Mugen
First post, by Unregistered
Well I've tried using this program in Xp using VDMsound. MUGEN is a customisable fighting engine, currently for DOS. It works fine in 98, but lacks normal sound in XP.
First I kept getting the "PIF" bug and solved that by restricting the prompt line to 64 characters. But now I keep getting close ups.
The program (vdmsound) runs for a while and then closes up giving me this error:
VDMSound DOS loader, version 2.01 (Aug 04 2001)
Copyright (C) 2000-2001 Vlad ROMASCANU.
VDMSound is covered by the GNU Public License (GPL), version 2 or later, as
published by the Free Software Foundation, Inc. (http://www.fsf.org/).
Loading 'VDDLoader.dll'...
Exiting due to signal SIGSEGV
General Protection Fault at eip=001037af
eax=fff70000 ebx=fff70000 ecx=00000343 edx=fff80000 esi=0016040c edi=00002010
ebp=001e3648 esp=001e3634 program=C:\DOCUME~1\USER\BUREAU~1\MUG~1\MUGEN.EXE
cs: sel=019f base=03430000 limit=7cbbffff
ds: sel=01a7 base=03430000 limit=7cbbffff
es: sel=01a7 base=03430000 limit=7cbbffff
fs: sel=0177 base=0000f280 limit=0000ffff
gs: sel=01b7 base=00000000 limit=0010ffff
ss: sel=01a7 base=03430000 limit=7cbbffff
App stack: [001e461c..0016461c] Exceptn stack: [00164574..00162634]
Call frame traceback EIPs:
0x001037af
0x000a5841
I hope anybody can help me on this one, thanks in advance.
Reply 1 of 13, by Snover
Searches are useful. Read that and see if your problem isn't solved or answered.
Yes, it’s my fault.
Reply 2 of 13, by Unregistered
Snover:
Yes I have tried that, but if you look a little further down, the one who started it didn't reply to the thread again. Thus not confirming if the given sollution actually works or not. Just to be sure let me say this:
MUGEN does work on XP or whatever, it just lies oin the configuration you have given it in mugen.cfg
The thing is, the sound isnt that clear and will not play midi files.
With VDMsound I tried to solve that and that's were this bug came up.
Thanks for your try.
Reply 3 of 13, by Nicht Sehr Gut
Originally posted by Unregistered Just to be sure let me say this: MUGEN does work on XP or whatever, it just lies oin the configuration you have given it in mugen.cfg
For the actual program issues we kind of have to redirect you to "experts" at places like http://www.mugenguild.cjb.net/ because troubleshooting MUGEN requires in-depth knowledge of the program and it has a huge number of variables. I don't think anyone here knows it well enough to cover more than the basics.
You'll find that getting DOS audio to run under XP is always a pain as the OS allows no direct access to your soundcard. You could always trying XP's native emulation (uses IRQ 5), but that is actually quite inferior to Vlad's emulation tool and will probably give you worse results.
Remember that the program you are trying to run was never meant to be run on an NT OS (Needs DOS->No DOS in NT). If you're truly determined to run it the way it was meant to be run, you may have to set up a dual-boot or use another set of hardware to run it.
Reply 4 of 13, by vladr
First, make sure that you have "Update 1" for VDMSound installed from http://vdmsound.sourceforge.net/files/VDMSoun … 0.4.update1.zip (unzip into VDMSound inst. directory and overwrite when prompted). Then use the "Run with VDMS" that does not have an icon next to it **OR** in LaunchPad, under "Advanced Properties", under "Troubleshooting", under "Custom Configuration" type/paste:
[VDMServicesProvider.config]
fixPOPF = 1
Does that fix the problem?
Cheers,
V.
Reply 5 of 13, by Unregistered
Nicht Sehr Gut:
First of all, MUGENguild isn't the expert in mugen. If there are experts in the mugen scene, then it's MUGENDev. at programming and Elecbyte at the programming of the game. Mugenguild can mostlikely be referred to as a mugennews page.
Vladr:
Then use the "Run with VDMS" that does not have an icon next to it **OR** in LaunchPad, under "Advanced Properties", under "Trou […]
fixPOPF = 1
Thanks for the tip, but that didn't help (at all). The same problem still occured.
Well if there is sound, shouldn't be adjustable?
It is there and hearable, isn't it?
Reply 6 of 13, by Nicht Sehr Gut
Originally posted by Unregistered First of all, MUGENguild isn't the expert in mugen.
I placed "experts" in quotes because, compared to me, they are. I was using the term relatively.
At the risk of being a wet blanket, I was never able to squeeze quality sound out of MUGEN under XP. Operation in general seems rather poor. Looks like a dual-boot candidate to me.
Reply 7 of 13, by Vladamir
Thanks so much vladr for that update posting that you put up. It didn't quite work like you said it would (had to run the vdms link with the icon as I still got the sigsegv error with the other one and that fixpopf line caused additional problems), but the fact is that my vdms works now, on mugen nonetheless.
Reply 8 of 13, by Unregistered
Vladamir:
It works on MUGEN, as in?
I'm not quite getting what you meant with that.
You're able to run VDM on MUGEN?
And yes quality sound is what I'm trying to get here. I've heard from a few people that they've been able to run VDM on MUGEN, but not IF they've got any good sound or not.
If it's there, it should be adjustable, right?
[edit]
MUGEN is quite something to learn, but after that it's fun to see what u can come up with. Almost if not everything is possible in MUGEN. Just need to figure it out.
[/edit]
[EDIT2] After screwing around with it some more, I got a PIF error. Has that got anything to do with the problem I'm getting or is that just another problem on itself. [/EDIT2]
Reply 9 of 13, by Vladamir
Ok, my apologies for being vague, I just meant that I stopped getting that annoying sigsegv error when I tried to run VDMsound with lanchpads default config; and that now I can run Mugen with vdmsound just fine. I get good sound and everything, which with my soundcard is pretty astonishing indeed.
Reply 10 of 13, by Unregistered
Hmmm... I'm using VD to run mugen and it's souding great... the only probelm is that the controls are very choppy.... like if I press back the character will keep moving back for a while after I let go
Reply 11 of 13, by Unregistered
Help! mugen runs great with vdm sound with the update and the other prog but after a couple of fights it throws me out of the game with the state already mentioned at the first post! what could be wrong?
PLEASE HELP ASAP!THANX IN ADVANCE!
Reply 12 of 13, by Nicht Sehr Gut
The DOS version was never beyond the BETA, it's a technical nightmare to run on any NT OS due to extremely large number of variable settings in addition to the VESA issues introduced by NT. If you go to the MUGEN home page, you'll see that they don't even have the DOS version for download and the only reference to it is in the FAQ, no download.
If you do find the download (elsewhere, obviously), when you run it you'll see that they ask you not to use this beta past November of 2001.
If it means a lot to you, you should seriously consider a dual-boot configuration for your PC. This is far easier to do with DOS or Win9x, but setting up Linux on a separate drive will give you proper support and features that are not in the DOS Beta.
The best solution is to download and use Linux, which is free (like MUGEN). Unfortunately, XP doesn't play nice with Linux, so you would probably need a Tool like BootMagic.
That about all I have...
Reply 13 of 13, by Unregistered
hey everybody , i got some good news,
am running MUGEN under winXP,
am using vdmsounds2.04, and the launch pad 1.0.0.7,
after you install the launch pad , make sure that the mugen folder is in this pad
C:/MUGEN
better say in your local hard drive, then run mugen with vdmsound , the 1 with icon,
and make sure of this setting;
My config:
VDM Sound properties:
Enable Expanded Memory (EMS)-on
Enable low level CD-ROM support (MSCEDX)-on
MIDI Emulation checked
Program:
Fast paste - on
Compatitiblity:
EMS checked 16384
XMS checked 16384
Enable DPMI support checked
Enable low level CD-Rom support checked
Enable low level network support checked
Dos enviornment:
Load HIMEM.SYS checked
Allow DOS to use UMBs checked
it works fine for me.
good luck 2 u guys.
