First post, by debs3759
What is this miniature ATX PSU connector called? It is 38 mm long, smaller than standard ATX, on a desktop socket 479 motherboard. I have a suitable power supply, but its size is longer than the board, so won't be suitable for the small build I'm planning. The PSU I have is like a long Flex ATX PSU, but I'm not sure if that is the name of the connector. The motherboard is mini ITX
Reply 1 of 9, by PC Hoarder Patrol
debs3759 wrote on 2022-04-19, 23:31:
Something similar to the Molex Micro-Fit Connector System?
The attachment Molex 0430452424.pdf is no longer available
Reply 2 of 9, by debs3759
That looks like it, thanks. I can't find any kind of micro fit psu or ATX adapter so far, so may have to use the psu I have. I think I found a suitable case, so that's something 😀
Reply 3 of 9, by darry
debs3759 wrote on 2022-04-20, 00:23:
What are that PSU's brand and model ?
You may be able to find a hint as to how to find a smaller sized equivalent based on its spec sheet or manual .
Reply 4 of 9, by PC Hoarder Patrol
I see plenty of adapter cables but they seem to be mainly for Dell systems, and I'm not sure they're wired straight thru 1 to 1 - what mb model is it for?
Reply 5 of 9, by debs3759
The PSU is an AcBel (never heard of them) API5PC14. The motherboard is an Asus PTGV-DM, from an HP Onyx system. I have the whole system apart from the original case. Everything I see for sale is 4-pin, no 24 pin adapter to use with an ATX PSU
Reply 7 of 9, by debs3759
I was searching "micro-fit". That looks like what I need, thanks. I've never worked on boards from large OEMs 😀
Reply 8 of 9, by ODwilly
Is it the Asus HP 479 board? If you search for the motherboard model # or HP name it should come up with an adapter on ebay. I bought one a few years ago.
Reply 9 of 9, by debs3759
ODwilly wrote on 2022-04-20, 01:20:
Searching the motherboard name came up with nothing. The link PC Hoarder Patrol posted gave me search terms for a good few adapter cable, so all is good
