Reply 1240 of 2402, by Chadti99
- Oldbie
For anyone interested, the Rendition Verite works on the m919. At the same resolution as dosbench Quake I’m able to achieve 31.8fps in vQuake at 180MHz/1024k L2. Although chalk a couple frames up to vQuake using 1.08 for it’ base.
Update!
Forgot to do the jumper FSB trick. With the PCI bus running at a full 60MHz I’m able to hit 33.1 in vQuake! Which I believe is the fastest vQuake score I’ve recorded on a 486.
Update #2
VQuake appears to favor l2 in WB on this board. Im able to hit 33.3 now.
