First post, by Nikoh
On my old PC AT pentium 100 I installed a compact flash card instead of the hard disk.
I use the compact flash card to add files to my dos 7.1 cdu OS; sometimes it happens that the system no longer boots. I have done many tests and I have seen that if I re-copy fresh himem and emm386 onto the compact falsh card, everything starts working again.
This may config.sys:
[menu]
menuitem=A, Extended memory (HIMEM+EMM386 NOEMS)
menuitem=B, Extended + Expanded memory (HIMEM+EMM386)
menuitem=C, Extended memory (JEMMEX NOEMS)
menuitem=D, Extended + Expanded memory (HIMEMX+JEMM386)
menuitem=E, Conventional memory only
menudefault=A,10
[A]
DEVICE=C:\DOS71\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS71\EMM386.EXE NOEMS I=B000-B7FF
[B]
DEVICE=C:\DOS71\EMM386.EXE AUTO RAM I=B000-B7FF
[C]
DEVICE=C:\DOS71\JEMM\JEMMEX.EXE NOEMS X=TEST I=TEST I=B000-B7FF VME
[D]
DEVICE=C:\DOS71\HIMEMX\HIMEMX.EXE
DEVICE=C:\DOS71\JEMM\JEMM386.EXE X=TEST I=TEST I=B000-B7FF VME
[E]
[COMMON]
SET PATH=C:\DOS71;..;
FILESHIGH=40
BUFFERSHIGH=50,0
FCBSHIGH=16,0
LASTDRIVEHIGH=Z
STACKSHIGH=11,512
DOS=HIGH,UMB,NOAUTO
DEVICE=C:\DOS71\ECHO.SYS W/e/l/c/o/m/e /t/o MS-DOS 7.10...
DEVICE=C:\DOS71\ECHO.SYS C/o/p/y/r/i/g/h/t M/i/c/r/o/s/o/f/t C/o/r/p. A/l/l /r/i/g/h/t/s /r/e/s/e/r/v/e/d.
DEVICEHIGH=C:\DOS71\SETVER.EXE
DEVICEHIGH=C:\DOS71\XCDROM\XCDROM.SYS /D:IDE-CD
REM DEVICEHIGH=C:\DOS71\VIDE-CDD.SYS /D:IDE-CD
DEVICEHIGH=C:\DOS71\DISPLAY.SYS CON=(,,1)
NUMLOCK=ON
COUNTRY=039,850,C:\DOS71\COUNTRY.SYS
REM SHELL=COMMAND.COM /P /E:640
SHELL=C:\DOS71\COMMAND.COM /C LH C:\DOS71\COMMAND.COM /E:640 /P
REM DEVICEHIGH=C:\DOS71\SMARTDRV.EXE /DOUBLE_BUFFER
REM DEVICEHIGH=C:\DOS71\IFSHLP.SYS
REM DEVICE=C:\CTCM\CTCM.EXE
and my autoexec.bat:
@ECHO OFF
PATH C:\DOS71\NORTON\NC;C:\DOS71\DOSLFN;C:\DOS71\SHSU3-6;%PATH%
PROMPT $P$G
SET DIRCMD=/A/4/O:GEN
MODE CON RATE=32 DELAY=1
MODE CON CP PREPARE=((850)C:\DOS71\EGA.CPI)
MODE CON CP SELECT=850
LH KEYB IT,,C:\DOS71\KEYBOARD.SYS
LH KILLER
LH DOSKEY
LH SHSUCDX /D:IDE-CD /V /C
REM LH MSCDEX /D:IDE-CD
LH DOSLFN /Z:C:\DOS71\DOSLFN\CP850UNI.TBL
LH CTMOUSE
SET SOUND=C:\SBLASTER
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
C:\CTCM\CTCM
LH C:\SBLASTER\AWEUTIL /S
LH C:\SBLASTER\MIXERSET /P /Q
ECHO.
REM For locking volumes to enable "direct disk access":
REM CALL LOCKDRV.BAT
BREAK ON
LFNFOR ON
ECHO Now you are in MS-DOS 7.10 prompt. Type 'HELP' for help.
ECHO.
Could it be a virus? I did a scan with microsoft antivirus but it didn't find any viruses.
why do only the memory manager files get corrupted while everything else continues to work?
Discord server for italian retrogamers that love CRT
https://discord.gg/x7HQqDWmvw
Reply 1 of 3, by mkarcher
Perhaps that flash card has weak sectors? Did you try comparing the corrupted memory managers with the original ones to find out the kind of corruption? Single bit flips are clearly distinguishable from virus infections.
Reply 2 of 3, by Horun
Good thought mkarcher ! If me would do this next time it happens: rename the files *.bad and leave them and then copy good files onto the CF, that way they would not be using same sectors.
I know that many times deleting a file just removes it from the file table so if you then rewrite the files they end up in same sectors as the supposed deleted ones specially IF no other files were
written to disk after delete and before writing....
Reply 3 of 3, by Nikoh
great idea, thanks guys i'll do it
