Reply 80 of 194, by ericvids
I hope this is an okay double-post, because I'm posting a new version today:
Version 1.35 now adds mapping support in the modern-controls version of wolfdosmpu. You can now choose the behavior of the tab key to "disabled", "stats" (like in 1.32), "map (explored)" (automaps your exploration), and "map (full)" (unlocks the whole map and shows all secret locations).
Stats mode: (aka "I'm too cool for automap, but I don't want to miss any secrets before exiting" mode)
The attachment stats.png is no longer available
Automap: (aka "I like Doom" mode)
The attachment explored.png is no longer available
Full map: (aka "I'm still playing it like the 90's, except I have id's hint book" mode)
The attachment full.png is no longer available
If you're wondering about the ^ signs, that just means "plus more secrets/treasures that you can't access yet." I automatically exclude currently-inaccessible kills/secrets/treasures depending on what keys you have or what pushwalls you already pushed. This way, when anyone attempts E2M8's impossible pushwall maze, it is possible to "complete" it by simply exhausting all reachable secrets. (You still won't get a 100% stats screen in the end, but you can now sleep at night knowing that you did your absolute best.)
Version 1.35 also fixes a (somewhat well known) pushwall bug in id's code that prevents 100% completion on fast systems (pushwalls move three spaces instead of two). This bug is fixed on both modern-controls and MPU-only versions. (In general, I think the MPU-only version is pretty much stable and any updates would just be game-breaking bug fixes like this.)
Memory usage is slightly higher on the modern-controls version due to the new automap feature. (I tested all the way down to 568 KB of conventional memory free on DOSBox-X for SPEARCW.EXE; anything lower and SoD will refuse to run.) The good news is that saves still work across versions. 😀 You'll just lose the unlocked map areas when you save on the MPU-only version (i.e., when you reload it in the WASD version, everything's back in fog).
Reply 81 of 194, by Gmlb256
Nice to implement the pushwall bugfix, back then it was believed that this bug was map-related and several old mods assumed that the pushwall moved three spaces until it was discovered that this was caused by the pwallstate condition in WL_ACT1.C.
You could add a command line switch or an option for the pushwall if one wants to play maps compatible with vanilla and relies on this buggy behavior.
Reply 82 of 194, by ericvids
Gmlb256 wrote on 2021-10-09, 13:39:
Do you know what other "features" like this should be toggles? I'm actually quite surprised about the history of this pushwall bug. I fixed it assuming ECWolf's own behavior, without thinking that they are also breaking compatibility with some existing maps.
Off the top of my head, one of the "fixes" that people have divided opinions of is with the speed of Fake Hitler fireballs in E3M9. (Again, ECWolf just assumed what it should be: fast.)
Reply 83 of 194, by Gmlb256
ericvids wrote on 2021-10-09, 16:00:
Another "feature" I can name are the "holowalls" which places a dead guard or enemy inside a wall and allows interesting tricks if used well, but that one would not require a toggle switch unlike the pushwall. Most other "features" are related to enemy AI bugs, before attempting to fix them (which breaks compatibility with vanilla demos) you can try the "Temporary Insanity" map set on the DOS version Wolf3D as that one doesn't work on source ports.
ECWolf's pushwall behavior is the correct one but there is a mod to make the pushwall to move three spaces.
The fireball behavior is an interesting one, for some reason T_Projectile routine was used as an "action" routine instead of being a "think" routine like the others projectiles such as the rocket and syringe. The original behavior depended on framerate and in faster computers it was very easy to dodge.
Reply 84 of 194, by ericvids
Gmlb256 wrote on 2021-10-09, 16:32:
I cross-checked with ECWolf and their fix is essentially equivalent to reassigning the action routine to the think routine with no other changes, so I did exactly that.
Version 1.36 is now available, which adds your suggestion to make compatibility options as command-line parameters. "WOLF3DCM COMP 1" enables three-tile pushwalls (although I removed the nondeterminism that sometimes makes it two tiles). "WOLF3DCM COMP 2" reenables slow hitler fireballs. "WOLF3DCM COMP" just enables all the "features" and makes it work almost like WOLF3D.EXE. 😀
I also fixed one of my own bugs, which causes phantom secrets to appear in the map when you load a game. While I fixed that, I also noticed that the engine does not actually save changes to the secret tile marks. Normally there is no problem because the corresponding map tiles are now empty (which caused my own code to generate phantoms), but in case you push ANOTHER secret wall in its place, there's a possibility to save the game, reload it, and THAT wall is pushable again. I don't know if it meaningfully appears in any of the stock maps though.
Update: Version 1.37 improves item pickup, fixes more memory issues, now enforces a 568 KB minimum conventional memory requirement on normal start to avoid further memory problems (you can override this using goobers/debugmode), and updated Robert's Jukebox. I mean, the core of this mod is the improved music, so I *had* to update the jukebox, right? 😜
Reply 85 of 194, by carlostex
Great stuff, i always wished for any updated vanilla Wolf3D/Spear of Destiny for DOS with bugfixes and more period correct weapons, such as the Kar98k, MP40 and maybe even Panzerfaust 😃.
This is not that, but still great to see an improved version, thanks for the good work.
Reply 86 of 194, by ericvids
carlostex wrote on 2021-10-12, 07:57:
... and more period correct weapons, such as the Kar98k, MP40 and maybe even Panzerfaust 😃.
Ehehehe... I don't think I can make THAT kind of mod. 😉
I'm improving this mainly for the guys who want to play the original on DOS with period-correct MIDI modules. 😉
I've been playing my own work for the past few days, and I discovered some things:
1. The game crashes after calling cache-altering functions enough times. It has mostly to do with interaction between memory used by the sound manager and the Message() function (which is used by cheat codes and my automap code). Obviously we can't have crashes, so I fixed my own automap code to not cache ANY resource at all (including the stack that I use to floodfill the map to check connected areas). I didn't bother fixing the cheat codes (it's the price you pay, cheater 😉 -- okay, mostly because I don't want to spend much more time understanding id's cache system).
2. With that fixed, I was able to play through the entire Spear of Destiny without crashing, and I also tried completing Wolf3D episode 2 with maximum possible ratios (with the help of my mapping system of course). And of course there's the dreaded E2M8 maze. The result:
The attachment wolf3dcw_000.png is no longer available
The map isn't as bad as I thought it would be, it's just mindless pressing of pushwalls. The only part that can break is the one I'm showing on the screenshot. This is the decision point whether you want to get 100% kills, or to sacrifice 1 kill and 1 secret to gain 1 more treasure and to see the "Call Apogee, say Aardwolf" sign (if you're playing the Apogee version). If you press the wrong set of walls, you might not be able to get either, or worse, get stuck in there forever. But otherwise, the rest of the map was straightforward as long as you can track where you are (or you're using automap). 😀
3. The 2 Hans Grosses in the maze are bugged. For some reason they don't activate properly (at least not from a fresh save), and even if they do, if you can pin them down before they are able to move, their shots won't hurt you.
Video footage here: https://www.youtube.com/watch?v=J2x-FfNgD5w
Anyway, here's version 1.38, which I used to test the entire game (and take the above screenshot and video). It didn't crash anymore, so I'm releasing it to the wild.
Reply 87 of 194, by Gmlb256
ericvids wrote on 2021-10-15, 18:10:
Heh, this reminds me of another enemy AI bug where they won't attack the player if they are stuck on the doorway and the player very near to it while making sure that the enemy can't see the player. This allows the player to kill the enemy with the knife undisturbed except dogs. 😁
Reply 88 of 194, by mOBSCENE
Neat project! Just tested version 1.38 on my real DOS machine, and it seems to work very good! It also seems to work properly with custom episodes for both Wolfenstein 3D (Super Upgrades) and Spear of Destiny (Mission 2 and 3).
Few small remarks:
* it took me a while to figure out the automap function - there seems to be no info about it on the project page on how to activate it, by accident found your Vogons post that describes the different Tab functions and only then realized I can change the Tab option from the Control menu (assumed Tab function could only be enabled/disabled entirely at first)
* the MPU-401 music is really loud, in comparison to the in-game sound effects and also in comparison with other games that support the MPU-401 - since I use an UM-ONE to transfer MIDI to my main PC to Falcosoft's Midi Player, I can change the volume there, but would prefer to be able to change the volume in-game
Anyway, I haven't noticed any real bugs!
Reply 89 of 194, by ericvids
Gmlb256 wrote on 2021-10-15, 18:20:
Oooh, I got to try that one... I also noticed I get stuck on doors myself when a standing enemy is immediately adjacent to its opening... I guess it's related...
mOBSCENE wrote on 2021-10-16, 16:03:
Wow, I'm glad it works! I haven't actually tested it with the super upgrades and the extra sod missions yet (and I hated mission 2 without a map, hahaha... I wonder if it's playable for me now...)
Okay, I'm making it a separate menu in the next version... I don't know how long it'll take, but it's gonna be there.
As for the music volume, I've so far hesitated because I discovered that the standard way of setting MIDI volume (via GM1 sysex) does not actually work on a few devices, such as the Roland MT-32 and pre-GM models of SC-55/CM-300.
I guess I could set the volume per-channel; I would have to manipulate the MIDI files' own channel volume messages when I get them. What do other games of the era do? (I also noticed Warcraft II sounds much quieter on default settings, but Warcraft I not so much... I haven't had time to check out what they actually send through the MPU401, though)
Reply 90 of 194, by ericvids
Sorry for the double post, doing a new release:
Version 1.39 is out, addressing the concerns above!
- added music volume control (for the use case as described above)
- put tab function options in a separate menu
- various fixes to automap: pushwall and bonus locations are marked on the map after player death, now renders "seeing" through pillars properly, added pacman ghosts locations (they aren't FL_SHOOTABLE so they previously didn't show)
- negative parameters for COMP, so you can specify, for example, COMP -1 as an easier-to-remember synonym for COMP 14 (which makes things work like WOLF3D.EXE on a Pentium but fixes the pushwall bug)
Note that the pushwall automap fixes required a minor tweak the savegame format. Savegames from 1.32 to 1.38 are forward-compatible to 1.39, but not vice-versa. (Why would you, though?)
The W versions unfortunately takes up 1 more KB of conventional memory (they now require 569 KB minimum). There's a limit to the features I can add before it becomes too large for regular DOS systems. But then again I haven't really cleaned up id's code (apart from removal of the WOLFHACK 386 stuff), so we'll see. Besides, I don't know what else to add at this point -- I've been playing the game as it is now and thoroughly enjoying it. 😁
Reply 91 of 194, by Gmlb256
ericvids wrote on 2021-10-18, 02:40:
That WOLFHACK stuff was the unused textured floor/ceiling code which eventually got used for the two Blake Stones games by Apogee and the DOS version of Super 3D Noah's Ark (which the original SNES version was notorious for being an unlicensed game). There were mods using a different code for this feature but I found them to be slower and flaky than the WOLFHACK code.
I think that it would be interesting to do a similar treatment for these Wolf3D based games now that I mentioned them. 😀
Reply 92 of 194, by ericvids
Gmlb256 wrote on 2021-10-18, 02:58:
I'm no artist though, so adding floor/ceiling textures is currently out of my league. 😜
Anyway, I've been eating my own dogfood lately and found a couple more issues with wolfdosmpu, so I just released Version 1.40.
The three big changes are:
- Added a small pause before starting a song. This helps clear up the MPU-401 data lines before playing the first few notes. (I fixed this because the new volume control added a few milliseconds delay on playback, causing timing issues at the start of the song).
- Active enemies will never go invisible now. This bug is caused by the 50-sprite limit of the original executables. You can reenable this bug by using COMP 16. (I fixed this because there are 75 officers in E4M10 that you can potentially kill at the same exact place, but if you try doing that in the original EXE, the officers turn invisible and you'll be shooting at ghosts for the latter half of the encounter.)
- More options for automap: You can now show secrets only when the level is "clear" (i.e., no more enemies are alive or can reach you), or always mark secrets but not unlock the rest of the map that you haven't seen. (I added this because during my own playthroughs, I found that showing the whole map gives too much away, and I feel dirty playing it 😉.)
Other than that, I've removed the "release candidate" tag now because I think wolfdosmpu is pretty stable at this point. Releases will also be more sporadic from now on since I've essentially run out of new things to add. 😀 (Except of course if people discover a game-breaking bug, or if anyone's able to make a set of high-quality floor/ceiling textures that go well with the original artwork, particularly the lighted/shadowed areas of the existing sprites...)
Reply 93 of 194, by Bondi
ericvids wrote on 2021-10-23, 19:51:
Hey, ericvids. Thanks a lot for the release and for the effort!
Just in case you need more ideas. 😀 You could make the owners of rarish PCMCIA sound cards happy by adding Sound Blaster Direct mode for digital sound (instead of DMA trasfer or instead of Disney Sound Source). It's a really simple routine. FastDoom already has it. Here is a short discussion
Re: FastDoom. A new Doom port for DOS, optimized to be as fast as possible for 386/486 personal computers! And I can also send you the C code that ViTi95 sent me to explain how it worked.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 94 of 194, by ericvids
Bondi wrote on 2021-10-24, 08:46:
Hi Bondi, I just got this working, can you try it out? (See attachment.) It's not as simple as I thought it would be because I had to repurpose id's semi-disabled pc speaker digital audio code for this (it's in assembly but thankfully I've gotten the hang of it by now), and I discovered a few bugs with id's sound code that I had to fix.
But it works now. 😀
You have to specify the port in the BLASTER variable, but specifically omit the DMA entry, like this: SET BLASTER=A220. If the BLASTER var is not there (i.e., if you let Wolf3D auto-detect it), DMA will be assumed.
The code is going to make a 286 suffer, that's for sure. I tried it on DOSBox at 1510 cycles/ms and the framerate is almost halved every time a digital sfx is playing. But, meh, it works. 😀
However I'm not making a release yet because I'd also like to support the Covox Speech Thing (since I'm using the 7000Hz timing interrupt already; might as well, right?). I'm having trouble finding a programming manual for that (and DOSBox doesn't officially support Covox except as a Disney Sound Source...) so I'm never sure if I'm supporting it correctly. Is the protocol essentially just the Sound Source minus the FIFO buffer? Do I still need to pulse the printer port off and on? etc.
Reply 95 of 194, by Bondi
ericvids wrote on 2021-10-25, 10:12:
Hi Bondi, I just got this working, can you try it out? (See attachment.) It's not as simple as I thought it would be because I […]
But it works now. 😀
Hi, ericvids! Amazing response timing! 😁
I've tried the executable, and as looks like mine is a registerd version as it was all messed up. But I could still test the sound.
I've tried it on two cards that have ES1688 chip so 100% SB compatible both set to port 220. BLASTER=A220.
One card is seen as Adlib (which is normal) and Wolf3d would not allow to select digital sound options.
The other card is seen as Sound Blaster. But selecting SB for digital sound resulted freezing as if it still tries to use DMA. This is what usually happens in an unmodded Wolf version.
Looks like Wolf is too smart and tries to detect things.
As for covox here is a sample of a wav player in asm. It's very similar to direct mode, even simpler.
The attachment COVOXTIM.txt is no longer available
Reply 96 of 194, by ericvids
Bondi wrote on 2021-10-25, 11:22:
Hi, ericvids! Amazing response timing! :D I've tried the executable, and as looks like mine is a registerd version as it was al […]
Oops sorry about the commercial/registered mixup.
How about this one? I also disabled sb pro positioning in this one to try to isolate the problem. Make sure you still have "SET BLASTER=A220" 😀
Reply 97 of 194, by Bondi
ericvids wrote on 2021-10-25, 11:47:
Digital sound is working now, as well as adlib music (did not copy MIDI folder yet). Cool!
But the game crashes sometimes now with this message (mostly after I kill someboby)
The attachment IMG_3259.jpg is no longer available
Edit. Also noticed that Wolf3d detects the card as Sound Blaster now (it was detected as Adlib before)
Reply 98 of 194, by ericvids
Bondi wrote on 2021-10-25, 14:04:
Digital sound is working now, as well as adlib music (did not copy MIDI folder yet). Cool! But the game crashes sometimes now wi […]
I wasn't getting this error, and I spent a few hours trying to reproduce your problem, then I realized something: I've seen the error before. It was when I tried to use the registered version EXE on shareware data files.
So I copied over the shareware files, and sure enough, it gave me the same exact error. 😜
I've uploaded both registered and shareware versions so you can see which one works with your setup properly. (Are you using .WL1 data files? Those are shareware.)
ALSO: I've got Covox support working on this build (I think). Do you have the hardware to test it? If so, the way to enable it is to add the SS# parameter to WOLF3DSW.EXE with # corresponding to your parallel port. (So if you plugged it into LPT2, you'd enter "WOLF3DSW SS2"). Then make sure Covox/Sound Source is selected in the Sound menu.
AND ALSO: Since the MPU-401 component is just one feature out of many at this point (and as Bondi eventually found out, wolfdosmpu works without the MIDI files in place and just reverts to OPL2 music), I am considering changing the name of the project to just "wolfdos". What do you guys think? 😀 It can't be "fastwolf" (like fastdoom) because it isn't faster. 😉 (Also, I probably won't rename the exe files since the suffixes are pretty descriptive, with M describing "music/minimum fixes" and W describing the WASD controls.)
Reply 99 of 194, by zyzzle
Keep the names as they are. "wolfdos" is just confusing.
