Blood 1 cutscenes in DOS
First post, by DoomSlinger
I recently got a copy of Blood 1 and was wondering if there is a way to get its cutscenes working in MS-DOS. They work fine in win 98, but I find that the game over all runs better when playing in DOS and non 640x480 resolutions work better as well. It's version 1.0 if that has anything to do with it. (as a side note, if anyone knows where I can download the patch to upgrade to 1.21 then that would be greatly appreciated). I've tried moving the Movie folder into the game directory and fixing the ini file. (they do work this way in windows, so I know I configured it correctly, but not in dos). Other than that I don't know what could do to get it to work. It may just be that cutscenes don't work in MS-DOS, which sucks.
I also want to point out I don't get the same splash screens in dos that I get in windows. It's like it's playing a low resource version of the splash screen. Any help is appreciated.
Reply 2 of 9, by Azarien
DoomSlinger wrote on 2022-05-28, 00:21:
Are you sure you're running the same exe file?
Reply 3 of 9, by DoomSlinger
Azarien wrote on 2022-05-28, 09:00:
Yes, it is the same exe file. It's the same install, I just have that pc set up to dual boot between ms dos and win98.
held wrote on 2022-05-28, 06:48:
Updates are here: https://web.archive.org/web/20090503054652/ht … blood.lith.com/
Then try these settings
Did not work
EDIT: I've recorded 2 videos of me launching the game, one in dos and one in win98 so you can see the difference. It's launched using the same file: https://drive.google.com/file/d/1_2YUHILaFhpM … iew?usp=sharing
Reply 4 of 9, by ZellSF
D:\3DREALMS
E:\3DREALMS
If the random warez copy I found is any indicator, blood.ini references absolute paths, so when you fixed it did you change to new absolute paths, or tried using relative paths (might not work)? Tried reinstalling in DOS?
Also as for the "low resource" thing seems like it's only running in a window? Right click the file > properties > screen > change to full-screen.
Edit: it doesn't work without the 1.11 patch in DOSBox either. So just patch the game?
Reply 5 of 9, by DoomSlinger
ZellSF wrote on 2022-05-29, 14:47:
D:\3DREALMS E:\3DREALMS […]
D:\3DREALMS
E:\3DREALMS
Ok, patching the game worked (I didn't have time to test that last night)
Also, the reason it shows 2 different drives is because there is a 50gb partition that doesn't show up in dos that is the ACTUAL D drive. so the D drive in dos gets moved to E
Reply 6 of 9, by Gamecollector
IIRC DOS cutscenes were fixed in the 1.10 patch.
Reply 7 of 9, by Azarien
DoomSlinger wrote on 2022-05-29, 17:19:
This is one of the reasons why Win9x's DOS is usually preferred to MS-DOS 6.x or earlier.
Reply 8 of 9, by Gmlb256
Azarien wrote on 2022-06-06, 17:16:
Yeah, but don't forget about Windows 95 prior OSR2 which like older standalone MS-DOS versions, it doesn't support FAT32 partitions.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 9 of 9, by Azarien
Gmlb256 wrote on 2022-06-06, 20:52:
Yes, but to be honest I never used Windows 95 version early enough not to have FAT32 support, which is why I did not think of it.
Back in the day I jumped from DOS 6.22 + WfW 3.11 straight into 95 OSR2.
(the longer story is 3.11 -> 95OSR2 -> 98SE -> XP -> Vista -> 7 -> 10 😜)
