor
1541 wrote on 2023-01-06, 10:07:
Only the blog site does not seem to be reachable: https://downforeveryoneorjustme.com/blog.ther … com?proto=https
That's interesting because it was live when I posted my previous message 😅
As for the slowdowns, maybe it's indeed because you're in China.
I'll see if things can be improved
Reply 329 of 416, by badmojo
Working fine here too.
What a great site 👍👍
Reply 330 of 416, by noshutdown
great, my access to the site has returned to normal today.
Reply 332 of 416, by PC Hoarder Patrol
If you search on a partial board name, is it the intended action that if you then click on a picture for a specific board rather than its page link that you can cycle thru pictures for all boards that matched the partial search, rather than just those for the board on which you clicked...or is it just me!!!
Reply 333 of 416, by Doornkaat
Don't know if this is a known problem, sorry if I'm repeating stuff that's already been reported:
The search function appears faulty. I get no or very few results when searching for known combinations.
i.e. searching for any Intel chipset only gives 22 results total.
Reply 334 of 416, by zago27
There may be a weird bug where going back in browser history from the search results causes the search filters to not be cleared correctly.
Try hitting the Reset button before applying the chipset brand filter.
Your friendly neighborhood hardware database and blog, The Retro Web
Reply 335 of 416, by Boohyaka
Congratulations on becoming my goto source! Amazing work guys. I've contributed what I could and will continue doing so 😉
Reply 336 of 416, by Doornkaat
zago27 wrote on 2023-03-02, 09:38:
Oh yeah, it's probably got something to do with this. Reset button doesn't help though, I need to clear my browser chronic and start over from the index page for search to work correctly.🤔
Reply 337 of 416, by douglar
Boohyaka wrote on 2023-03-02, 11:21:
Along with the quality of data, the site performance has really improved too. It's a pleasure to use.
Reply 338 of 416, by rasz_pl
Add YEAR/DATE to the database indicating when product entered market or 'earliest documented example' would be great.
Add some way for 'Expansion slots' to not be required to remember exact number of slots. For example clicking "8-bit ISA" would fill the input box with "x", or even better possibility of requesting range so instead of "x" you could enter ">0" or "1-2" or "<3".
Add ram slots to the database to allow searching for dip/sipp/simm30/simm72/dimm/etc and by number of slots. Of course at first it will be unpopulated, but with time people can fill the data while fixing other things, or maybe even automatically by using computer vision.
While playing with this idea I discovered some errors in the database
https://theretroweb.com/motherboards/s/gigaby … e-ga-ep45-ud3lr
https://theretroweb.com/motherboards/s/abit-ab-st6-raid
both list "2x PS/2 mouse", have one
https://theretroweb.com/motherboards/s/abit-aa8xe
"2x Toslink", has one http://ixbtlabs.com/articles2/mainboard/abit- … 8xe-i925xe.html http://www.ixbt.com/mainboard/abit/abit-fatal … xe-sound-sm.jpg
https://theretroweb.com/motherboards/s/pcchips-m821lr
"2x Floppy interface", has one
Reply 339 of 416, by BitWrangler
I dunno if that "2x floppy interface" is confusion creeping in from things that happened later but ended up causing questions about the past, like ATA was just ATA until serial came out and now it was PATA, (I can't find PATA port labelled in 486 manual! etc). In that from 1981 into early noughts a single floppy interface was guaranteed to support 2 drives, until P4s and later boards came out with a grudging single drive only supported in BIOS floppy interface (That can probably be persuaded to see another drive with workarounds in DOS) So that maybe gets people wanting to label floppy interfaces with the number of drives the BIOS supports on them.
