First post, by EvieSigma
I have a Compaq LTE Elite 4/75CX with the always troublesome Citizen W1D floppy drive and I'm trying to repair it, but I think I did something wrong? I opened it up to try and shrink the belt, as I don't have a replacement on hand, and after reassembly it won't accept a disk, it just gets stuck in the drive. I opened it up again and corrected an issue I noticed (the drive head assembly had somehow come loose from the worm gear that moves the heads back and forth) but I still can't actually load a disk into the drive. What did I do wrong?
