Reply 280 of 283, by imi
also not a SC55 but I guess this is still the best thread for it... I pulled this off a 486 board today
so yeah CR2032 lithium cells can definitely leak it's not just the SC55 ^^ this one was from toshiba.
155.7 KiB
Reply 281 of 283, by Erwin_Br
Ok guys, I'm going to open my SC55 as soon as I'm home.
2 questions:
1. Wouldn't the SC55 give a warning when the battery is low or gone? Thought I read something like that.
2. Will the SC55 operate fine without a battery? If so, I will leave it out altogether.
Thanks!
Reply 282 of 283, by keropi
Erwin_Br wrote on 2021-05-16, 15:11:
Ok guys, I'm going to open my SC55 as soon as I'm home. […]
2 questions:
Thanks!
- if you remove the battery you get a 1-sec message each boot that the battery is low
- it will work just fine for gaming reasons , I also did not put a battery back. but if you want it to hold some special setup/options for your studio to work with then obviously it will lose such settings. in a typical gaming system all that is irrelevant and the battery can be out with no issues
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
