First post, by Sphere478
- l33t++
All my floppy hardware wasn’t working so I ordered goteks
Even got the fancy ones with oled, flash floppy and a dial. Totally loving them so far btw!
But I’m having a issue,
I was able to make a .ima file for the driver files. The same files that I used to use on a floppy when the floppy disks used to work.
I loaded it on the gotek and selected it, in windows ME I can open A: drive and see those files.
I reset and started xp setup push f6 and when I get to the screen I push S but it then asks me to insert a disk into the drive with the files on it.
Reset and go back to ME and drivers are right there in A: for the world to see.
What is the problem?
