First post, by dosfriend
My 5x86 133 machine was working great and stable until I've decided to give the talkie version of Day of the tentacle a try.
It will freeze randomly at some point while playing but the music will continue playing until I reboot. Maybe is sound related because it seems that if I disable speech the freeze doesn't happen. I am using a CT1600.
Tried to disable CPU cache without any improvement. There were 2 patches for the game on Lucas FTP but they don't fix this issue. Also copied the CD monster.sou to HD but it doesn't matter from where I run it, will freeze while playing the intro or game.
Other Lucas talkies work fine on this machine, like Sam&max, Atlantis or unofficial talkie Monkey 1 & 2.
I am out of ideas about what could be causing this and will appreciate any comments 😀
Reply 2 of 8, by kanecvr
It's EMS related. I had the NOEMS parameter set up for EMM386 (in config.sys). Removing it solved the problem. My version of the game also warns me "EMS memory under 2mb".
Reply 3 of 8, by dosfriend
Thanks for your reply 😀
Have EMS memory enabled but just tried with NOEMS parameter. It certainly needs EMS because it complains with the message you pointed out. I am running DOS 7 with EMM386 & HIMEM.
Crashes with EMS and without, as long as I keep the speech enabled.
Reply 4 of 8, by elianda
DoTT seems to access IRQ 7 independently of what you have set. I had the effect that when I had a Soundblaster at IRQ 5 and GUS at 7 the game froze. When I left the GUS uninitialized then it worked fine. DoTT setup was se to IRQ 5...
Youtube Channel
Reply 5 of 8, by dosfriend
You are right, DOTT seems to access IRQ 7 somehow even if it's set to 5 on setup or by command argument.
Even leaving GUS uninitialized the freeze will come sooner or later in the game 🙁
Reply 6 of 8, by keenmaster486
Is there a way to temporarily redirect IRQ7 to something else that's harmless?
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 7 of 8, by elianda
Newer SBs and the GUS is software configurable, so IRQ can be changed on the fly...
Youtube Channel
Reply 8 of 8, by leolobato
I know this is an old post, but it's the first one on Google searching for DOTT freeze. The issue was the CTMOUSE version.
Because of this other thread (Monkey Island 1 Ultimate Talkie freezes during speech ), I've reverted to CTMOUSE 2.04A and the problem is now fixed.
