First post, by 1200XL M.U.L.E.
Hi there!
First post here - so, hello world!
I’m going to start rebuilding some old systems from my more youthful days soon. AT cases seem to be a hard find. Will I be able to fit an AT motherboard into a modern ATX case? I think I read somewhere the motherboard mounting holes lines line up the case but I will need to leave the rear I/O port plate off in order to access the keyboard connector.
Is there a known case that works out well?
Do folks just 3D print or build out custom case solutions?
Thanks!
Reply 1 of 11, by jakethompson1
As drive bays vanish this is becoming more difficult--getting to the point you're going to be looking for new old stock or a used case even for ATX.
Two cases I've done this with are the Thermaltake V3 and Cooler Master Elite 350. Both are long-discontinued. The latter has a ridge to the right side of the motherboard that limits how wide a board that can fit into the case.
In addition to the I/O shield the other issue is the power switch. If you use an ATX power supply with an adapter, it's possible to replace the intermittent power switch in the case with a latching one. Or, you can forego the switch and just use the one on the back of the power supply.
Reply 2 of 11, by waterbeesje
Basically you still can put an old AT board into the newest ATX case. Putting up drives is also less needed if you want to walk the CF route 😀
Stuck at 10MHz...
Reply 4 of 11, by Baoran
How well something like SilverStone Grandia GD09 would work for this purpose? I was considering it some time ago.
One problem I see is that there is no room for both optical drive and floppy drive.
Reply 5 of 11, by Plasma
One minor issue that you may encounter is ATX cases have 7 slots while AT cases have 8. So you won't be able to fully populate a motherboard with 8 slots unless you install a card with no ports in the last slot and remove the bracket.
Chenbro SR209 is a nice old school ATX case that is still available new.
Reply 6 of 11, by Sphere478
I need help figuring out a 3d print for putting a gotek in the atx shield and a slim cd. But otherwise it seems okay
ATX I/O shield models for 3D printing
Gotek in the I/O shield? With AT motherboard Need some 3D modeling help.
Re: Help me find the perfect computer case.
Sphere's PCB projects.
Reply 7 of 11, by imi
Baoran wrote on 2022-06-27, 19:53:
the GD07 has four 5 1/4" bays 😉
Reply 9 of 11, by 1200XL M.U.L.E.
Mostly for towers, I think, to suck in cold air from the bottom and expel it up top.
Reply 10 of 11, by Baoran
imi wrote on 2022-06-27, 20:43:
Yeah, but it is much bigger and costs almost double.
Reply 11 of 11, by Sphere478
mR_Slug wrote on 2022-06-27, 20:45:
I haven't really kept up with the modern world. Why do they put the PSU at the bottom now?
If talking about mine, it’s movable
