Reply 60 of 128, by Mumak
- Oldbie
andunn wrote on 2021-12-02, 13:53:Model 30 still has the blank screen issue, wierdly the image corruption on next program launch does not appear every time. Model […]
Mumak wrote on 2021-12-02, 10:30:Posting v1.61 in a attempt to fix the PS/2 issues you've seen (except the hang at GUS check).
Model 30-286 memory amounts are fixed and everything else seems to be OK too.
Model 50 MCA bus info is still not working, when I hit "Enter" an empty "MCA Slots Configuration" screen appears for a fraction of a second and then goes back to the "Bus Info" screen.
Thanks for the report!
Posting v1.62 to hopefully fix both issues:
[version pulled as there's a newer one]
Please let me know the results.
