Reply 20 of 33, by pshipkov
All good PC-Engineer.
Thanks for the additional notes and info.
You are seeing some of the things i observed with it as well.
It benefits from FPU, which is not typical for video games up to Doom class stuff.
This makes it misleading for "classic" interactive DOS graphics.
You can verify its dependence on FPUs if you run it on a 386 systems with and without FPU. Results are vastly different.
Aside of that it is decently indicative measure for video cards, but still predominantly CPU sensitive.
But this is kind of inline with all apps/games from that era - in the general case - CPU is everything that matters.
Do you have more charts ?
Don't be shy. : )
retro bits and bytes | DOS media library
Reply 21 of 33, by PC-Engineer
Ohh, i have some charts more, but this is the wrong thread for it 😉
Maybe I don't understand exactly what you mean by FPU dependency.
At least for 486 (did not tested 386), the FPU dependance of PCP Bench is minor. The SX/33 without FPU has 92% of Performance of DX/33 with FPU. Or the UMC U5S without FPU has 118% of Performance of DX/33.
But even this FPU dependency does not change the suitability of the PCP Bench as a comparison for graphics cards with the Same CPU for me. With Quake it is apparently something else, because here the strong FPU limitation (on 486) almost completely cancels the scaling of the graphics cards, so that even an ISA graphics card is enough to draw the data provided by the FPU.
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 22 of 33, by pshipkov
Yeah, we kind of hijacked the thread instead of getting a room for the two of us.
If you try in 386 machine you will see how strongly dependent PCPB is on FPU.
But also, if the CPU is fast enough, the perf difference between FPU or not gets smaller.
486 hardware masks the problem. So in a way we can say that things are somewhat consistent there.
In both PCPBench and Quake 1 i see around 10 fps difference between best/worst components on a 30 max fps basis.
So both tests give enough range to judge something on them.
But both predominantly CPU/FPU bound before hit anything around VGA, etc.
Anyhow.
Reply 24 of 33, by OSkar000
Wow, lots of response here thru the weekend 😀
I don't mind my thread getting hijacked with lots of more or less useful information for me.
So if I understand things correctly I should try to find a S3 Vision 864, 868, 964 or 968 with at least 2mb ram.
I can get an ATI Mach 32 with 2mb ram but that card is pretty limited due to its slow-ish ramdac. Still thinking of getting it to try if its any fun/good/useful.
Reply 25 of 33, by PC-Engineer
The Mach32 are very good cards for DOS and Windows for its time, if you don’t need 1600x1200.
Also the drivers for Windows and DOS (little TSR for VESA compatibility) have a good quality. The best variant is one with VRAM, 2MB (for memory interleave) and ATI68875 RAMDAC (135MHz).
Reply 26 of 33, by OSkar000
PC-Engineer wrote on 2022-04-05, 08:57:
The card I can get is a Graphics Wonder Mach 32 with the 135mhz RAMDAC and 2mb DRAM, fcc id EXM229.
It seems to be pretty usable and fits some of my needs.
Reply 27 of 33, by maxtherabbit
PC-Engineer wrote on 2022-04-02, 17:01:
I have tested some VLB cards in system with a Am5x86 @160MHz for DOS apps. […]
In general the following accelerators can get a recommondation in DOS and Windows:
S3 864 / S3 868 / S3 968 / S3 Trio64 / S3 Trio64 V+ (all with 2MB DRAM or 2/4 MB VRAM)
ATI Mach32 2Mb VRAM / ATI Mach 64 2/4 MB VRAM
Trident TGUI 9440 2MB DRAM
ALG 2228 2MB DRAM
Cirrus Logic GD5434 2MB DRAM
In any case (for the cards above) make sure, you have 2MB RAM for 64Bit memory access or Memory interleave (Mach32) - only important for windows. For windows use make sure you have a (>)135MHz Hi- or Truecolor DAC. With Trio64 and TGUI9440 i observed spaghettized pictures on TFT screens. The best affordable, fastest card would be one with S3 864 like @kixs recommends. The S3 cards with DRAM are faster in DOS than the VRAM variants. In Windows the S3 VRAM cards are faster. With ATI cards the VRAM cards are equal to DRAM cards in DOS and faster in Windows.
The S3 Vision cards: 864/868 (DRAM) and 964/968 (VRAM) and Trio64 are 64Bit.
The older S3 cards 805 (DRAM) and 928(VRAM) and Trio32 are 32Bit, while the 805i has memory interleave with 2MB DRAM.
The S3 868/968 are nearly identical to the 864/964 with some additional video acceleration and zooming features.
The Trio64 hat the 864 core with integrated 135MHz RAM DAC.
For 1600x1200 @8bit with 60Hz or higher you need a 4MB card with 175MHz (or higher) RAM DAC. So you should look for: ATI Mach64 +Memory Upgrade, Diamond Stealth 64 (Video) VRAM +Memory Upgrade (was available with S3 964 and 135MHz DAC and as „Video“ with S3 968 and 220MHz DAC), ELSA Winner 2000 4MB version (was available with S3 928 and 964).
All of these cards are nearly unobtainalble. The best chance for you is to ask the user Madao, he developed a own S3 968 4MB VRAM card.
Fantastic data. Do you have access to a TVGA8900CL or TVGA8900D? They have a 32 bit memory interface and are significantly faster than their 'C' counterparts
Reply 29 of 33, by kixs
maxtherabbit wrote on 2022-04-18, 13:30:
ALG 2228 2MB DRAM
With Trident chipsets there isn't a standard rule. Sometimes even the same looking cards with the same chipsets have different performances. I find CL cards faster than D.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 30 of 33, by arncht
For dos ark is the fastest, good compatibility but not so good vga output. The vision864 is a good compromise and authentic way, similar fast as the wd90c33 or the et4000w32p. Avoid the tseng, it has compatibility issues.
Overdoze of the demoscene
Reply 31 of 33, by noshutdown
its an old post but i am quite sure that the fastest vesa card is the s3 968/964, the next are probably ark1000, s3 864/868 and trio64(also based on 864).
the slowest is supposed to be trident9200.
but really, since vesa cards are for 486 only, i doubt if they would really make any difference when paired with such slow cpu.
Reply 32 of 33, by dionb
Nice necro...
One thing not discussed three years back was the elephant in the room: the 1600x1200 requirement and what that means for image quality.
Purely looking at performance, S3-based cards are good all-rounders. But they frequently had really bad image quality that was irritating at 640x480, let alone at higher resolutions. In the mid 1990s (VLB era) anything over 1024x768 was the realm of specialized solutions and 1600x1200 basically unheard of.
A lot of cards simply could not support it (eg integrated RAMDAC on Cirrus Logic chips.maxes out at 1280x1024) and even where supported (eg S3 968 or Ark 1000VL - If paired with suitable RAMDAC) the card would have to have analog circuitry on par with say Matrox to deliver acceptable image quality.
Finding a VLB card that can 1 display 1600x1200 and 2 do it well will be the challenge. If you manage that, you take whatever performance you get.
Reply 33 of 33, by noshutdown
dionb wrote on 2025-01-25, 11:14:
Nice necro... […]
Nice necro...
oh man, the idea does sound crazy to me, as running 1600*1200 requires ~160mhz or higher ramdac.
yes, some s3 968 vesa cards with 175 or even 220mhz ramdac do exist, but running such high resolution on a 486 machine still seems meaningless. only highend 17inch crt monitors are capable of that resolution at that time, and 17inch monitors only starts to become popular in 1998 or so, most of which are 110mhz economic models, not to mention the highend ones capable of 175mhz or higher.
