M.2 NVMe working on old school regular pci
Reply 20 of 38, by chrismeyer6
It's a nice adapter and it's not badly priced either.
Reply 21 of 38, by Hoping
I wonder if there will be the possibility of putting a option rom a pci card so that it recognizes an nvme ssd and the OS can be started from it. In this forum (https://www.win-raid.com/t3661f13-Experimenta … Option-ROM.html) they have an option ROM to insert into the motherboard bios. But it seems less dangerous to me, and also very interesting if it could be put on a pci card. I know that there are isa cards for option roms but I have not found any pci other than this (http://www.softworld.es/cu/custodius_lite_2004/) that I don't know if it will be exactly what is necessary, and it could not be easily obtained I also suppose that you could use a network card but it does not seem to me such a clean method.
I am wondering this because I am currently using the usb boot method described here (https://www.win-raid.com/t871f50-HowTo-Get-fu … Systems-with-an -AMI-UEFI-BIOS.html) but for some strange reason, I don't feel totally comfortable with this method.
Reply 22 of 38, by Oerg866
Sphere478 wrote on 2021-02-05, 14:42:
This may be the first m.2 nvme ever on a pentium 1 era socket 7 motherboard 😂🤣 (it’s the highlighted one.)
Which Linux derivate is that?
Reply 23 of 38, by Sphere478
Oerg866 wrote on 2021-09-12, 14:37:
Um, been a while, trying to remember… I think it was debian jessie?
Sphere's PCB projects.
Reply 24 of 38, by The Serpent Rider
It's the safest method, because it doesn't change anything in firmware or hardware. And there's usually no problem dedicating one port and some random USB stick for boot loader.
Reply 25 of 38, by Sphere478
Hoping wrote on 2021-09-12, 13:45:
I think I mentioned that the problem is that these seem to run in some kind of pio mode when used on these old systems. I was literally getting kbps out of it, it was dreadfully slow. Totally ruined any thoughts of it’s usefulness.
The fastest thing I have found for old systems is this: promise tx4 sata II 300 pci. You can use that to adapt to a sata nvme I believe though I haven’t tried but pretty sure it would work. I’ve just used it on regular 2.5” it gets really good speeds on my 430tx mobo almost as fast as the ram haha
Reply 26 of 38, by The Serpent Rider
It's SATA or NVME. Not both. SATA M.2 can be easily fitted into 2.5 inch adapter.
Reply 27 of 38, by Sphere478
The Serpent Rider wrote on 2021-10-20, 21:13:
My terms may be confused.
Sata cable to sata stick on a adapter is what I mean 😀
Reply 28 of 38, by Hoping
Sphere478 wrote on 2021-10-20, 21:11:
What I would like to see is a boot rom pci card that recognizes NVME devices and can boot from them. Something like XTIDE that can be inserted into a rom of a network card. I am not targeting computers as old as a Pentium, but I am targeting computers that have native PCI-E, without adapters.
The usb boot method works, but I think a boot rom on a pci card would be intresting.
Reply 29 of 38, by cyclone3d
The HighPoint SSD7505 (4x nvme slots) and SSD7140 8x nvme slots) support booting.
16x PCI-e but they require PCI-e 3.0 or 4.0 and a UEFI BIOS.. and are quite expensive.
https://www.highpoint-tech.com/USA_new/series … ssd7500-faq.htm
So.. I forgot about this option, but you should be able to use CLOVER to pass booting to an nvme drive even if you only have a legacy BIOS setup.
I am pretty sure this should make it possible to boot to even a dumb nvme adapter.
https://www.win-raid.com/t2375f50-Guide-NVMe- … der-method.html
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30 of 38, by The Serpent Rider
So basically it's useless.
Reply 31 of 38, by Sphere478
Hoping wrote on 2021-10-21, 21:10:
Ah, with native pcie yeah that may work.
I think if you put grub on a usb drive you could boot to it.
Reply 32 of 38, by LSS10999
Recently I got myself such a combination to run a large NVMe SSD over PCI for data storage. The adapter itself works and the disk is being correctly recognized. I think it should theoretically use all the PCI bandwidth if possible, though I don't know if it'll affect the operability of other devices on the PCI bus as the bandwidth is shared...
The good part is that unlike USB/SATA, such a disk would not be visible to OSes or boot managers that can't handle it properly, so OSes that I don't intend to use the disk for would not complain.
However, I noticed a caveat when using it with Windows 7, as the PCI-PCIe adapter initially reported Code 10 error and refused to work. Googling about the issue led me to this. After following its instructions the adapter now works correctly, and I'm able to access the disk.
It seems the interoperability affects only Windows 7. On Linux it the adapter and disk work without any issue. Since the OP appears to be running Win10 and there were no mentions of workarounds used, it's very possible that the issue was already fixed on Windows at some point.
Reply 33 of 38, by Sphere478
LSS10999 wrote on 2021-11-22, 01:21:
Recently I got myself such a combination to run a large NVMe SSD over PCI for data storage. The adapter itself works and the dis […]
I encountered extremely bad transfer speeds it seems all the writes and reads had to be translated through the cpu because of the adaptation or something like that. I was literally getting kbps on older systems. And low mbps on newer hardware.
My advice if you want to do this is as follows
Use a promise tx4 sata II 300 pci card and adapt to sata m.2
That should actually come close to pci saturation. And honestly is probably be the absolute fastest configuration you can put on 33mhz 32bit pci. Might be able to go a little faster with a server style card with sd ram cache but not much.
Reply 34 of 38, by LSS10999
Sphere478 wrote on 2021-11-22, 01:53:
I encountered extremely bad transfer speeds it seems all the writes and reads had to be translated through the cpu because of t […]
Strange... On my test system (C2Q based) I was able to saturate USB2.0 speeds (~36MB/s) when copying stuffs from a USB stick (over USB 2.0 port) to the NVMe SSD behind the adapter. Maybe what disk you use matters as the NVMe-to-PCIe adapter is passive, so the PCI-to-PCIe bridge is the only thing between between the NVMe disk and the CPU/chipset. (EDIT: That was tested on Linux... not sure if how OS handles things also matters to some extent)
As for Promise TX4 SATAII 300 PCI... I recall having used it on a much older motherboard (Pentium D based) before and it worked great. I could even boot systems from SATA SSDs attached to it and the performance is comparable to that of the native SATA-150 ports, if not better.
Should say that the option ROMs those SATA cards use (for booting support) consume precious upper memory, which can be a problem if you use DOS, but not a problem otherwise. If not using the disks for booting, disabling the option ROM might prevent the UMB consumption as well as preventing incompatible OSes (that I don't intent to use them on) from seeing the disks, though.
Reply 35 of 38, by Sphere478
LSS10999 wrote on 2021-11-22, 03:25:
Strange... On my test system (C2Q based) I was able to saturate USB2.0 speeds (~36MB/s) when copying stuffs from a USB stick (ov […]
Check cpu usage. I think transfer speed is improved by faster cpus
Reply 36 of 38, by rasz_pl
Sphere478 wrote on 2021-11-22, 03:49:
shouldnt be, whole point of NVME is its a native PCI bus mastering solution bypassing CPU completely. You setup queues and it pumps data to/from ram without CPU intervention. There is a chance this particular drive had trouble when paired with PCIE x1 1.0 of the PCI-PCIE converter and other brand of controller would work better.
Reply 37 of 38, by LSS10999
Sorry for a shameless bump after about a year later. I've been experimenting with similar use cases on even older motherboards recently and, well, they all ended up in failure, unfortunately.
Even with such a PCI-PCIe bridge adapter, I can't really make NVMe SSDs work reliably on a chipset that predates PCIe. The NVMe SSD cannot be initialized on Linux as it would not respond to anything (device not ready in dmesg), and while the SSD works with Windows' default drivers to some extent, after some writings the disk would report errors and become inaccessible (recovers after a restart, though).
The bridge itself appears to work fine, and that the SSD itself I used for testing is working just fine on another system using native PCIe, so nothing was really faulty, probably just that chipsets too old can't really handle things like that. I tried several NVMe SSDs of different brands, and they all exhibit similar behaviors.
In the end I can only reliably use NVMe SSDs on PCI slots using such bridges, if the motherboard's chipset already had PCIe support (which was the case for the one that I already made working). In such cases, such bridges would be mostly useful for adding another (slower) storage when there are no more PCIe slots (including x1 ones) to spare.
But again, from previous posts I noticed it was indeed possible for NVMe SSDs to work on older, pre-PCIe chipsets. I wonder if BIOS needs to be aware of such devices somehow...
Reply 38 of 38, by Sphere478
In my case I was able to get it to work with debian jessie and 430tx motherbord. But it was so slow I didn’t even let setup finish.
The best way to do this is with a sata controler, and a sata m.2 that will work great!
It may be possible to do this on isa by adapting from ide to sata or scsi to ide to sata
