Dos 6 conventional memory tricks
Reply 260 of 267, by dr_st
Joseph_Joestar wrote on 2021-09-27, 07:29:
BTW, for testing purposes, I just reverted all of the tweaks that I added manually (including the EMM386 line listed previously) and let MEMMAKER.EXE work its magic on the unmodified AUTOEXEC.BAT and CONFIG.SYS. Surprisingly, it achieved an even better result, giving me 614 KB of free conventional memory. And this is without using any of those memory ranges and without HIGHSCAN.
I think I'm good with that and will likely keep this setup.
Could you share your current Config/Autoexec? I'm curious what exactly MemMaker did here. Others can learn from it too, I'm sure. 😀
Reply 261 of 267, by Joseph_Joestar
dr_st wrote on 2021-09-27, 08:05:
Sure thing. For reference, the files are from this rig running DOS 6.22 + Win 3.11. Note that I'm deliberately using the bloated Microsoft mouse driver v9 because of this issue with my BIOS, but MEMMAKER somehow manages to load it high.
AUTOEXEC.BAT
@ECHO OFF
SET SOUND16=C:\OPTI930
C:\OPTI930\sndinit /b
SET BLASTER=A220 I5 D1 H5 P300 E620 T6
SET SOUND=C:\SB16
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
LH /L:1,23024 C:\DOS\MSCDEX.EXE /E /D:OPTICAL /L:D
LH /L:0;1,25168 /S C:\DOS\MSM9\MOUSE.EXE
PROMPT $p$g
PATH C:\DOS;C:\DOS\BAT;C:\WINDOWS;C:\OPTI930
SET TEMP=C:\TEMP
SET DIRCMD=/A/O:GEN
SET SST_RGAMMA=1.0
SET SST_GGAMMA=1.0
SET SST_BGAMMA=1.0
SET SST_SCREENREFRESH=85
SET SST_FX_GLIDE_SWAPINTERVAL=0
SET SST_GRXCLK=50
CONFIG.SYS
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=40,0
FILES=60
DOS=UMB
LASTDRIVE=E
FCBS=4,0
SHELL=C:\DOS\COMMAND.COM /P /E:512
DEVICE=C:\OPTI930\cdsetup.sys /T:X
DEVICE=C:\CTCM\CTCM.EXE
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
DOS=HIGH
DEVICEHIGH /L:1,11360 =C:\DOS\VIDECDD.SYS /D:OPTICAL
STACKS=9,256
MEM.EXE /a /c /p
Modules using memory below 1 MB:
Name Total = Conventional + Upper Memory
MSDOS 17,213 (17K) 17,213 (17K) 0 (0K)
HIMEM 1,168 (1K) 1,168 (1K) 0 (0K)
EMM386 4,144 (4K) 4,144 (4K) 0 (0K)
COMMAND 3,184 (3K) 3,184 (3K) 0 (0K)
MOUSE 25,440 (25K) 272 (0K) 25,168 (25K)
SETVER 512 (1K) 0 (0K) 512 (1K)
VIDECDD 5,056 (5K) 0 (0K) 5,056 (5K)
MSCDEX 15,712 (15K) 0 (0K) 15,712 (15K)
Free 675,616 (660K) 629,008 (614K) 46,608 (46K)
Memory Summary:
Type of Memory Total = Used + Free
Conventional 655,360 26,352 629,008
Upper 93,056 46,448 46,608
Reserved 393,216 393,216 0
Extended (XMS)* 65,967,232 578,688 65,388,544
Press any key to continue . . .
Total memory 67,108,864 1,044,704 66,064,160
Total under 1 MB 748,416 72,800 675,616
Total Expanded (EMS) 33,947,648 (33,152K
Free Expanded (EMS)* 33,538,048 (32,752K
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 628,704 (614K)
Largest free upper memory block 46,400 (45K)
Available space in High Memory Area 928 (1K)
MS-DOS is resident in the high memory area.
PC#1: Pentium MMX 166 / Soyo SY-5BT / S3 Trio64V+ / Voodoo1 / OPTi 82C930 / AWE64
PC#2: Celeron 466 / Abit ZM6 / Voodoo3 / AWE64 Gold / YMF744 / SC-155
PC#3: AthlonXP 1700+ / Abit KT7A / GeForce4 / SBLive / ALS100
PC#4: Athlon64 3700+ / DFI LanParty / 9600GT / X-Fi Titanium
Reply 262 of 267, by dr_st
Joseph_Joestar wrote on 2021-09-27, 08:32:
Thanks! I was going to ask about that MOUSE thing. 😁
Comparing to my startup files over there, it seems like the difference with all these EMM386 switches only amounts to ~8K of UMBs on my system. I guess EMM's default heuristics do a pretty good job finding free UMBs, while MEMMAKER does a great job utilizing them. Your free UMBs are all in one 46K chunk, thanks to the /L /S switches. You could even fit SMARTDRV in there, and a few other goodies, like DOSKEY.
I see the main difference in free conventional memory is that on my setup, COMMAND and parts of DOS are loaded in the high memory, while on your system they are all loaded low according to MEM/C/P. Part of it is probably due to DOS 7 vs DOS 6 (DOS 7 can load more stuff HIGH by default), but maybe it also has to do with the relatively late positioning of DOS=HIGH in your CONFIG.SYS? I don't remember if it has any effect.
Reply 263 of 267, by Joseph_Joestar
dr_st wrote on 2021-09-27, 18:07:
I do use SMARTDRV on physical hard disks, but I don't see much benefit from it on a CF card, which is what my DOS 6.22 system is running on.
Originally, I had a single line with DOS=HIGH,UMB near the top of my CONFIG.SYS. For some reason, MEMMAKER split that into two lines and changed the position. I have no idea why.
Reply 264 of 267, by Rawit
I came here for memory tricks but ended up with a new mouse driver. The Microsoft mouse driver v9 fixes a few things on my Cyrix MediaGX1 system. I noticed with CuteMouse Windows wouldn't load and only version 2 gave me what I thought was OK performance. Apparently some delays in software (for example FastTracker 2 not keeping tempo) were caused by CuteMouse and are now solved!
YouTube
Reply 265 of 267, by Nemo1985
Rawit wrote on 2021-12-15, 08:25:
That's interesting, did you try to load windows without cutemouse? A boot menu with multiple voices it's the best thing.
Reply 267 of 267, by Nemo1985
Rawit wrote on 2021-12-15, 14:51:
Yes, I made a bat to unload CuteMouse on start of Windows 3.11 to circumvent this issue. With CuteMouse loaded it wouldn't start or would start without a mouse.
Sorry, I thought you were talking about windows 98.
I use cutemouse and windows 3.11 on my 486 build, but I haven't those issues.
