Reply 20 of 53, by Repo Man11
- l33t
You'll want to test your memory bandwidth with the motherboard's cache enabled and disabled once you have the K6-2+. With my TXP4 and a K6-2+ modified into a K6-3+ the memory bandwidth is significantly better with the motherboard's cache disabled.
Edit: Speedsys also shows that the system has better performance with the motherboard's cache disabled when combined with a K6-3+
"We do these things not because they are easy, but because we thought they would be easy."
