Amstrad Mega PC
Reply 180 of 234, by Zalog
keropi wrote on 2021-10-24, 12:23:
Just a heads up for anyone else considering getting either the Mega EverDrive PRO or the MegaSD flashcarts for Mega-CD support:
I got a mega everdrive PRO and although it works fine on my normal megadrive 1 console on mega-pc it it very problematic - normal cartridge games have gfx glitches like missing or flashing pixels.
Mega-CD stuff do not work at all, you just get a black screen , no bios load or anything...
Hi Keropi, as promised here are some details from my everdrive pro cartridge for you to compare with
Build date is 31/08/2020
It's detecting the MegaPC as a "EU PAL 50" system
The OS version is 4.07 (not the oldest as apparently my partner ugraded the cart when she got it).
Looking at the OS changelog for the Everdrive Pro cart, OS, there is a note stating
!!WARNING!! After this update cart will no longer be supported with older OS versions.
However, repair tool can be used for roll back to the older OS versions: http://krikzz.com/pub/support/mega-everdrive/ … ries/repair.zip
So if yours is a more modern version 4.09 to 4.13 (at the moment) - it'll need the repair tool if you want to try the older (4.07) version.
Reply 181 of 234, by keropi
Zalog wrote on 2021-10-27, 15:14:
Hi Keropi, as promised here are some details from my everdrive pro cartridge for you to compare with […]
interesting stuff , thanks!
my EDPRO is quite recent and I am running 4.13 atm
I do not think the sega-cd bios is at fault because games run fine on normal md console and secondly the normal game gfx issues have nothing to do with cd bios
I will downgrade and report back
Reply 182 of 234, by keropi
allright!
I used repair.zip to downgrade and started trying all OS updates from 4.07 to the latest 4.13
this time CD games worked fine (!) - even on latest 4.13 that did not work before - same SD same files same CD BIOS
the only thing that was the same in all versions were the small graphics glitches, Zalog can you test your system and see if you get this Tails corruption on Sonic 2?
Reply 183 of 234, by Zalog
keropi wrote on 2021-10-27, 16:47:
interesting stuff , thanks! my EDPRO is quite recent and I am running 4.13 atm I do not think the sega-cd bios is at fault becau […]
Glad the downgrade works. Interesting the re-upgrade to 4.13 keeps everything working - it perhaps suggests this is something that 4.07 does that is kept or inherited as the os is upgraded- it would be useful to ask the os author to look into it, as this suggests it could be fixed
Yes the bios suggestion was a very long shot, but I thought it could be possible (although highly unlikely) that you've encountered two separate faults - one gfx related and another related to the cd bios not loading. I'll have a look at sonic 2 in a bit !
Reply 184 of 234, by Zalog
keropi wrote on 2021-10-27, 17:35:
......the only thing that was the same in all versions were the small graphics glitches, Zalog can you test your system and see if you get this Tails corruption on Sonic 2?
Yes have just checked Sonic2 and I get graphical glitches with tail too - I'd never loaded this game on the everdrive pro so didn't notice it ! (apologies for phone pic)
The attachment Sonic2.JPG is no longer available
Checked my original cart of Sonic 2 on the MegaPC and definitely don't get this, so its not a problem with the amstrad running this game, it suggests you've found a second bug in the OS to report to krikkz , i have my fingers crossed he can fix it.
Still at least you've found a methodology to fix the first (no MegaCD) one, so megapc's can use this cart whilst he works on fixing both of them.
Reply 185 of 234, by keropi
Zalog wrote on 2021-10-27, 18:07:
Yes have just checked Sonic2 and I get graphical glitches with tail too - I'd never loaded this game on the everdrive pro so did […]
thanks for checking Zalog, at least it's not my MED or system that behaves like that.
My cart must have had some corruption in fw or something, I cannot explain why after downgrading with repair.zip it started working - but I won't complain about it! 🤣 🤣 🤣
I have reported all these to krikzz , I hope there is a cure!
I have been playing some MCD games all this time and I cannot detect any pixel errors with them. weird.
I also tried a real Sonic2 cart - it worked fine just like the MED works fine on a standard md console....
Reply 186 of 234, by keropi
I messed quite a bit with CD games yesterday and I got some weird behavior... although I could not detect any gfx issues with any CD game - I was playing Popful Mail for ~1hr and on saving I got this crash screen:
after that Popful Mail would not load. I had to delete the sram save file it created so the game would load but after a couple of times it failed again with a black screen - not even CD BIOS would load. Re-wrote the game files to SD again (there was no corruption but I did it anyways) but that did not help. Other CD games load fine though. I have no idea what is going on but it seems there are stability issues ....
Reply 187 of 234, by Zalog
keropi wrote on 2021-10-28, 11:08:
Very odd - I wonder if the act of saving caused the issue and screwed something up in the cart - might be worth running the "fix" program again to see if it makes it work again. Definitely agree with you that there are some issues with the cart as the original games play fine. Interesting though that they are confined to only some games, perhaps they are calling for resources on the cart which aren't covered properly in the OS yet ? Will definitely not play Popful Mail on the cart now !
Reply 188 of 234, by keropi
Zalog wrote on 2021-10-28, 13:16:
I think it's just because the MED-PRO is unstable on the mega-pc.
The trick was to delete the whole MEGA folder that holds the OS and copy it again from krikzz's OS package.
My guess is that some database got corrupted and prevented the game from loading...
We'll see how this goes in the end - tbh I am not hoping for much 😐
edit:
I found why popful mail dies like that: it's when you tell it to save to the emulated external ram cart
using the "internal" ram space does not crash the game
if you get the crash to get things going again you have to delete the MEGA folder and write a fresh copy...
Reply 189 of 234, by Jo22
Um, I'm just a layman here, but I remember that certain models of the real Mega Drive/Genesis used a cheap Motorola 68000 CPU by another company (Signetics ?).
From what I remember, that CPU had stability issues under certain circumstances and thus wasn't very well suited for overclocking projects.
Maybe it has issues with bus noise, to high capacities or other things like DMA, too, not sure.
Another recommendation was to make sure that the 68000 gets clean TTL signals, some users used a HD74LS14 as "buffer" thus.
Reply 190 of 234, by Richard Poll
I’m really enjoying my mega card, thanks keropi!
keropi wrote on 2021-09-21, 18:29:
the Mega Card is now a thing :D it was made possible with megadrive guru Tiido's help […]
the Mega Card is now a thing 😁
so what is onboard?
  • ALS100 soundchip providing SB/SBPRO/SB16 compatibility
  • a Yamaha OPL3
  • Realtek 8019AS ehternet controller providing 10mbps connection and boot rom support for XT-IDE BIOS
  • a scandoubler that makes possible for the onboard megadrive to output a standard VGA signal (it is a linedoubler like old amiga scandoublers, no framebuffer no lag - 1 scanline delay) , has jumper to enable/disable scanlines
  • an optional exclusive Serdaco MIDI daughterboard - the X3GS (basically same as X2GS but green and has some leds for added bling 🤣)
  • ISA header and MIDI I/O + routing configuration for an upcoming PCMIDI upgrade daughterboard , there are 2 midi jacks on board: 1x OUT and 1x IN/OUT selectable via jumpers
The ALS100 is a nice chip (and rare/expensive for some reason) but it cannot escape it's budget card roots. Rest assured this is the best sounding ALS100 card out there but do not expect quality to blow your mind.
It goes hand-in-hand with the Mega-PC that is a noisy and crammed system 🤣
The chip does support all SB ADPCM modes so there are no missing sounds in older games that use them.
The onboard Amstrad Adlib needs to be disabled with a simple mod - else the ALS100 software will complain about Adlib ports being used. Completely optional one can ignore that and edit ALS.INI by hand if needed.
The megadrive sound is routed through ALS100 so no separate speakers or external connections needed.
The scandoubler portion is now as good as it gets with the signals it gets from the original amstrad megadrive card - which is a little messy: video signal routing is not good and RGB levels overdriven.
Despite that, the photos below do not do it justice: at times one might think it's an emulator running and not the actual megadrive.
The ribbon cable from the amstrad megadrive card connects to Mega Card and then a new ribbon cable connects to the Amstrad motherboard. This way the original VGA port is used and A/V switching is done on the Mega Card.
There will be research how to mod the original amstrad megadrive card to bypass it's shortcomings: it will be quite some components removed but if someone wants to get the max quality out of it then it will be an option.
A small cable is needed to patch the megadrive clock to the scandoubler, this cannot be avoided and will look like this , solder points are 2 legs of the crystal oscillator...
and here is how the card connects to the system:
and now some pics of the card in action 😀 keep in mind I cannot take good CRT photos for the life of me, my camera has especially troubles with color balance 😐
that's it for now! hope you like what you see
added 28-09-21
I am not sure what IMGUR will do to the 11mb JPGs but I managed to get better crt pics 😀
I suggest you click on the direct links to get the full resolution of the pics
https://i.imgur.com/HujdSFc.jpg
https://i.imgur.com/FmPIfVn.jpg
https://i.imgur.com/8fogemA.jpg
https://i.imgur.com/SlExC6M.jpg
https://i.imgur.com/e2OUe7W.jpg
https://i.imgur.com/5owYeER.jpg
Reply 191 of 234, by phipscube
Do you have a Mega Card?
Edit
Wowee! Just checked the site and sent out a request to buy one! ...Joy!
Richard Poll wrote on 2021-12-12, 22:05:
so what is onboard?
  • a Yamaha OPL3
added 28-09-21
Reply 192 of 234, by keropi
thanks for the support guys!
there will be an RMC video about the MegaCard later this week - it mainly focuses on the md part but there is some pc action as well in it 😀
Reply 193 of 234, by smsdave
Great review video now on RMC.
https://youtu.be/nOyza3cOOqM
Thanks keropi, looking forward to getting my hands on mine even more now!
Reply 194 of 234, by kolderman
Does this Mega card work only in an Amstrad or any PC?
Reply 196 of 234, by keropi
PCMIDI addon for the megacard is in the works... 😁
it will be a tight fit - space is just enough for it
Reply 197 of 234, by keropi
....aaand it's done and working great as expected 😁
now the MegaCard project is truly complete 😀
Reply 198 of 234, by JimWest
This is really great work! Congratulations to everyone involved!
Reply 199 of 234, by phipscube
Truly amazing mate! It's something to be very proud of 😀
I'm currently waiting for my Mega Card to arrive.. watching it travel here via the tracking number, Mega excitement!
