First post, by marinescuiuri
hello, I'm in need of help again.
have a fujitsu esprimo e910 desktop. the one for offices that are sold as refurbished right now.
it has one case cooler mounted in front that start for 2 seconds at boot (just a check most probably) then stay off even if cpu goes to 72 degree celsius (max temp I got from stress testing it).
now the second cooler is the cpu cooler. this one starts only when the cpu hits 70 degree. is very silent.
i have no control over this 2 fans. SpeedFan does not detect their rpm. probably this is how this office computers are.
i want to upgrade the cpu radiator (the arctic cooler 12 seems a good budget cooler). or any other low profile cooler for 1155 socket.
my question is, with a new cooler, will i be able to adjust the speed of the fan?
or, as long as the mobo doesn't have such luxury for the stock coolers, this options will not be present even with a new cooler ?
thank you guys
windows Xp build - code name: the last samurai
Fujitsu E910 / i5 3470T / 4GB DDR3 1600 / Intel Q77 chipset / 250w (85+) PSU / 320GB HDD (Xp) - 240GB SSD (windows 7)
Reply 1 of 5, by majestyk
Are there any settings in BIOS, like fan-profiles "silent", "performance"...?
Reply 2 of 5, by cyclone3d
You could always get a fan controller and add it.
Some of the Rosewill case fans include a simple fan controller that fits in one of the expansion slots on the back of the computer.
You won't be able to control the fan through the BIOS or Speedfan if it doesn't work on the stock cooler
As far as the system having issues if nothing is hooked up to the stock fan headers... You might be able to trick the sensor or even just mount the stock fans somewhere else.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 5, by marinescuiuri
cyclone3d wrote on 2022-02-05, 19:09:
You could always get a fan controller and add it. […]
man this is a good idea, must investigate
Reply 5 of 5, by Sphere478
marinescuiuri wrote on 2022-02-05, 19:40:
https://www.ebay.com/itm/313693144730?
Pic incase link goes down.
Sphere's PCB projects.
