Reply 20 of 72, by SBLive
Standard Def Steve wrote on 2021-10-07, 16:48:This is why I shouldn't be reading Vogons on a highish DPI display set to 100% without my glasses. I read your title as Behold the VCR and was totally expecting to find a PIII rig stuffed into an Xbox One inspired black desktop case. 😜
I absolutely love it though. The LiveDrive, Plextor burner, case window and GeForce 3 is totally Cover of Maximum PC, Summer 2001 material. That machine is just begging you to play Max Payne on it.
🤣. Yeah, no VCRs here. And thank you, the aim of this and my other builds is to build the dream PCs I drooled over but could not afford back in the day. Plus, this machine actually gets some real, practical use - for example, it runs the software for my older EEPROM programmer that only works in XP and 2000, but nothing newer. I also run tons of old media tools and use it as a vintage DAW with FL Studio 4 and a hardware synth hooked up via MIDI. 😀
