DOOM with ray-tracing
First post, by Jo22
Hi everyone,
Just saw another interesting article at hackaday.com that may interest you.
https://hackaday.com/2022/04/18/ray-traced-do … -really-shines/
Raytracing sure is fascinating, I think.
It also has a CRT filter, if I understood the comments correctly.
Reply 1 of 28, by gedbag
These raytracing ports of old games are the one thing that really make me want to have a modern powerful gaming PC. It's pretty cool how well it works, even in Doom, which lacks actual dynamic lighting so the modders had to assign a bunch of lighting properties to objects in the world.
I'm looking forward to Half-Life with raytracing the most. That one just looks insane.
https://www.youtube.com/watch?v=SsteDE8h6jc
Finally accurate reflections on the Colt! 😁
Reply 2 of 28, by The Serpent Rider
One of examples when ray-tracing is not a good idea at all, because Doom lighting model was too simplistic. Half-Life should be looking fine though, because original baked lightmaps were already simulating realistic lighting.
Reply 3 of 28, by badmojo
The Serpent Rider wrote on 2022-04-20, 02:37:
Which is why a flashlight is included, and it's an awesome addition! If the author can fix a few remaining annoyances then this will be my preferred way to play DOOM going forward.
Reply 4 of 28, by The Serpent Rider
Basically that's fixing problem with duct tape.
Reply 7 of 28, by VileR
It may be interesting as a tech demo, but on the visual side it doesn't look like something I'd actually want to play. A bit like ZdoomGL/GZDoom with just the annoying visual distractions turned up to 11.
Reply 9 of 28, by VileR
FioGermi wrote on 2022-04-20, 08:09:
I often joke about how Raytracing sometimes comes down to making an entire game's floors all shiny, reflective and wet.
When your off-planet research base gets overrun by demonic hellspawn, the plumber is always the first to go. 🙁
Reply 10 of 28, by The Serpent Rider
Mario 64 RTX. Now shiny and wet!
Reply 11 of 28, by Sombrero
Everything casts a reflection. 🤣
When pixel shaders became a thing even dirt roads started to look like they had a glass coating. When the original HDR became a thing you needed to wear sunglasses to protect your eyes with some games. Et cetera. I wonder has there been a new graphical gimmic that hasn't immediately been cranked to the max without any notion to subtlety.
That said, as someone who prefers JDoom (without the 3D models of course, because sheesh) over other source ports, I might actually like this. Ain't buying a RTX card just for this though 😀
DOS/Win98SE: Abit BX133-RAID / P3 650MHz / Voodoo3 3000 / 128MB SDRAM / Audigy 2 / Orpheus
WinXP: Asus P5K / P4 HT 651 3.4GHz (65W) / 6800 GT / 2GB DDR2 / X-Fi
WinXP/7: MSI Z77A-G43 / i5-3570 / GTX 960 / 8GB DDR3 / X-Fi
Reply 13 of 28, by DosFreak
Was finally able to pick up a 3080 last week so may give it a shot. May tackle q2 rtx after elden ring first tho.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 14 of 28, by keropi
DosFreak wrote on 2022-04-20, 09:56:
[...] after elden ring first tho.
A man of culture ... I got some 220hrs on it 🤣
🎵 🎧 PCMIDI MPU , Orpheus , Action Rewind , Megacard and MK8330 soundcard website
Reply 15 of 28, by gedbag
Don't forget about Serious Sam Raytraced as well.
https://github.com/sultim-t/Serious-Engine-RT/releases
Reply 16 of 28, by buckeye
gedbag wrote on 2022-04-20, 10:37:
Tried this one, everything shiny has a "speckled" look to it. Mouse look is glitchy. Probably need
to dive in and tweak some settings.
Intel D865GL Pentium 4 2.4ghz. 512MB DDR 400 Geforce2 GTS 64MB SB Audigy 500W 98SE
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Reply 17 of 28, by gedbag
buckeye wrote on 2022-04-20, 12:51:
Did you try it recently? I think they fixed some of that stuff.
Serious Sam TFE: Ray Traced. Update 1.4: Lens Flares Latest Update log […]
Update log
lens flare rendering
upscaling techniques:
AMD FSR
Nvidia DLSS
fixed some sparkles in the reflections (e.g. on weapons)
mirrors can have texture on them
sadly, still no AMD support, sorry 🙁
Reply 18 of 28, by Jo22
No no. It's the reverse!
In raytracing, If you -the viewer- looks at an apple, then you don't actually look at an apple.
It's you that's been stared at by the apple. 😉
Edit: I do fully agree with everything beeing "all shiny, reflective and wet", also.
That's exactly what you get with classic raytracers! 😄
