Reply 20 of 32, by mothergoose729
Gona wrote on 2021-05-18, 21:14:Cloudschatze wrote on 2021-05-18, 20:40:Something is wrong with DSMI's SB16 detection routine in Aladdin. I can't speculate as to what. Here's a workaround config file though, concerning a SB16 configured with IRQ5 and high-DMA channel 5. (Byte 0x25 is the IRQ, and byte 0x26 is the DMA channel, if your SB16 is configured otherwise.)
Enjoy 16-bit @ 44.1kHz stereo output with your SB16, or something.
Wow! Great job!Aladdin_SB16_(patched_by_Cloudschatze)_-_on_-_SB16_CT2230_rev02.ogg
Is it also a detection problem when selecting SB Pro in Aladdin the SB16 works as mono?
That sounds great! Even a bit better than WSS I'd say... more filtered but without being muddy.
