Reply 160 of 174, by feipoa
 - l33t++
Thank you!
Running:
DEBUG
g=dc00:7
opens the SCSI BIOS configuration utility, the same one as CTRL-A at boot time. However, it looks as if the DMA test routine has been built into this CTRL-A BIOS boot menu already. Perhaps it isn't in the *B variants of the 154X card? Either I didn't notice it previously, or I simply thought it was the common "verify media and remap sectors" feature.
HOWEVER, the benefit of running it from debug is that I can have all the Cyrix CPU registers setup first and thus determine if they are interefering with DMA transfers.
