Garrett W wrote on 2022-01-29, 09:17:Here's mine: […]
Here's mine:
MMX 233
3Dfx Voodoo Banshee PCI
OEM 430TX based board
64MB RAM
Win95 OSR2.5
3DMark2000 - 640x480 16bit - 436 3Dmarks
I might give it a go at 1024x768 just to see that Banshee way out of its league. I have a GeForce4 MX440 PCI that will really help out in this situation with TnL, but I'm somewhat unwilling to mess with my setup right now. Is CPU overclocking allowed for the results to be valid?
I ran a few more tests with the Banshee.
3DMark99 MAX - 800x600 16bit - 1246 3DMarks / 1609 CPU 3DMarks
3DMark2000 - 1024x768 16bit - 441 3DMarks
I found it very interesting that the MMX 233 is such a bottleneck in 3DMark2000 that even the poor old Banshee can do 1024x768 and score identically to 640x480. Anyway, I decided to test my GF4 MX440 PCI that I mentioned before. I used the earliest driver I had on hand that would support it, 43.45. The card is identified as the GF4 MX440 with AGP8x, but it is indeed a PCI card which I find somewhat amusing. The results speak for themselves:
3DMark99 MAX - 800x600 16bit - 1206 3DMarks / 1582 CPU 3DMarks
3DMark2000 - 1024x768 16bit - 1046 3DMarks
These scores demonstrate two things :
a) 3DMark99 MAX does not take advantage of T&L and as such scores ever so slightly lower than the 3Dfx card I had previously. I believe the slightly lower score (it was repeatable) to be a side-effect of driver overhead.
b) 3DMark2000 sees a massive boost, as was to be expected. In fact, unless I missed someone's score, I believe I'm on top for the time being! For proof, I have two blurry photos with CRT artifacts because I didn't bother to adjust the shutter speed.
The attachment 99.jpg is no longer available
The attachment 2000.jpg is no longer available
There's definitely room for improvement here. My particular OEM 430TX board comes equipped with 256K L2 Cache, so I suppose 512K could make a small difference, as would tighter memory timings such as CL2, which my board reluctantly does not allow me to modify. There's also the possibility of overclocking the CPU by using a 75MHz bus on this chipset (my board, once again, does not, regrettably, offer such an option) or even 100MHz on a Super7 board. Considering this PCI variant of the AGP8x version of MX440 probably came out rather late, I don't think I can really go much farther back when it comes to using older drivers, 43.45 are already from early 2003. A PCI variant of the GeForce2 MX using drivers from 2000 would probably perform a bit better.
