First post, by Stiletto
It includes the source to both the original PSX game as well as its Windows port (including ATI 3D CIF headers!)
Please note that it is currently unknown if these sources are fully buildable.
https://twitter.com/forestillusion/status/150 … 048268176990209
do the Fandango!" - Queen
Stiletto
Reply 1 of 17, by RetroGamer4Ever
I wish someone would release the source for G-Police. That one would be fun to have revamped for modern systems, as it just needs the graphics code adjusted for today's D3D.
Reply 2 of 17, by BEEN_Nath_58
I randomly download some files while I was tired and on phone, turns out it was the Wipeout source. Lmao
Reply 4 of 17, by leileilol
RetroGamer4Ever wrote on 2022-03-27, 20:49:
reminder that code leaks don't mean guaranteed sourceports. It's too legally toxic there. Every time leaks like these happen, there's always that "this will improve x" on the assumption that programmers will look at it and use it.
Reply 5 of 17, by ZellSF
Download isn't working, anyone has a mirror? I want to look at the incomplete Direct3D port that's apparently included.
Reply 6 of 17, by PC Hoarder Patrol
ZellSF wrote on 2022-04-06, 09:52:
It's on the internet archive
Reply 7 of 17, by robertmo
should work with dgvoodoo2
Reply 8 of 17, by BEEN_Nath_58
robertmo wrote on 2022-04-06, 14:12:
I think he wants a D3D11/12 remaster. In general, almost every known Windows game from 1995 can work on current systems with latest OS architectures.
Reply 9 of 17, by RetroGamer4Ever
I want a game that works perfectly with today's DirectX. Many older games with 3D acceleration don't work due to deprecated/removed features and DirectX pipeline changes in the APIs and drivers and quite a few titles simply don't work because they don't support the widescreen resolutions used in today's systems, which is why I have a pile of the old LCD monitors, which I run off of the DVI port on my GPUs.
Reply 10 of 17, by robertmo
i think dgvoodoo2 should cover all that. if it doesn't report a bug
it should also add black bars on wide screen monitors
Reply 11 of 17, by ZellSF
PC Hoarder Patrol wrote on 2022-04-06, 10:23:
Thanks. Got it to build, but it's not working. This guy has more success:
https://twitter.com/3226_2143
Reply 12 of 17, by BEEN_Nath_58
RetroGamer4Ever wrote on 2022-04-06, 16:11:
I am still happy with my Nvidia 10 series card which can pump resolutions as low as 320x200 and run games as old as MechWarrior 2 for Windows 95. You'll need workarounds to get games working though. robertmo mentioned about dgVoodoo2, then there's DDrawCompat, WineD3D, DxWnd which does more than DirectX, DDHack, you'll just have to bear and configure things properly to get things working. And always it's not DirectX, on my Nvidia card many things are already sorted out and the rest I look into are CPU scheduling, exceptions skipping/NOP, limiting memory, CDFS support, single core affinity, etc.
And as you asked for a game that works perfectly with today's DirectX, how old do you want? 1995? I got MechWarrior 2 working. 1996? NFS1 works in most cases, Jane's USNF, Interstate 76 does work. 1997? GTA 1, Frogger, NFS2, Mortal Kombat 4, etc. 1998: Half Life, NFS3, Jane's ATF, SpeedBusters, Rayman 2. There's a lot that works, but I don't have a list right now.
You can keep going on, but don't expect to get much from MS. Just a week ago, MechWarrior 2 for Win95 could run on fullscreen without any graphic emulation and now it complains that my GPU isn't able to support fullscreen. Although DxWnd's DirectX restored it again, it proves nothing is constant and you'll need to work on getting things to work.
For now I primarily use DDC or DxWnd but use dgVoodoo2 when some exotic feature is required such as Table Fog or pallettized textures or the former 2 don't work well.
Reply 13 of 17, by ZellSF
That seems like a bad assumption. I haven't run into any game that has a problem with widescreen monitors, what old games can object to is too many resolutions available, which gets more likely with higher resolution and higher refresh rate monitors.
Reply 14 of 17, by BEEN_Nath_58
ZellSF wrote on 2022-04-08, 09:34:
ACT has done a good job in limiting resolutions. For example, Frogger 2 has issues with running very high resolutions such as 1080p which gets suppressed by some ACT flag.
Reply 15 of 17, by appiah4
Still waiting for the obligatory Vulkan port 🤣
Reply 16 of 17, by BEEN_Nath_58
appiah4 wrote on 2022-04-08, 10:22:
I'll be quite disappointed if the Witcher remaster if it comes for PC doesn't have Vulkan.
