Reply 720 of 2387, by pshipkov
@chadti99
I am on win95 osr2 (or dos6.22/win3.11 - depends on which CF card I pick or what I want to test/check).
Do you get distorted sound in DOS ? Can check win98 as well - maybe it is something specific there.
How I get 2111 at 180mhz ?
By being very very Very Very VERY VERY patient with finding the right chips combination. I mentioned in previous posts that the UUD board is extremely picky about L2 cache chips if tightest BIOS timings are desired. With that in place it turns into one of the fastest socket 3 mobos, but the path to there practically rules it out for pretty much everyone. I can point you to previous discussion with Feipoa in the thread where prior to that I was on the opinion that the board is flaky/compromised in that regard, but his comments motivated me to experiment. It is possible.
12ns chips don't ensure tight timings. 256kb here happens with 15ns umc chips. 10124kb is with mixture of 15 and 10ns issi chips.
@Feipoa
I remember checking these threads.
How you tell if it is X or P related bios ?
Didn't observe any side effects other than slightly lower frame rate in some DOS tests which made me back off from it.
