First post, by stealthjoe
I am trying to get a couple of DOS games (Body Blows, Jungle Strike, Desert Strike) running on my PC(in signature). These are few of the most stubborn games I encountered. Would always fail to run with a runtime error or divide by zero error. While I do agree this PC is too fast for these games, these wouldn't run on a Pcem setup as well (133/200 Mhz). I was able to get Body Blows running on my PC using Throttle but it was extremely slow. I remember able to play these games (albeit shareware) without a hitch on an old system I had long ago (P200 MMx, 32 MB RAM, Socket 7). Sadly it is no longer with me. Appreciate if anyone could share your experience in running these games on your retro builds and the config used. Thank you!!
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
Reply 1 of 4, by Revolter
You're on the right track, but Throttle does slow things down to a crawl if run without the "-C" parameter (telling it to NOT disable L1 cache, which is the case by default).
Anyway, there is now a new utility including both the chipset throttling and CPU's own ODCM (which is another 12.5% increment throttling feature in addition to the previous one) control functionality:
CpuSpd - A Hardware Based CPU Speed Control Utility for DOS/Win9X Retro Gaming
Celeron 800@1066, 512MB, GeForce2 MX AGP/GeForce 8400GS PCI, ES1938S/Dreamblaster S2, DOS 6.22/Windows 3.11/Windows ME/Windows 2000
Reply 2 of 4, by luk1999
Sounds like an issue with old Turbo Pascal app. Have you tried to patch these games?
Fix "Error 200" (Divide by zero) - by Snover and Stiletto (updated!)
P4 3.0C, P4C800-E Deluxe, 1 GB RAM, X800PRO 128 MB AGP, SB Audigy, Chieftec 400 W, XP SP2
XP2000+, KT2 Combo, 512 MB RAM, GF3Ti200 64 MB AGP, FM801, FSP 400 W, 98SE
C500, Garry, 128 MB RAM, Voodoo 2 12 MB, TNT2 PRO 32 MB, ALS100 Plus+, Compaq 200 W, 98SE
Reply 3 of 4, by stealthjoe
Hi. Thanks for your replies. I tried to patch Desert Strike and Jungle Strike using the TPPATCH.EXE, but in vain. It would throw an error (in German) that the file is not using Pascal 7.
Reply 4 of 4, by konc
Of course the Strike games aren't written in Pascal. There is a different cause for the problems you're facing with them.
