First post, by kolderman
I though I would try out an Athlon XP-M cpu I have had lying around for a while. The main interest in how slow it can go using setmul.
However, when I try and use setmul to change the multiplier, the system locks up. Setmul detects it as a K7 at the correct current mult/freq.
Is it supposed to work?
Reply 1 of 12, by BitWrangler
What motherboard/chipset/bios version ??
Reply 2 of 12, by luk1999
What motherboard do you use? Have you tried another apps to set multiplier (eg wcpuid)?
P4 3.4E, ASUS P4C800-E Dlx, 1 GB, X800 PRO 256 MB AGP, SB Audigy, XP SP2
P3 600, AOpen AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
K6-2/300, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
Reply 3 of 12, by kolderman
msi ms 6378
Reply 4 of 12, by BitWrangler
According to a page on fab51, which I can only get at with googles cache at the moment, (horrendous url alert) ...
http://webcache.googleusercontent.com/search? … n&ct=clnk&gl=ca
That board has been confirmed to work but boots at maximum mobile multiplier. A genuine mobile chip has it's max multi pegged at it's rated speed and it locked from going higher, whereas a mobile modded desktop chip may have it floating at 24x so this board might have problems booting one unless it had it's mobile multi capped.
So the question is, were you trying to set a higher multi? (unpossible) or a lower one? (shoulda oughta worked)
Reply 5 of 12, by kolderman
Lower, down to three. It's a genuine mobile athlon, true speed 1800mhz. I'll try a bios update.
Reply 6 of 12, by BitWrangler
Hmm I don't know if I've seen ppl set them lower than 5 or 6, but not sure if that's a hard limit on the CPU or just because motherboards/chipsets never expected to see any athlon or duron slower than 550 or 600 Mhz.
Reply 7 of 12, by kolderman
The mobo is revision 2, the bios is W6378MS V1.8 121801. There are not rev2 bios updates on the MSI website, just pbi 3.1.
I tried going to 5x, same problem. This is where it locks up (image). I will try wcpuid. Are there other tools besides?
Reply 8 of 12, by kolderman
OK so I tried WCPUID but it did NOT allow me to change mult, the option was greyed out. It did detect it as a Mobile Athlon XP just fine tho.
Reply 9 of 12, by BitWrangler
There's another oldie that might work on windows, https://www.majorgeeks.com/files/details/gcpuid.html
Reply 10 of 12, by kolderman
Tried using gcpuid - it gave me the option, but got the exact same lockup behavior when changes the mult even from 6 to 5.5. Maybe this mobo just wont allow it.
Reply 11 of 12, by luk1999
BIOS probably doesn't support Mobile Athlons.
If you have another motherboard (preferably something with VIA KT400/600 or SiS 746/748, ASRock is a good choice for playing with mobile CPUs) then you can test your XP-M on it.
Reply 12 of 12, by kolderman
I will try but this one had the ISA slot which made it interesting....oh well.
