Reply 40 of 55, by matze79
I have a Euro PC which had failed logic ics, some are already replaced and socketed, but then it broke down again and i was to lazy to fix it again. It also has AVR based Clock Replacment and Flash Storage for Settings 😁 instead of Battery buffering.
Reply 41 of 55, by matze79
i have a Euro PC but it needs repair, if you don`t mind...
Reply 42 of 55, by Jo22
Last Half of Darkness also mentions Sound Master support at some point - any chance it could work with this card ?
If so, that would be cool. The game uses Covox stuff for sound plackback, so maybe it could be patched also.
This simple DAC would also be an interesting addition/alternative to emulators such as PCem or DOSBox, IMHO,
where Sound Blaster support might be a bit too power hungry sometimes (Amiga port of DOSBox, perhaps ?).
In that case, if SB is disabled, it wouldn't conflict with its I/O ports, either.
Speaking of I/O ports, the Sound Master seems to use I/O addresses that won't conflict with LPTx so easily.
In some scenarios, like running Windows 3.x/4.x or using parallel port ethernet cards,
this DAC would come in handy. Maybe things like TEMU could be patched to support this one, too.
Imagine, the Soundman could then be used for AdLib AND Tandy 3-voice sound! 😁
Reply 43 of 55, by matze79
just patch temu to output to port 300 hell 😀
but most games use 3 voice for music so you can choose 3 voice or adlib only hm
i have made similar circuit for testing and maybe i will add it to the 3 voice soundcard.. i need more isa slots my XT is running out of spare Slots 😒
Reply 44 of 55, by Jo22
Thansk for the feedback, I hoped so! 😀
Unfortunately, though, I have got no Soundman, so I had to ask.
Reply 45 of 55, by Fagear
I've tried to decode and simulate address decoder of Rainbow Arts Soundman from photos.
This card puts OPL2 on base addresses: 0x380, 0x388, 0x38E.
And 8-bit Non-DMA DAC on base addresses: 0x220, 0x221, 0x228, 0x229, 0x22E, 0x22F, 0x300, 0x301, 0x308, 0x309, 0x30E, 0x30F
And all of those ports are used at the same time.
It this correct or I'm misinterpreting something? Can anybody check?
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 46 of 55, by keropi
ok since I am the only one that has this thing atm I searched my notes better , turns out I wrote 22x 30x ranges not 220/300 ...
so just to be extra sure I did the tests again and found that all these addresses (0x220, 0x221, 0x228, 0x229, 0x22E, 0x22F, 0x300, 0x301, 0x308, 0x309, 0x30E, 0x30F) produce sound.
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 47 of 55, by matze79
Hey Keropi, does the Card come with any Floppy Discs ?
Reply 48 of 55, by keropi
matze79 wrote on 2020-04-30, 12:39:
nope, I just got the card and nothing more
Reply 50 of 55, by keropi
yes it does work as a dac I have heard some tunes when I was testing it 😁
Reply 51 of 55, by matze79
you can add it to bios table , then it should work as LPT1 Covox
debug
d 40:8
e 40:8 78 03 # example port 378h
q
Reply 52 of 55, by Grzyb
matze79 wrote on 2025-07-09, 18:53:
Good idea!
Not all programs will work this way, but some actually do look for LPT addresses in the BIOS data area.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 53 of 55, by digger
Grzyb wrote on 2025-07-09, 19:02:
Good idea!
Indeed. Just like with timing routines on newer and faster CPUs, broad compatibility comes down to proper programming versus sloppy and lazy programming.
A while back, I acquired an original Disney Sound Source. From what I've experienced with some testing, it works fine with well-written games, even on a 2016-era PC with a PCIe parallel port adapter, when I use a DOS tool like PRTADD to automatically register the parallel port's base address in the BDA.
That's how BIOS and OS hardware abstraction is supposed to work.
Any cutting of corners by accessing hardware directly *may* offer a slight performance benefit on slower systems at the time of the game's release, but only causes problems on newer hardware, further down the line.
And if done properly, hardware extraction should have neglible overhead, if any.
Thanks for the handy DEBUG hack, @matze79!
Reply 54 of 55, by Kordanor
Not sure if this is the same card. But just stumbled over this advert in my Might and Magic 3 Box, a game which was published by Softgold. And so there was advertisement in there for it's daughter company Rainbow Arts.
The card looks a bit different, but maybe thats an earlier version?
It's saying the Soundman is completely adlib compatible but can also support PC-SOUNDMAN, later it's saying it's also SOUND-MASTER compatible.
Also it's sold bundled with LOGICAL and ROCK'N'ROLL. So I thought maybe that's some programs which could be interesting for you to test.
So this comment is just in case you find anything useful in the ad for this discussion.
Reply 55 of 55, by Jo22
Kordanor wrote on 2025-08-13, 23:46:
Not sure if this is the same card. But just stumbled over this advert in my Might and Magic 3 Box, a game which was published by […]
Hi, thank you! 😀
I think the PC-Soundman is being supported by the sound engine used in the DOS version of the point&click game Telekommando II.
It appears as an entry in the sound setup, at very least. Maybe it supports the sound effects via that DAC, too?
Because, TK2 supports both Sound Blaster (sfx+fm) and AdLib (OPL2 aka YM3812).
