The quest for the perfect retro laptop: a saga
First post, by keenmaster486
It all started a few years ago when I wanted to play DOS games on the go.
I got a Toshiba T1950CT to start off. But what I didn't realize is that it didn't have a built-in sound card. Shoot! So that was out of the picture even though it was a great laptop to tinker with otherwise.
Then I found a Toshiba Satellite T460cdt. This was much better. Fully DOS compatible, good graphics, sound, Pentium MMX, etc. But I found that the build quality was severely lacking.
So I kept looking. On eBay I found a Thinkpad 385XD. This looked perfect, plus it had both the CD and floppy drive internal to the same unit. Great! But then I discovered the Neomagic craphics chip had terrible DOS compatibility.
The search went on and on.
Eventually my requirements expanded. I wanted not only to play DOS games, but do Windows 9x productivity things as well. And have internet connectivity to connect to all the things. Etc, etc.
It's been a bear of a task finding the perfect retro laptop.
Here are the laptops I've gone through so far, in roughly chronological order:
  • Toshiba T1950CT -- REJECTED (no built in sound card)
  • Toshiba Satellite T460CDT -- very good candidate but REJECTED (bad build quality, not great keyboard)
  • IBM Thinkpad 385XD -- tempting but REJECTED (rubbery palmrest, Neomagic video has bad DOS compatibility)
  • IBM Thinkpad A20m -- REJECTED (too large and heavy, ATI graphics have lackluster DOS compatibility, Crystal audio sounds terrible with FM synth, keyboard is mushy and not Thinkpad-like at all)
  • IBM Thinkpad 560X -- REJECTED (Neomagic video, no internal floppy or CD, sound card is on the fritz)
  • IBM Thinkpad 365CD -- REJECTED (Not enough RAM or CPU power to do late DOS stuff and Windows 9x, screen casing is broken in multiple places due to bad hinge engineering, CD drive is bad, no internal floppy)
  • IBM Thinkpad 600E -- REJECTED (Neomagic video, rather large and heavy)
  • IBM Thinkpad 760XL -- REJECTED (Password locked and destroyed EEPROM chip while attempting to remove, but also: CRAP keyboard. Unlike any other Thinkpad.)
[/list]
So now I am back to square one again.
I think, however, that I have figured one thing out: there is no perfect retro laptop that will fulfill ALL my needs all at once.
So I have split it into two. Here they are:
The DOS/Win31/Win95 laptop
This will be capable of the following:
  • Perfect or near-perfect DOS video/sound compatibility
  • Not too large or too thick, of course this is all by 90's standards. The 365CD for example was fine. The 385XD was too large for me due to being 3-spindle.
  • Minimum of original Pentium speeds, for everything up to mid-late DOS era, think Duke3D or DOOM as a maximum.
  • Great keyboard touch
  • Can run DOS but also Windows 95 for writing, internet browsing, etc.
  • Ability to connect to Internet, and run browsers like Netscape
The Late DOS / Windows 98 / 2000 / Linux experimentation laptop
  • DOS compatibility sufficient for late DOS era games that require lots of speed
  • Can run Windows 98 / 2000 for millennium-era Windows productivity and internet things
  • Can also run some type of Linux for experimentation
  • Connects to Internet and can run later browsers like RetroZilla well
  • Could also do things like play MPEG videos and DVDs
Accordingly I have purchased on eBay a Thinkpad 760XL, to assist me in fulfilling the first category.
I am thinking that the two laptops for these categories will be, respectively, the Thinkpad 760XL, and the Thinkpad 600E.
The 600E I have already upgraded with a faster CPU (PIII-500), max RAM (544 MB), PCMCIA WiFi card, and brand new battery cells. It will serve well as the ~2000 era laptop.
The 760XL has the following specs:
  • CPU: Pentium MMX 166
  • Video: Trident Cyber9385 (good DOS compatibility according to The Chart -- it's based on Trident Providia)
  • Sound: ES1688 (good DOS compatibility)
  • Max of 104 MB RAM (sufficient for up to Windows 95)
  • TFT LCD 800x600 screen
  • Ultrabay with floppy drive. Could put a CD drive in there too if I got one.
Hopefully I can finally converge on a good setup this way. It will be a lot of configuration and setting things up to get everything to work properly, but I expect it to be rewarding.
I'll document any further adventures in this thread.
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 1 of 701, by cde
keenmaster486 wrote:
[*]TFT LCD 800x600 screen
I'd be interested to know how the graphics card deals with stretching 320x200 to 800x600. In theory it could just triple the pixels vertically and scale 2.5x horizontally. However since I imagine the panel is 60 Hz there could be some issues with games that expect 70 Hz. OTOH if the card converts 320x200 to 720x400 first and then to 800x600 the result might not look very good.
Reply 2 of 701, by derSammler
Depends. Toshiba for example does only integer scaling unless you force "stretch image" in the BIOS. Then you always get a full-screen image, doing non-integer scaling and ignoring the aspect ratio (=very, very ugly).
Best panel resolution for DOS games is 640x480 (or 1280x960, which are rare and mostly too powerful already).
Reply 3 of 701, by Intel486dx33
Probably the IBM Thinkpad 750/755CD.
They made so many of these and they are pretty easy to find in good condition.
Easy to fix, upgrade and repair.
32mb ram max.
Has great driver support in DOS/Win3x/95/OS2.
Support for external display.
IBM provides all the drivers on there website.
https://thinkpads.com/support/Thinkpad-Driver … t/ddfm/380.html
Reply 4 of 701, by Anaxagoras
The Late DOS / Windows 98 / 2000 / Linux experimentation laptop […]
It's sounds like my laptop do.
It's like this Toshiba Satellite Pro 4600 but with 256MB and 60GB HD.
My computers
Reply 5 of 701, by dkarguth
I always loved the Compaq LTE Elite 5000 series. They are pentium laptops, and have a removable floppy drive that can be replaced with a cd-rom drive or a second battery. The hard disk is also very easily swapped.
They had built in sound, a large high-resolution screen, and pcmcia support for ethernet cards or wifi modems. I used to run windows 98 on mine with no performance issues.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 6 of 701, by Gered
320x200 to 800x600 nearest-neighbour scaling for 2D DOS games kind of ruins it for me honestly. And I quite dislike playing them at the non-scaled line-doubled 640x400 resolution, leaving large black borders (this is completely a personal preference, many other people may not mind this at all). For me the perfect DOS laptop would absolutely have to have a 640x480 display.
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 7 of 701, by keenmaster486
I know a lot of people strongly dislike the 320x200 --> 800x600 scaling. For me, it is not a big issue. Sometimes the scaler can mess things up scrolling-wise, though, which happens a lot with Neomagic cards. But not the Thinkpad 760XL, if various YouTube videos showing DOS gameplay are any measure.
Reply 8 of 701, by Gered
I don't really any complaints about the Neomagic cards honestly. There are some problem games for sure, but probably 95%+ of the DOS games I like to play look and play just fine on my 600X. The only complaint I have with that laptop is that pretty much any kind of dithering pattern looks like crap with it's scaling.
The 760XL is not bad, I think you'll be quite happy with it if you're fine with nearest-neighbour 800x600 scaling. I downgraded my 760ED from it's original 1024x768 display to a 800x600 one because the scaling on the higher-res display was absolutely atrocious. The 800x600 display panel and graphics card I ended up with (had to change them both) is basically the same as the one in a 760XL. It's probably my favourite 800x600 laptop display (still bothers me, but it bothers me the least 😜 ).
Toshiba 430CDT
Reply 9 of 701, by AlessandroB
I like to candidate my Acer Travelmate 517TE. It has all the ports you can imagine and has enough power for practically every 1990-1999 game, excluding those that require specific 3D acceleration given by external cards. The only flaw in my opinion is that the build quality is not comparable to that of IBM, but if you find a unit in excellent condition and treat it very well, I am sure that it will last a long time. You can install everithing between DOS to WinXP, i browse slowly but close to perfectly on the web today with it.
This is the spec:
http://users.libero.it/andrea-c/acer_travelmate_517te.htm
Reply 10 of 701, by Bondi
If scaling to 800x600 is acceptable, then my candidate for an ideal laptop is my Hitachi Visionbook. P233, ESS1879 sound chip, up to 128 Mb RAM, C&T65555 video, and all sorts of ports from that time. Very reliable and expandable. It can take second HDD or any stanard laptop IDE optical drive. It even has game port, but it's connector is on port replicator.
Scaling looks fine in most games. It runs all games (mostly late DOS games) I tried. It also runs Win98 fine and I played HL1 on it in 320x200 mode. It works fine with Margi PCMCIA DVD decoder, so I can even watch DVDs on it.
Downside is that these are quite rare and finding parts is tricky.
Among laptops that have 640x480 display my favourite is IBM Thinkpad 760LD.
PCMCIA Sound Cards chart
Reply 11 of 701, by matze79
I would recommend AST Ascentia P Series
Has SB16 Sound, Gameport and CD-ROM or Floppy but you need to swap as needed.
Co2 - for a endless Summer
Reply 12 of 701, by Violett'Blossom
It all started a few years ago when I wanted to play DOS games on the go. […]
My favourite laptop in this regard is Siemens PCD-4ND because :
It has very crisp 640x480 TFT panel
Integrated ESS688 audio chipset
486DX2 50MHz
Everything about it is perfectly serviceable,
has decent keyboard and has Industrial grade build quality ( I have dropped mine on concrete, just blew away the dust of top cover nothing happened to it) 😊
Retro gaming : Compaq Armada E500
Portable : MacBook Air 2012
Hackingtosh : I5 6500 8GB DDR4 RX480 8GB
Reply 13 of 701, by Violett'Blossom
486DX2 50MHz - Pentium-S 75
Reply 14 of 701, by bjwil1991
All of my DOS/Windows laptops have 800x600 resolution or 1024x768 from Pentium 90 to PIII-700.
Laptops I have:
1) Toshiba Satellite Pro 410CDT
Specs:
Intel Pentium 90
40MB RAM (8 on-board, 32MB RAM LIF installed)
1.44MB FDD
Had a 4x CD-ROM drive, but the laser was shot and waiting for a good, used one
2GB CF Card running Windows 95 Upgrade and MS-DOS 6.22
24x external parallel port CD-ROM drive
C&T CT65548 1MB Local Bus video (not so friendly with Duke3D as it states the card is not compatible, I wish I could find a Cirrus Logic CL-GD5428 video card as the card can be swapped)
11.3" TFT Active Matrix
ESS AudioDrive ES688 (great DOS compatibility and no drivers needed)
2) IBM ThinkPad 380D (TFT) aka, the good looking laptop from VT
Specs:
Intel Pentium 150
48MB RAM (16MB on-board, 32MB RAM installed)
12.1" 800x600 TFT Active Matrix (pulled from a $10 ThinkPad 380D, specs to follow)
Neomagic MagicGraph128ZV with 1.125MB (not that bad, but it could be better)
Crystal CS4236B (not bad, but not good for DOS)
1.35GB HDD
1.44MB FDD/4x CD-ROM drive on 1 bracket (CD-ROM drive doesn't eject because of the metal bracket that sits on top that's causing the drive to get pressed down on top)
Windows 98 Upgrade and HDD file system changed from FAT16 to FAT32
3Com EtherLink III PCMCIA card
3Com Megahertz 56K modem
3) IBM ThinkPad 380D (DSTN), aka, the fixer upper
Specs:
Intel Pentium 150
32MB RAM (16MB on-board, 16MB RAM installed)
12.1" 800x600 DSTN (swapped from the good looking ThinkPad 380D)
2.1GB HDD
1.44MB FDD (CD drive not present and some other key hardware is missing, including some screws)
Windows 98
4) HP Pavilion N3350
Specs:
AMD K6-2+ 550M
64MB SD-RAM
12.1" HPA display 800x600 (stretched and stays stretched, unable to find an applet to make it not stretch at startup)
Trident AGP shared RAM up to 8MB
USB 1.1 port
4.7GB HDD
Windows 98SE
DVD-ROM drive (pulled from an IBM ThinkPad R40, will get an actual drive)
1.44MB floppy drive
ESS Maestro-3 sound card and modem
CardBus 32-bit (only 1 card can be installed)
5) Compaq Armada M700
Specs:
Intel Pentium III 700
128MB SD-RAM
ATI Rage AGP
12GB or so HDD
DVD-ROM drive
14.1" TFT display 1024x768 (video display software can disable stretching after Windows 98SE boots up)
CardBus 32-bit (accepts two CardBus/PCMCIA (Type II) cards or 1 CardBus/PCMCIA (Type III) card)
ESS Maestro-2E sound card
Intel Pro 100 Mini-PCI NIC
WInModem 56K v.90
Windows 98SE
Used as a dial-up server using WinRoute Pro 4.1.26 and the Dial-up server application to allow connections from the client PC
Reply 15 of 701, by keenmaster486
Thanks for the input, guys!
Yesterday, just for fun, I finished setting up the Thinkpad 560X to dual boot MS-DOS/WFW311 and Windows NT 4.0. This is not my ideal setup, and this laptop has the Neomagic video and a sound chip on the fritz, but it's cool and fun to play around with NT4. I think the most use this laptop will get is in word processing, retro internet stuff, and terminal things, as I was able to get it connected to my home WiFi network through an Orinoco card.
Tomorrow the Thinkpad 760XL arrives. We will see how it fares.
Reply 16 of 701, by Bondi
I'm wondering how you did that. I could never connect mine. AFAIR it did not support some modern security protocol. What router are you using and what security standard?
Reply 17 of 701, by keenmaster486
You have to have a network that is either open (no security) or uses WEP instead of WPA/WPA2. There are no WiFi cards that support WPA/WPA2 in DOS, and only one or two of them support it in Windows 98.
I have a separate access point that is broadcasting a second, open network throughout my house. I am not too worried about security in this case because it is a residential neighborhood with nobody in the vicinity who might try to connect to it, and besides that it's too weak to get past my house anyway.
Reply 18 of 701, by bjwil1991
I have a Wireless G network card that supports WPA, but my Compaq Armada M700 won't connect to it, however, oddly enough, it connects to my wireless extender. It also depends on the channel for the wireless AP since some systems liked certain channels.
Reply 19 of 701, by keenmaster486
Could also be the difference between WPA and WPA2, or AES vs TKIP.
WPA2 requires hardware support. WPA can work on WEP-only cards with the right software/driver updates, although these were not available for Windows 98 usually.
