First post, by duboisea
I bought a Voodoo 3000 and it seems to have some issues. If I use it in DOS (or Windows without drivers installed) I get four horizontal lines of artifacts across the screen. When I install the drivers all I get is a black screen after rebooting.
Happy to post more images, just ran into the limit of 5. Anyone have advice or ideas?
    1.59 MiB
    1.49 MiB
    1.66 MiB
    1.5 MiB
    1.31 MiB
Reply 2 of 10, by duboisea
Done!
Reply 6 of 10, by paradigital
Repeating patterns are typically memory errors. With so few artifacts visible this would appear to be a single bit or single address line.
I’ve not had chance to look at the photos in detail, but I wouldn’t be surprised to see some physical damage.
Reply 7 of 10, by rasz_pl
You can test broken traces by squeezing individual memory chips with your fingers and then starting up computer, or running something rendering graphics on whole screen and squeezing ram chips one by one. Order of operations is important because just reconnecting broken trace wont show up on the picture without system refreshing memory with bad data.
Reply 9 of 10, by NostalgicAslinger
KM4132G512Q-7 means 7 ns memory chips, to slow for a Voodoo3 3000, because 7 ns is specified for 143Mhz like the Voodoo3 2000 PCI card with SGRAM. The 3000 SGRAM version needs 6 ns (166 MHz specified) SGRAM memory chips. Your broken card has 6 ns chips. I would look for the faster 5,5 ns SGRAM chips (183MHz), then you have more leeway when overclocking and install a fan on the heatsink or use a case fan behind the card, because the Voodoo3 cards are getting very, very hot without any active cooling!
Reply 10 of 10, by Rikintosh
I had the same problem but it was vertical red lines. It was one of the memory modules that was dead. I found a compatible module on another video card that I don't remember the model. I easily replaced it using a simple hair dryer and a little solder flux.
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
