Last Half of Darkness also mentions Sound Master support at some point - any chance it could work with this card ?
If so, that would be cool. The game uses Covox stuff for sound plackback, so maybe it could be patched also.
This simple DAC would also be an interesting addition/alternative to emulators such as PCem or DOSBox, IMHO,
where Sound Blaster support might be a bit too power hungry sometimes (Amiga port of DOSBox, perhaps ?).
In that case, if SB is disabled, it wouldn't conflict with its I/O ports, either.
Speaking of I/O ports, the Sound Master seems to use I/O addresses that won't conflict with LPTx so easily.
In some scenarios, like running Windows 3.x/4.x or using parallel port ethernet cards,
this DAC would come in handy. Maybe things like TEMU could be patched to support this one, too.
Imagine, the Soundman could then be used for AdLib AND Tandy 3-voice sound! 😁
