Socket 1/2/3 Voltage Interposer Tweaker (Alpha)
Reply 60 of 94, by Sphere478
debs3759 wrote on 2022-06-11, 01:22:
I don't see any suggestion of a 387 from Sphere, he only said math coprocessor. As it's for socket 3, I take that to mean he wants to be able to run the i487 on it's own, which seems perfectly reasonable.
Currently I am not attempting to do a math co processor. It might get added to the pcb later down the road though if it’s determined that it is practical to do so. It was mentioned that there is a particular variant that is super common that would be encouraging to look into this further. But for now, gotta focus on the pin mods and make sure they are understood and stable.
Gonna need the help of someone with soldering skills and a vast socket 1/2/3 processor collection who is willing to do some pin mod experiments. To verify that these mods will work once they are wired.
It may make sense to get the alpha all setup with traces and have a alpha tester order one as a quick way to test the mods themselves and debug the design. This is still nowhere near release stage. So no one should be ordering this yet obviously.
Sphere's PCB projects.
Reply 61 of 94, by Sphere478
those willing to perform tests to qualify these mods please contact me.
Put in a decent amount of work on this today.
The attachment socket 3 interposer tweaker alpha 5.zip is no longer available
I think I found a way to put the instructions on the unit. they aren't as detailed as I'd like but this is what fits.
Note the holes are still 0.016" which is press fit size and as of yet untested. as it sits this may work with a motherboard LIF socket that has clearance and only the cpu as a shim. I would have to check interp0oser/interstitial socket dimensions and probably adjust.
Anyway, Retro and I are still trying to figure out the amd 133 detection thing. I have two theories currently which I am waiting for Retro to test. one is VOLDET and the other is SETMUL.
It goes without saying that this device is not idiot proof. And great care will have to be taken when setting it, as some pins on one cpu correspond to different functions on another.
Gotta add a note about wt/wb on one of the SETMUL pins speaking of..
By the way, you guys might be able to use this with a modern psu using its 3.3v as a source for the 3.3v no need really for fancy power circuits? just run the wire. (Something that will have to be prototyped by an adventurous soul.) some capacitors between vcc and vss may be a good idea. but here isn't much room..
Edit: vcc/vss mislabel fixed in next version
Reply 62 of 94, by Sphere478
this is kinda what I was thinking.
The attachment New Bitmap image.png is no longer available
Also more adjustments for alpha 6 in the works.
Reply 63 of 94, by Anonymous Coward
The i487SX is not a math coprocessor, even though it was marketed as one. Definitely not the first thing I think of when somebody mentions a math coprocessor. Not sure why anyone would want to run an i487SX on its own, isn't part of the fun having two CPUs installed simultaneously? Perhaps the people who own newer boards with only one socket feel left out.
A feature that *would* be useful is to let the module be jumpered for i487SX pinout. Sadly, there are some systems with soldered on CPUs and overdrive sockets that only accept this type of CPU (though they can be modded).
I think if you read further up in the post, you'll find the reason why "math coprocessor" made the list is because Sphere submitted a picture of the Cyrix 487S interposer and wondered if that could be integrated into the module. I'm pretty sure it's a 387.
Reply 64 of 94, by weedeewee
Installing a 487SX disables the 486SX. You will not be running two cpus. Just the one and the other one will only take up space.
Do not ask Why !
Reply 66 of 94, by Sphere478
weedeewee wrote on 2022-06-11, 10:18:
Isn’t that just halarious. I wonder who first figured that out. Talk about marketing bait and switch 🤣.
Speaking of, I wonder if there is a mod to make it run without the 486sx even installed at all. (Or does it?)
487SX 169pin socket: any way to use a normal 486DX2 there?
And just like that, we now have a new mod to add to the tweaker!
It looks like if we ground the pin mentioned it will allow the use of normal cpus in 487 sockets. (Not sure if this means without the primary cpu installed at all or not, but seems to work with both installed)
Edit:
Mod is now added. B14 was already a function pin implemented for setmul. So I just needed to add it to the instructions. Wouldn’t it be interesting if you could use non intel processors there now?
It looks like most processors use that pin for TMS test mode select. It usually has a internal pull up resistor. So it looks like pulling it low at worst case would put it in “test mode” whatever that is, but according to that thread all is well though when pulling it low. So Instructions for it have been added. They did note a memory issue though that was never fully resolved. I asked about it and got this response:
keropi wrote:
Hey man I do not have that system anymore, I reverted the mod and gave it away to an IBM collector I actually do not remember an […]
Hey man
I actually do not remember any of that stuff, they are gone from my mind 🤣 🤣 🤣
but I do remember there was something else missing and I made a mental note to not bother in the future with such upgrade
something fpu related I think? if I remember it I will drop you a pm!
keropi wrote:
the mod worked but all I remember is that FPU access? IRQ? something had the potential to lock the system
If I recall more I will let you know!
Reply 67 of 94, by Sphere478
http://www.pchardwarelinks.com/486pin2.htm
Oh this is handy^
Socket3 wrote on 2022-06-07, 19:06:
I have a literal buttload of socket 3 hardware, and so does fepioa. I could be one of the beta testers. […]
Sphere478 wrote on 2022-06-07, 08:27:
Anyone able to confirm this pin spacing with a caliper? […]
Here is a socket 3 footprint I threw together based on the pentium overdrive datasheet.
I need beta testers btw.
Need active feedback and engagement. or this probably won't get past alpha/beta
As for features:
- I think the most important thing on a socket 3 interposer is voltage. I think the ability to chose between 3.3, 3.45, 3.6 (needed for some cyrix 5x86 chips, also useful for OC), maybe 3.8, 4 and of course 5V would be top of the list.
- Another useful feature would be multiplier selection. Some boards only support 1x/2x (DX/DX2). Some boards lack a multiplier selection jumper (very early 486 boards and 386/486 combo boards). I don't know if this could be done from an interposer, but it probably can since kingston upgrade chips and the pentium overdrive work this way. This might also be useful for boards without documentation or without proper documentation.
- A 5v fan header could also be useful. Socket 3 chips don't get very hot, and having 5v header on the interposer would be cool so we don't have to hook up fans to molex connectors and mess up the wire management.
-Test points for CPU voltage would also be cool.
I reached out to you in PM, we should chat on discord.
I think at this point your wishes appear to be coming true, we just need to test them.
This device should be able to divorce the cpu voltage from the mainboard voltage with interposer sockets and allow it to be powered externally. Either at 3.3v or with a external converter of your choosing.
Later on, might give a onboard solution a whirl. But a external solution seems like it would be fine for now.
And the multiplier pins seem to be all wired up, just need to verify them.
Reply 68 of 94, by Sphere478
looking at some measurements here for the lif sockets and determining which PCB thicknesses will work with them. 0.4mm should work, and 0.6mm should work which is great because 0.6mm is cheap.
The good news is that, unlike socket 7, the male and female portions of the pins are compatible so no need for a different part above and below.
it lists the diameter at 0.018" and that's what I have on my intel dx2 cpu here
on socket 5/7 the pins seemed to fluctuate between 0.018 to 0.017
So I could change the hole size to 0.017 but honestly the 0.016 may work.
I have a 0.016 socket 7 prototype coming soon that I should be able to use to test one of the 486 pins on. hopefully JLC actually makes it 0.016 and doesn't just use standard drill sizes.
on a previous prototype it looked like they use a small drill and spiral it around in there to get to the right size which works.
obviously you should solder these connections even if the press fit is good if you plan on doing anything with VCC.
the one annoying thing that I am expecting is to possibly have to clip the tails of the pin headers or raise them. pin headers on a 0.6mm pcb is kinda iffy but I think it can work. super gluing the plastic collar to the pcb may help.
Reply 69 of 94, by Sphere478
Alpha 6
The attachment socket 1, 2, 3 interposer tweakeralpha 6.rar is no longer available
Mostly silk screen changes.
Reply 70 of 94, by jakethompson1
Anonymous Coward wrote on 2022-06-11, 13:14:
Yeah, but it sure looks pertty.
It sure wouldn't be justified, but another possibility is adding a Weitek co-pro capability via an interposer 😁
Reply 71 of 94, by Sphere478
Alpha 7
The attachment socket 1, 2, 3 interposer tweaker alpha 7.zip is no longer available
Okay,
I solved the remaining DRCs and beefed up the current paths with this one.
might pull the vccdet function off the board. I added that in anticipation of it possibly being why Retro's cpu won't work.
Some of the setmul pull ups are probably redundant as many chips already have that internally but having it on the tweaker won't hurt anything, especially since they are only on when jumper is set to that function. I put them on the socket 5/7 tweakers because not all the cpus there had internal pull ups. and it's easy to add. with the plethora of socket 1,2,3 cpus there may be a instance of missing pull up.
At this point, aside from any errors in design as of yet unnoticed, or a redesign prompted by new information, I'm pretty much waiting for confirmation of these mods working on actual hardware.
-The POD mods are decently well covered in the video posted earlier, so those should be okay.
-The 487 mod was documented in that thread posted earlier.
-The VCC external power will have to be tested in prototype stage. first with a DVM checking for shorts, and then with actual power.
-It's mainly the setmul pins that I want confirmed (Perhaps you guys have stumbled upon threads showing this mod before? If so, link it.)
-Remaining things to be resolved also: The amd 133 issue RetroPcUser discovered, and the one board that only likes cyrix cpus that Anonymous Coward has.
Reply 72 of 94, by Sphere478
jakethompson1 wrote on 2022-06-11, 17:44:
https://www.cpu-world.com/CPUs/4167/index.html
this one?
Fascinating. 🤔
On the next alpha I will probably adjust the untapped thru holes. as they won't need soldered I can pull the pads back so the user doesn't have to mess with all of them.
Reply 73 of 94, by Socket3
Sphere478 wrote on 2022-06-08, 07:21:
Ready for some testing? […]
As for features:
multiplier
CLKMUL
Clock Multiplier (Input)
The clock multiplier input defines the ratio of internal
core clock frequency to external bus frequency. If sampled Low, the core frequency operates at twice the external bus frequency (speed-double mode). If driven
High or left floating speed-triple mode is selected. CLKMUL has an internal pull-up to VCC
and may be left floating in designs that wish to select speed-triple clock
mode.
So I found the clock multiplier pin on a dx4 but things got interesting when I found another diagram that showed it in yet another location.
Then I found this nice webpage http://ps-2.kev009.com/eprmhtml/eprmx/h12203.htmNew Bitmap image - Copy - Copy.png
So it appears we have no less than three pins that were used for clock multipliers on various cpu types. Non standardization I'm assuming.
According to that link:
Cyrix 486
uses B14
AMD 486DX2-NV8T
uses B13
Intel DX4, Cyrix 5x86, AMD486S DX2SV8B DX4SV8B, and iDX4-WB (AMD-5x86)
uses R17
So we will need three separate switches for pull up, then again three more for pull down. (double throw won't work unless jumper, as we need to be able to disable them)
A small bit of good news is that one of those pins B13 doubles at wt/wb on Intel DX2-WB, Intel® PODP, AMD486S DX2SV8B DX4SV8B, and iDX4-WB (AMD-5x86)
The instructions for using this tweaker are going to be complicated I can already tell. and there doesn't seem to be much we can do about hat if this data is to be believed.
Hit me up on discord when you have some time and we can probe these features and do some proofs of concept. if all looks well I can sketch out a schematic for this.
Got it. Sent you a PM. Haven't been online for a few days, I took the week off work so I can sort out my huge mess in my garage I made during moving from one city to another and after parting out two cars. My retro PC stuff is also in there so I've spent the week building a 3m by 2m shelf out of L shaped steel for various heavy car parts.
Reply 74 of 94, by Sphere478
Socket3 wrote on 2022-06-11, 18:38:
No worries. 😀
The attachment socket 1, 2, 3 interposer tweaker alpha 8.zip is no longer available
Alpha 8
-Pulled unused pads back to the holes, and made the holes of those pads 0.019”
Forgot to update silk screen to alpha 8 in images but it's updated in pcb file.
Reply 75 of 94, by Sphere478
https://www.informit.com/articles/article.asp … 30978&seqNum=28
The internal core speed of the DX4 processor is controlled by the CLKMUL (Clock Multiplier) signal at pin R-17 (Socket 1) or S-18 (Socket 2, 3, or 6). The CLKMUL input is sampled only during a reset of the CPU and defines the ratio of the internal clock to the external bus frequency CLK signal at pin C-3 (Socket 1) or D-4 (Socket 2, 3, or 6). If CLKMUL is sampled low, the internal core speed will be two times the external bus frequency. If driven high or left floating (most motherboards would leave it floating), triple speed mode is selected. If the CLKMUL signal is connected to the BREQ (Bus Request) output signal at pin Q-15 (Socket 1) or R-16 (Socket 2, 3, or 6), the CPU internal core speed will be two and a half times the CLK speed. To summarize, here is how the socket has to be wired for each DX4 speed selection:
CPU Speed
CLKMUL (Sampled Only at CPU Reset)
2x
Low
2.5x
Connected to BREQ
3x
High or Floating
Unexpected cpu cache result.
TheMobRules wrote on 2018-11-04, 22:13:
Actually the Intel DX4 supports 3 different clock multipliers via de CLKMUL pin: […]
  • If CLKMUL is left floating or connected to Vcc, you get 3x (default)
  • If CLKMUL is grounded, you get 2x
  • If CLKMUL is connected to the BREQ pin, you get 2.5x
Source: http://www.informit.com/articles/article.aspx … 30978&seqNum=28
Based on this the Tweaker has been updated.
Reply 77 of 94, by Sphere478
5v to 3.3v
My Ultimate VL/EISA 486
trying to understand how this interposer is accomplishing this, it looks like some pads must be smd and others thru hole and the socket just sits on top of the pcb? which would give a fair amount of headroom between the socket and cpu for extra parts.
I was looking at adding a three pin regulator (or two) to this design to add voltage interposer capability but it turns out that I think the externally powered method may actually be better. hear me out:
Many modern quality PSUs probably have very clean 3.3v rails, and a 486 isn't the pickiest CPU, So simply using that rail just makes a lot of sense. as for higher voltages, just regulate down from 5v with an adjustable quality buck. or if you wanna go all out you can use a lab PSU there really isn't much room for suuuuper fancy stuff stuff on this Tweaker anyway.
To that end I've updated the pico psu adapter for 3.3v output.
Re: ATX to AT pico Adapter!
Reply 78 of 94, by Sphere478
The attachment socket 1, 2, 3 interposer tweaker Alpha 10.zip is no longer available
Alpha 10
Fixed some errors, made some adjustments
Reply 79 of 94, by Sphere478
here is the pico psu adapter btw they each have a spot for the 3.3v wire
Also, these may work as a regulator for the interposer should it ever go that route.
https://www.mouser.com/ProductDetail/Analog-D … %2FXfjFdA%3D%3D
https://www.mouser.com/ProductDetail/Analog-D … ZUEf7XPJg%3D%3D
