First post, by 1200XL M.U.L.E.
Hi there!
First post here - so, hello world!
I’m going to start rebuilding some old systems from my more youthful days soon. AT cases seem to be a hard find. Will I be able to fit an AT motherboard into a modern ATX case? I think I read somewhere the motherboard mounting holes lines line up the case but I will need to leave the rear I/O port plate off in order to access the keyboard connector.
Is there a known case that works out well?
Do folks just 3D print or build out custom case solutions?
Thanks!
