Reply 20 of 112, by Sphere478
- l33t++
Nemo1985 wrote on 2022-03-12, 02:25:Probably, still the higher v2.9 frequency is 250 mhz (little to none overclocking chance), while the v2.2 is 285 (or 300 for the […]
Probably, still the higher v2.9 frequency is 250 mhz (little to none overclocking chance), while the v2.2 is 285 (or 300 for the almost impossible to find 433gp).
That's the performance difference at 250mhz clock:
Immagine.pngThe configuration was slightly different compared to the 200 mhz, but somewhat comparable.
At 200 mhz the difference (quake 320 resolution) was 1,7 fps, while at 250 mhz it was 2,2!
So apparently going up with clock increase the performance gap.
Yeah, we’re overclockers here. We care about max stable frequency! :p
Yeah, I’m still looking for a 433gp. There are two models. I may have mentioned. a MII and a MIIv which as far as I can tell are actually exactly the same thing 🤣 aside from the extra letter on the label. But I suppose it could be said that the 400gp is also basically the same thing 🤣
