Reply 100 of 192, by Sphere478
- l33t++
PcBytes wrote on 2022-02-20, 02:29:Although slightly risky, CBROM should do that considering your bios is Award. […]
Sphere478 wrote on 2022-01-26, 07:12:oh BTW, here is this 😁
this is pulled from the bios. if someone can figure out how to put it in the new bios that would be cool
And if my memory serves me right... it was something along the lines of "cbrom biosfile.bin /logo yourlogo.bmp".
Not very sure of this as it's WAY long since I last tinkered with Award BIOS to that extent and that was already in the P4 era (with a ASUS P4P800-VM that took a beating almost daily from the amount of BIOS chips I was testing on it lmao)
EDIT: Here's a link from Supermicro (yes, they apparently tell you how to replace your BIOS logo with whatever you want!) that explains the procedure:
https://www.supermicro.com/support/faqs/data_ … hange_steps.doc
Disregard the OSB steps as you don't need them on your BIOS (it predates the OSB stuff by quite a few years at this point)
(FYI the OSB logos used in newer Award BIOS are basically those small Intel logos that show up in a square, black or white, during POST. These were also used in the P4 era to show what CPU you were running.)
it doesn't seem to be working for me I put in the command and it just lists commands that I can use
here is everything I have, I'm gonna try a few more times but then gotta run. if you wanna take a crack at it,
I'm also uploading this for anyone who wants both of the latest bioses for these boards, with any luck here in a few they will have the logo again! and there will be a new version!
