tseng labs e3000
First post, by scroeffie
hi a friend has some color problems in some games and some the colors are perfect
he says its a driver problem or ulitily thing
he needs this utility disk (Of dmode.exe) voor de ET3000
the et4000 dmode does not work on the et3000 he already tried that
he also reburnt the bios etc
Reply 1 of 16, by Grzyb
ftp://ftp.oldskool.org/pub/drivers/TSENG/ET3000.ZIP
Reply 2 of 16, by scroeffie
how do i open the link ? when i click on it nothing happens
Reply 3 of 16, by kixs
You need a browser that supports FTP or some other dedicated FTP client. New browsers had dropped support for it some time ago 🙁
I've attached the drivers here:
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 4 of 16, by scroeffie
drivers worked for him thanks 😀
Reply 5 of 16, by _Rob
These files seems to be meant for the Orchid ProDesigner ET3000 card, but presumably will work on any ET3000.
Unfortunately it seems disk1 is missing from the ZIP file. Not sure either what it would have contained.
And these are not actual disk copies, but only the files with the original timestamps changed. But at least the original file metadata can still be partly seen in the included LABEL-* text files.
Disk2 contains Windows/386 2.11 drivers, and disk3 contains the DOS utilities to change video mode (VMODE.COM) and VGA font (FLOAD.COM/FEDIT.COM).
It does not include the VDIAG.COM, DMODE.COM, VANSI.SYS, HOTKEY.COM, HOTZOOM.COM or ROMDATE.COM utilities mentioned in the Puretek VGA Ultra ET3000 documentation.
https://archive.org/details/tseng-labs-et3000 … uretek-vgaultra
Are there any other ET3000 disk sets that have survived? Searching online, I only find Windows 3.0/3.1 driver disks.
Reply 6 of 16, by Grzyb
_Rob wrote on 2023-04-21, 12:41:
But it isn't missing...
$ unzip -t ET3000.ZIP
Archive: ET3000.ZIP
testing: ET3000/ OK
testing: ET3000/DISK1/ OK
testing: ET3000/DISK1/-------.--- OK
testing: ET3000/DISK1/------.--- OK
testing: ET3000/DISK1/ACAD_9.10 OK
testing: ET3000/DISK1/AUTOCAD.20 OK
testing: ET3000/DISK1/DSORCHID.EXE OK
testing: ET3000/DISK1/GEMSETUP.V22 OK
testing: ET3000/DISK1/GEMSETUP.V30 OK
testing: ET3000/DISK1/GEMSETUP.V31 OK
testing: ET3000/DISK1/GEM_VEN.XXX OK
testing: ET3000/DISK1/HOTKEY.EXE OK
testing: ET3000/DISK1/HOTZOOM.EXE OK
testing: ET3000/DISK1/LABEL-1 OK
testing: ET3000/DISK1/SD1024.SYS OK
testing: ET3000/DISK1/SD1024.VGA OK
testing: ET3000/DISK1/SD800.SYS OK
testing: ET3000/DISK1/SD800.VGA OK
testing: ET3000/DISK1/TINST1.EXE OK
testing: ET3000/DISK1/TPACK1.COM OK
testing: ET3000/DISK1/VP2_0.TXT OK
testing: ET3000/DISK1/VPDRV2_0.EXE OK
testing: ET3000/DISK2/ OK
Reply 7 of 16, by _Rob
Ok, indeed seems the zip file contains more. but...
$ unzip ET3000.ZIP
Archive: ET3000.ZIP
ET3000/: mismatching "local" filename (README.1ST),
continuing with "central" filename version
file #2: bad zipfile offset (local header sig): 37
file #3: bad zipfile offset (local header sig): 80
file #4: bad zipfile offset (local header sig): 137
file #5: bad zipfile offset (local header sig): 193
file #6: bad zipfile offset (local header sig): 248
file #7: bad zipfile offset (local header sig): 304
file #8: bad zipfile offset (local header sig): 12008
file #9: bad zipfile offset (local header sig): 15595
file #10: bad zipfile offset (local header sig): 18558
file #11: bad zipfile offset (local header sig): 21237
file #12: bad zipfile offset (local header sig): 21294
file #13: bad zipfile offset (local header sig): 22093
file #14: bad zipfile offset (local header sig): 30415
file #15: bad zipfile offset (local header sig): 30771
file #16: bad zipfile offset (local header sig): 56332
file #17: bad zipfile offset (local header sig): 81893
file #18: bad zipfile offset (local header sig): 107252
file #19: bad zipfile offset (local header sig): 132611
file #20: bad zipfile offset (local header sig): 142917
file #21: bad zipfile offset (local header sig): 148754
file #22: bad zipfile offset (local header sig): 149176
file #23: bad zipfile offset (local header sig): 156698
file #24: bad zipfile offset (local header sig): 156741
file #25: bad zipfile offset (local header sig): 156799
file #26: bad zipfile offset (local header sig): 156856
file #27: bad zipfile offset (local header sig): 156912
file #28: bad zipfile offset (local header sig): 156967
replace ET3000/DISK2/DVGA1024.GRB? [y]es, [n]o, [A]ll, [N]one, [r]ename: N
Seems my issue is with the ftp server, downloading the attachment instead works.
Reply 8 of 16, by _Rob
Disk1 contains Autocad 9/10, GEM 2.2/3.0/3.1, Ventura Publisher drivers and HOTKEY and HOTZOOM. No trace of the VDIAG utility.
Reply 9 of 16, by Kekkula
Does anyone have dmode.exe for et3000 or know where to get it?
Reply 10 of 16, by Jo22
Kekkula wrote on 2024-03-19, 17:25:
Hi, I'm not sure if you need an period-correct dmode from the 80s, but in case a recent dmode does suffice..
Re: Realtek realtalk, is it the best VGA for CGA? What is?
Edit: You can also try the attached zip file. It's from The GUI Gallery site. All credits goes there.
It has the driver/utility files of various old ISA VGAs, incl. ET-3000.
Fun fact, the ET3000 is old enough to have been known by East Germany's Robotron before fall of the Berlin wall. 😁
U80621: VGA Controller (Tseng Labs ET3000)
https://en.wikipedia.org/wiki/U80601
Reply 11 of 16, by Kekkula
Thanks for the files.
This is kind of unknown world to me. I had 286 back in the day as I was kid, but it was ega machine.
I'm trying to get this card to work with 286 and philips 7bm743 monitor in hercules mode... I'm not sure if that's even possible.
I don't know if I have to do something in dos 5 to change it to monochrome mode maybe?
I've tried to change the graphics card to monochrome mode, via dip switches and by jumper, but if I try to start a game in hercules mode I always get garbled screen, game runs I can hear sound.
Reply 12 of 16, by Jo22
Hi, you're welcome!
I'm not sure if I can give a good advice here, but ATI Wonder series had monitor auto-detection, I think.
So depending on what you're trying to do this might be worth a look.
There's ATI VGA Wonder, ATI Small Wonder (CGA, Plantronics and Hercules on different screens), ATI VIP (almost VGA) etc.
Be careful with sub-models, though. An ATI EGA Wonder and an ATI EGA Wonder + are two separate shoes, so to say.
An ATI VGA Wonder and Wonder 16, too.
You can als try to ask at vcfed.org, if users here don't have an idea. We're all just human, after all. Well, almost, ha. 😅
Reply 13 of 16, by DEAT
Kekkula wrote on 2024-03-27, 19:39:
Testing with my ET3000 card seems to be that the DB9 output is only capable of MDA and not Hercules, which is bizarre since it's capable of doing Hercules emulation through VGA.
win16.page | Twitch
Reply 14 of 16, by Kekkula
Thanks for the info.
I also think that my philips monitor is limited to only MDA... At least I couldn't get it to sync to my Euro Pc monochrome signal... Of course the Euro Pc graphics chip could also be bad, since I don't own another 9pin monitor I can't test that theory.
Reply 15 of 16, by Grzyb
Kekkula wrote on 2024-04-02, 06:34:
I don't think so.
Hercules Graphics Card was designed to use the MDA monitor.
Both MDA and Hercules output is 18 kHz HSYNC and 50 Hz VSYNC.
Well, there may be some slight differences - some cards use 16.000 MHz crystal, some use 16.257 MHz.
But it should be well within the tolerance of the monitor.
Reply 16 of 16, by Kekkula
Thanks.
I will check Euro Pc settings again now that it seems to be otherwise working.
