First post, by RobDos
I'm tempted to pick up a 5.25/3.5" combo floppy drive from Epson but before I do I'm curious how to get floppy 3 and 4 working without BIOS support.
I assume I need some sort of driver.
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
Reply 1 of 18, by maxtherabbit
huh? those combo drives are meant to be used as the only device on the cable, you set jumpers to pick one as A and the other as B
Reply 2 of 18, by Grzyb
Indeed.
It's possible to have more than two floppy drives - https://www.seasip.info/VintagePC/floppies.html
...but those dual 5.25+3.5 drives aren't of any help here.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 18, by BitWrangler
This is one of those "It deepends" not a typo, just possible if you're willing to go off the deepend. I think Grzyb's link there is a fairly comprehensive overview.
Reply 4 of 18, by Bondi
maxtherabbit wrote on 2021-11-20, 15:05:
Guess it should work fine on a secondary controller with your driver. What do you think?
Isn't this combo drive in fact just two drives on one cable with the twist somewhere inside the circuitry?
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 5 of 18, by weedeewee
Bondi wrote on 2021-11-20, 16:31:
Yes.
Do not ask Why !
Reply 6 of 18, by maxtherabbit
yeah it is, and would
Reply 7 of 18, by Grzyb
Wait a min... I think I've missed something...
Is there some new driver for >2 FDDs?
Not that I really need one...
Once upon a time, I tried to install two generic multi-I/O cards, one jumpered for primary FDC address, the other for secondary - but it didn't work, even the drive connected to the primary ceased to work... probably IRQ and/or DMA conflict, and no jumpers to select different IRQ/DMA.
So I ended up purchasing one of those 4-floppy controllers with its own BIOS.
Reply 8 of 18, by retardware
Just do what is described in the article linked above.
It works fine, I did this already in the mid 1980s to connect 4 drives.
Nothing more needed than driver.sys and drivparm.
And uniform and/or xenocopy if your intent is to transfer from other systems' diskettes.
You just have to make sure that you either don't use castrated drives without DS jumpers or mod these to a particular DS.
Reply 9 of 18, by Grzyb
retardware wrote on 2021-11-20, 17:32:
But what exactly do you mean?
There's many scenarios described in that article...
Also, in mid-80s... wasn't that with an XT-style, DD-only controller?
I need HD, of course!
Reply 10 of 18, by Bondi
Grzyb wrote on 2021-11-20, 17:07:
Wait a min... I think I've missed something... […]
Yes, there is this driver https://www.vcfed.org/forum/forum/technical-s … ver=#post919840
But you need a proper secondary controller which allows to set alternative port and IRQ/DMA or handles sharing correctly. Adaptec AHA1542CF worked for me fine. AHA1542B I'm sure will do as well.
BTW nothig described in that article worked for me.
Reply 11 of 18, by retardware
Grzyb wrote on 2021-11-20, 17:39:
Controller (765 core) is same, it's just a better data separator.
Recently there was some talk about FDD controller, mentioning that the AHA-1542 FDC is one of the best ones available, also works with 2.88MB disks.
Of course, disable mobo onboard FDC, it's almost always inferior.
Reply 12 of 18, by rmay635703
My only quad floppy controller is a GRC with an IDE Bios onboard, has its own setup program and everything
3rd and 4th floppy drive letters end up interesting if you have a hard drive and cd
Reply 13 of 18, by crvs
Bondi wrote on 2021-11-20, 17:58:
Fantastic! This is the first driver I managed to get working with a 3rd floppy drive on Adaptec AHA1542CF, thank you very much for the link!
Reply 14 of 18, by Bondi
crvs wrote on 2021-11-22, 14:37:
The thank you goes to maxtherabbit, who wrote the driver. (:
Reply 15 of 18, by maxtherabbit
That's great. Using a 1542 as a secondary FDC is actually what motivated the project
Reply 16 of 18, by crvs
maxtherabbit wrote on 2021-11-22, 16:37:
Thank you a lot for your effort, both on the driver and sharing the details. There is suprisingly few information on this topic, basically just a page mentioned above, but none of its solutions had worked for me (I didn't try only 4-floppy controller, just couldn't find one).
Reply 17 of 18, by rmay635703
crvs wrote on 2021-11-22, 17:52:
Every IBM 5150 has a quad floppy controller but it only supports up to 720kb drives, would need to wire the external floppy connector back inside to use it most effectively (unless you like enclosures)
Not supportting HD drives is a deal killer
Reply 18 of 18, by maxtherabbit
I like enclosures
There are a good handful of 4 drive controllers out there that support 500kHz too
