Reply 380 of 484, by matze79
Have you unpacked the Prince.exe before hexedit ?
Reply 381 of 484, by root42
matze79 wrote on 2020-03-04, 21:58:
I didn't. Are you sure it's packed? At the address there was a matching byte. Hence I would assume it was fine.
YouTube and Bonus
Reply 382 of 484, by matze79
its packed.
Reply 383 of 484, by root42
matze79 wrote on 2020-03-05, 12:52:
its packed.
Ok, now please tell me with what packer so I can try to unpack. 😁
But I wonder why it has the correct byte at the same offset...? I have little hopes the unpacking will help. But am welcoming suggestions! Or maybe someone has a working binary?
YouTube and Bonus
Reply 385 of 484, by root42
Didn't yet get around to investigate Prince, but tried Arkanoid 2:
https://www.youtube.com/watch?v=sTd8WbJxyQk
YouTube and Bonus
Reply 386 of 484, by matze79
Here is a Preview on Almost-Release Canidate R1.3,
The attachment aisler.jpg is no longer available
Full reroute, with some optimizations by dreamblaster in KiCad to allow machine assembly, and better hand assembly.
Reply 387 of 484, by root42
I tried Paku Paku on my sound devices. MT32, CMS and Adlib as well as PC Speaker (via TNDY) works fine. But I don't get anything on the /tandySound option.
https://youtu.be/HqA-KI7KKdc
Any ideas what I need to do for that?
YouTube and Bonus
Reply 389 of 484, by root42
That did the trick:
https://youtu.be/u9_LKmPQl2U
YouTube and Bonus
Reply 390 of 484, by matze79
Good! 😀
Reply 391 of 484, by JohnGrobler
Hi @matze79 awesome work on this Tandy ISA soundcard, any plans for releasing the PCB designs as open source in the future maybe?
Reply 392 of 484, by bjwil1991
Is there a sound off sys file somewhere out of curiosity or a way to load the sndoff program file in config.sys?
Reply 393 of 484, by matze79
https://www.retroianer.de/wordpress/index.php … ndy-soundkarte/
just add this tool to your Autoexec.bat!
@ JohnGrobler
Not yet, at some point later.
but there is some investment going on to make them avaible soon!
Professional assembled boards!
so you may be able to purchase at Serdashop.com soon! including Metal Slot Cover.
Reply 394 of 484, by matze79
The attachment protos.jpg is no longer available
The attachment modmaster_covox.jpg is no longer available
extended my Tandy Prototype Card with Covox DAC,
its highly configurable so i can almost choose any IO Adress i want.
This is Setting the ISA DAC to LPT1:
debug.exe:
d 40:8
e 40:8 78 03
q
78 03 -> 378
So programs asking BIOS for LPT will use the Card.
This program switchs LPT1 to LPT2 :
The attachment 1pr2a.zip is no longer available
Reply 395 of 484, by carlostex
Fantastic matze79!!
Reply 397 of 484, by matze79
https://youtu.be/FNMrrozIUrI
https://youtu.be/XJ0C90UMX14
Don`t be confused, its just plain DAC on ISA Bus.
i bascily have no idea now howto make DMA driven DAC.
As i also own no Tandy (yet)
And Dosbox Code did not really help me yet.
Small Steps 😀
Reply 398 of 484, by bjwil1991
Cool. Already have 2 sound cards with Covox Speech Things and Disney Sound Source on Aztech Sound Galaxy NC NX Pro cards (1 is non-16, and the other is 16 with Windows Sound System and WaveTable header).
Reply 399 of 484, by matze79
The attachment tracker.jpg is no longer available
Something weird is going on 😳
