First post, by Nikoh
- Newbie
On my old PC AT pentium 100 I installed a compact flash card instead of the hard disk.
I use the compact flash card to add files to my dos 7.1 cdu OS; sometimes it happens that the system no longer boots. I have done many tests and I have seen that if I re-copy fresh himem and emm386 onto the compact falsh card, everything starts working again.
This may config.sys:
[menu]menuitem=A, Extended memory (HIMEM+EMM386 NOEMS)menuitem=B, Extended + Expanded memory (HIMEM+EMM386)menuitem=C, Extended memory (JEMMEX NOEMS)menuitem=D, Extended + Expanded memory (HIMEMX+JEMM386)menuitem=E, Conventional memory onlymenudefault=A,10[A]DEVICE=C:\DOS71\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\DOS71\EMM386.EXE NOEMS I=B000-B7FF[B]DEVICE=C:\DOS71\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\DOS71\EMM386.EXE AUTO RAM I=B000-B7FF[C]DEVICE=C:\DOS71\JEMM\JEMMEX.EXE NOEMS X=TEST I=TEST I=B000-B7FF VME[D]DEVICE=C:\DOS71\HIMEMX\HIMEMX.EXEDEVICE=C:\DOS71\JEMM\JEMM386.EXE X=TEST I=TEST I=B000-B7FF VME[E][COMMON]SET PATH=C:\DOS71;..;FILESHIGH=40BUFFERSHIGH=50,0FCBSHIGH=16,0LASTDRIVEHIGH=ZSTACKSHIGH=11,512DOS=HIGH,UMB,NOAUTODEVICE=C:\DOS71\ECHO.SYS W/e/l/c/o/m/e /t/o MS-DOS 7.10...DEVICE=C:\DOS71\ECHO.SYS C/o/p/y/r/i/g/h/t M/i/c/r/o/s/o/f/t C/o/r/p. A/l/l /r/i/g/h/t/s /r/e/s/e/r/v/e/d.DEVICEHIGH=C:\DOS71\SETVER.EXEDEVICEHIGH=C:\DOS71\XCDROM\XCDROM.SYS /D:IDE-CDREM DEVICEHIGH=C:\DOS71\VIDE-CDD.SYS /D:IDE-CDDEVICEHIGH=C:\DOS71\DISPLAY.SYS CON=(,,1)NUMLOCK=ONCOUNTRY=039,850,C:\DOS71\COUNTRY.SYSREM SHELL=COMMAND.COM /P /E:640SHELL=C:\DOS71\COMMAND.COM /C LH C:\DOS71\COMMAND.COM /E:640 /PREM DEVICEHIGH=C:\DOS71\SMARTDRV.EXE /DOUBLE_BUFFERREM DEVICEHIGH=C:\DOS71\IFSHLP.SYSREM DEVICE=C:\CTCM\CTCM.EXE
and my autoexec.bat:
@ECHO OFFPATH C:\DOS71\NORTON\NC;C:\DOS71\DOSLFN;C:\DOS71\SHSU3-6;%PATH%PROMPT $P$GSET DIRCMD=/A/4/O:GENMODE CON RATE=32 DELAY=1MODE CON CP PREPARE=((850)C:\DOS71\EGA.CPI)MODE CON CP SELECT=850LH KEYB IT,,C:\DOS71\KEYBOARD.SYSLH KILLERLH DOSKEYLH SHSUCDX /D:IDE-CD /V /CREM LH MSCDEX /D:IDE-CDLH DOSLFN /Z:C:\DOS71\DOSLFN\CP850UNI.TBLLH CTMOUSESET SOUND=C:\SBLASTERSET BLASTER=A220 I5 D1 H5 P330 E620 T6SET MIDI=SYNTH:1 MAP:E MODE:0SET CTCM=C:\CTCMC:\CTCM\CTCMLH C:\SBLASTER\AWEUTIL /SLH C:\SBLASTER\MIXERSET /P /QECHO.REM For locking volumes to enable "direct disk access":REM CALL LOCKDRV.BATBREAK ONLFNFOR ONECHO Now you are in MS-DOS 7.10 prompt. Type 'HELP' for help.ECHO.
Could it be a virus? I did a scan with microsoft antivirus but it didn't find any viruses.
why do only the memory manager files get corrupted while everything else continues to work?
Discord server for italian retrogamers that love CRT
https://discord.gg/x7HQqDWmvw
