First post, by marinescuiuri
- Newbie
hello, I'm in need of help again.
have a fujitsu esprimo e910 desktop. the one for offices that are sold as refurbished right now.
it has one case cooler mounted in front that start for 2 seconds at boot (just a check most probably) then stay off even if cpu goes to 72 degree celsius (max temp I got from stress testing it).
now the second cooler is the cpu cooler. this one starts only when the cpu hits 70 degree. is very silent.
i have no control over this 2 fans. SpeedFan does not detect their rpm. probably this is how this office computers are.
i want to upgrade the cpu radiator (the arctic cooler 12 seems a good budget cooler). or any other low profile cooler for 1155 socket.
my question is, with a new cooler, will i be able to adjust the speed of the fan?
or, as long as the mobo doesn't have such luxury for the stock coolers, this options will not be present even with a new cooler ?
thank you guys
windows Xp build - code name: the last samurai
Fujitsu E910 / i5 3470T / 4GB DDR3 1600 / Intel Q77 chipset / 250w (85+) PSU / 320GB HDD (Xp) - 240GB SSD (windows 7)
